This is just at idle?
Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. John Robert M. Gary wrote: I just spoke with Lycoming regarding my very high fuel flow. Recently I've had a problem where I'm getting almost double my normal fuel flow at idle even with the mixture at the edge of cut-off. I suspected a servo but called Lycoming. They said I may have a nozzel with a blockage and the other nozzles are streaming because of it. Does this make any sense? Could a blockage cause an *INCREASE* in fuel flow? I have a JPI fuel transducor wheel that measures fuel flow that has shown to be very accurate. -Robert |
The Visitor wrote: This is just at idle? Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. Anytime. However, it is a little bit intermitent. Sometimes it "clears" itself. I can't increase throttle w/o increasing mixture but I *MUST* keep the two perfectly in line, if either gets in front of the other the engine dies. It really feels like there is no fuel regulation. -Robert |
The Visitor wrote: This is just at idle? Are your manifold pressure and rpm readings in line with each other? I am thinking about cam shaft wear. Anytime. However, it is a little bit intermitent. Sometimes it "clears" itself. Probably the blockage in a fuel nozzle moving around. |
| Thread Tools | |
| Display Modes | |
| Does Lycoming make any sense? | Robert M. Gary | Piloting | 22 | October 24th 06 01:01 AM |
| Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 03:19 AM |
| MAKE THOUSANDS NO SCAM | [email protected] | Home Built | 0 | February 28th 05 03:06 AM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
