I just spoke with Lycoming regarding my very high fuel flow. Recently
I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
I'd do a flow test then clean all injectors and do another flow test. Just
have some help and extinguishers around as already mentioned. Get your hands on 4 baby food jars with lids. Poke 3 holes in each lid, center large hole for the injector nozzle, 2 outside holes for a piece of stiff wire to fashion into a hanger. (and to vent air) Weigh each empty set up, record empty weights. Insert nozzles into center holes, screw jar onto cover. Run boost pump after your helpers have been awakened and armed with extinguishers. Weigh each jar, compare net fuel weights. Clean, lather, rinse, repeat. Jim |
Sounds like they didn't understand that you are observing the high fuel flow
on an in-line true flowmeter rather than their pressure-based panel meter. "Robert M. Gary" wrote in message ps.com... I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
Stan Prevost wrote: Sounds like they didn't understand that you are observing the high fuel flow on an in-line true flowmeter rather than their pressure-based panel meter. That's what I thought but I reenforced what I was saying several times. I really just don't want to send a 600 hr fuel servo for O/H for $2K if it doesn't need it. -Robert |
Robert M. Gary wrote:
I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I remember discussing this when working on my A&P, and promptly forgot about it after I got out of school. IIRC, it has something to do with the fuel injection...if one is blocked, the other nozzles pick up the loss and are sometimes too efficent. Obviously I can't remember the exact cause, but I've heard the same exact thing before...blockage can cause an increase in fuel flow. |
Why don't you just have the nozzles cleaned and rule that out?
Robert M. Gary wrote: Stan Prevost wrote: Sounds like they didn't understand that you are observing the high fuel flow on an in-line true flowmeter rather than their pressure-based panel meter. That's what I thought but I reenforced what I was saying several times. I really just don't want to send a 600 hr fuel servo for O/H for $2K if it doesn't need it. -Robert |
This is just at idle?
Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. John Robert M. Gary wrote: I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
The Visitor wrote: This is just at idle? Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. Anytime. However, it is a little bit intermitent. Sometimes it "clears" itself. I can't increase throttle w/o increasing mixture but I *MUST* keep the two perfectly in line, if either gets in front of the other the engine dies. It really feels like there is no fuel regulation. -Robert |
The Visitor wrote: This is just at idle? Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. Anytime. However, it is a little bit intermitent. Sometimes it "clears" itself. Probably the blockage in a fuel nozzle moving around. |
Robert, does it matter whether the boost pump is on or not?
| Thread Tools | |
| Display Modes | |
| Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 03:19 AM |
| MAKE THOUSANDS NO SCAM | [email protected] | Home Built | 0 | February 28th 05 03:06 AM |
| Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? | Mike Spera | Owning | 6 | December 13th 04 02:13 AM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 08:17 AM |
