#11
OK......since it has a "Catch" here's the answer
Richard Riley wrote:
On Wed, 11 Oct 2006 22:06:33 -0400, "Morgans" wrote: "Richard Riley" wrote I assume you ruled out the Cessna 337, the Defiant and the Boomerang. Yep, no centerline thrust. Boomerang isn't centerline, it's totally asymetric that ends up putting the engines really, really close together. But it is a one-off, so I wouldn't count it. Depends which engine fails. The right engine is only a few inches off the nose wheel centerline. |
Morgans wrote:
"Peter Duniho" wrote You do, of course, need sufficient directional control, but I'd guess that between the nosewheel, some rudder effectiveness, and even some judicious braking (even if it does lengthen the takeoff run even further), this is just a matter of pilot technique, not of whether it can be done at all. It seems as though nobody could argue against the point that with a dead engine, most light twins can not even MOVE in a straight line, from a standing start. I guess since most engines are outboard from the wheels, even brakes are no good at all, and that nosewheels will just slide sideways. Of course, rudders are no good at that speed. I seem to remember that in his book "Logging Flight Time", Bill Kershner described a demonstration flight he did for the Air Force in an Aztec, where he took off, flew through some maneuvers and landed with one engine shut down. Kris |
Morgans wrote:
Here is a link. No mention as to if more have been made. http://www.angelaircraft.com/ It is an attention getting, serious looking aircraft. Yes, but they market it for the "rough, unimproved airstrip" type of operation. Take a look at the first picture on that link. Notice the location of the props vs. the ground vs. the main gear. Those blades would be toast after about 100 hours. They brought the prototype up to Alaska about 15 years ago, hoping to make some sales. Not a single bite. Happy Flying! Scott Skylane |
karl gruber wrote: I gave Harmon Leonard a BFR about 20 years ago. He is long gone now but fancied himself quite an opera star. He owned a big freight company here in Seattle and was mostly retired. Bob Gardner will vouch for the fact that Harmon flew for about 30 minutes every day and his REPUBLIC TWIN SEABEE was a common sight in the sky around Boeing Field. http://tinyurl.com/h4jrs We had done some landings in Lake Washington and the STOL Twin Bee is really a terrific short field airplane. It has 6 feet of wing extension and Harmon just firewalled one engine from a slow water taxi. The airplane immediately went into a sharp turn but did manage to increase speed enough to get up on the step. It still went around in circles a couple of times, but finally got above Vmcg(w) and old Harmon just milked it off the water.................singing Lohengrin or something. It was a sight and sound to behold. I signed him off regularly because he never killed himself and nobody else would EVER fly with him. He WAS an excellent stick.............but somewhat of a scofflaw. Karl "Curator" N185KG I remember Harmon Leonard, but I did not know he was a pilot! A Seabee. Of course. I once toyed with the idea of getting one of those when we were thinking of moving out to the Hood Canal. Now that we live out there (or will, when we get back next month), I still have to wonder what I am going to do about a plane and flying. |
"Morgans" wrote in message
It seems as though nobody could argue against the point that with a dead engine, most light twins can not even MOVE in a straight line, from a standing start. I guess since most engines are outboard from the wheels, even brakes are no good at all, and that nosewheels will just slide sideways. Of course, rudders are no good at that speed. Navajos' nose wheel steering is connected by rods to the rudder pedals. It is easy to take-off on one engine. Free castoring nosewheels can be a bitch if not impossible. AeroCommanders and C-310s can be done. The secret is that as you speed up, the circle gets bigger and bigger. D. |
Similar Threads | ||||
A New Threat to The USA, Iranian F-14 Tomcats? Answer it ... | Amir - Iranian F-4 pilot | Naval Aviation | 13 | September 28th 06 11:34 PM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Answer on CEF ILS RWY 23 questions | Paul Tomblin | Instrument Flight Rules | 21 | October 17th 04 04:18 PM |
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
The answer to the gasoline problem | Veeduber | Home Built | 4 | May 22nd 04 08:58 PM |
