I just spoke with Lycoming regarding my very high fuel flow. Recently
I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
I'd do a flow test then clean all injectors and do another flow test. Just
have some help and extinguishers around as already mentioned. Get your hands on 4 baby food jars with lids. Poke 3 holes in each lid, center large hole for the injector nozzle, 2 outside holes for a piece of stiff wire to fashion into a hanger. (and to vent air) Weigh each empty set up, record empty weights. Insert nozzles into center holes, screw jar onto cover. Run boost pump after your helpers have been awakened and armed with extinguishers. Weigh each jar, compare net fuel weights. Clean, lather, rinse, repeat. Jim |
Sounds like they didn't understand that you are observing the high fuel flow
on an in-line true flowmeter rather than their pressure-based panel meter. "Robert M. Gary" wrote in message ps.com... I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
![]() Stan Prevost wrote: Sounds like they didn't understand that you are observing the high fuel flow on an in-line true flowmeter rather than their pressure-based panel meter. That's what I thought but I reenforced what I was saying several times. I really just don't want to send a 600 hr fuel servo for O/H for $2K if it doesn't need it. -Robert |
Why don't you just have the nozzles cleaned and rule that out?
Robert M. Gary wrote: Stan Prevost wrote: Sounds like they didn't understand that you are observing the high fuel flow on an in-line true flowmeter rather than their pressure-based panel meter. That's what I thought but I reenforced what I was saying several times. I really just don't want to send a 600 hr fuel servo for O/H for $2K if it doesn't need it. -Robert |
I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I remember discussing this when working on my A&P, and promptly forgot about it after I got out of school. IIRC, it has something to do with the fuel injection...if one is blocked, the other nozzles pick up the loss and are sometimes too efficent. Obviously I can't remember the exact cause, but I've heard the same exact thing before...blockage can cause an increase in fuel flow. |
"Emily" wrote in message Obviously I can't remember the exact cause, but
I've heard the same exact thing before...blockage can cause an increase in fuel flow. It causes an increase in the indication on the OEM indicator which in actuality is a pressure guage, not a flowmeter. Mr. Gary's system uses a true flowmeter and a clogged injector line should show a decrease in flow. D. |
I don't think so, at least not very much decrease. I think the fuel will
divide among the functioning injector nozzles. This is why the pressure increases when one is blocked, the fuel is forced through a fewer number of orifices, causing a greater pressure drop across them. "Capt.Doug" wrote in message ... "Emily" wrote in message Obviously I can't remember the exact cause, but I've heard the same exact thing before...blockage can cause an increase in fuel flow. It causes an increase in the indication on the OEM indicator which in actuality is a pressure guage, not a flowmeter. Mr. Gary's system uses a true flowmeter and a clogged injector line should show a decrease in flow. D. |
"Stan Prevost" wrote in message
I don't think so, at least not very much decrease. I think the fuel will divide among the functioning injector nozzles. This is why the pressure increases when one is blocked, the fuel is forced through a fewer number of orifices, causing a greater pressure drop across them. If we are talking about the OEM 'flowmeter', how many transducers does it have? It would need two to measure a pressure drop. It needs only one to measure the pressure near the spider. If it has only one transducer near the spider, and a nozzle clogs, the remaining nozzles won't flow enough to relieve the increased pressure and the result will be an increased 'flow' indication. D. |
![]() Capt.Doug wrote: "Stan Prevost" wrote in message I don't think so, at least not very much decrease. I think the fuel will divide among the functioning injector nozzles. This is why the pressure increases when one is blocked, the fuel is forced through a fewer number of orifices, causing a greater pressure drop across them. If we are talking about the OEM 'flowmeter', how many transducers does it have? It would need two to measure a pressure drop. It needs only one to measure the pressure near the spider. If it has only one transducer near the spider, and a nozzle clogs, the remaining nozzles won't flow enough to relieve the increased pressure and the result will be an increased 'flow' indication. The fuel flow measurement does not take into account pressure. Its just an inline wheel that spins around. -Robert |
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 02:19 AM |
MAKE THOUSANDS NO SCAM | [email protected] | Home Built | 0 | February 28th 05 02:06 AM |
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? | Mike Spera | Owning | 6 | December 13th 04 01:13 AM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
