![]() "Happy Dog" wrote in message m... "Dave Stadt" One might say that the fatal accident rate seems disproportionate (50% of the SR20, 25% for the SR22 versus 10% for the 172 and 20% for the 182), but at the sample sizes present, there's absolutely no reasonable way to draw any valid statistical conclusion (and note that for the SR22 and the 182, the rates are actually similar). Apples and oranges. The 182 fleet is many times larger than the SR22 fleet. And the 172 fleet is near infinite compared to the Cirrus fleet. The numbers look pretty bad for Cirrus. Did you adjust for the kind of flying done by each? No, you didn't. The flights all involve an equal number of takeoffs and landings only some are more successfull in the landing department than others. Unless you wish to redefine "flight" , no, they don't. Are circuits "flights"? moo I suspect so. Unless one just motors around on the ground in a big rectangle. |
![]() Although the SR-22 is fixed gear wouldn't it be more appropriate to compare them to other planes of similar performance and wing loading? Then remove the "gear up" incidents for the final comparison? When it comes to performance and handeling the SR-22 is about as far from a 172 as you can get. I don't know of any "every day" retracts like the Bo, or Mooney with near the wing loading of the SR-22 and the 172 can be over 26% less than those at a tad over 14# per sq ft. Actually both the Mooney and Bo are far easier to slow down even with the tendency to float by the Mooney and they have roughly 30% less wing loading than the SR-22. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Peter Duniho" wrote A quick NTSB database search shows in the last six months 4 accidents (2 fatal) involving a Cirrus SR20, and 52 (5 fatal) involving a Cessna 172. The SR22 was involved in 7 accidents (2 fatal), while the Cessna 182 was involved in 36 (6 fatal). Clue - Look at fleet size, then adjust for that, and come back with some more meaningful statistics. How many bazillion C172's are there out there, vs. Cirrus? -- Jim in NC |
"Morgans" wrote in message
... Clue - Look at fleet size, then adjust for that, and come back with some more meaningful statistics. The fleet size isn't nearly as relevant as total flight hours for the flight over a span of time. And yes, I agree that the data is missing. However, none of you have provided alternate data to support the claim that the Cirrus is actually worse. And at first glance, the total number of Cirrus accidents is MUCH lower than for Cessna accidents, which is exactly what one would expect given the difference in fleet sizes. Clue: when you are making accusations, the burden of proof is on YOU. If you're going to claim that the accident rate is abnormally high, you need to provide data to support that claim. Suggesting that the defense has insufficient data isn't meaningful. Pete |
![]() Morgans wrote: "Peter Duniho" wrote A quick NTSB database search shows in the last six months 4 accidents (2 fatal) involving a Cirrus SR20, and 52 (5 fatal) involving a Cessna 172. The SR22 was involved in 7 accidents (2 fatal), while the Cessna 182 was involved in 36 (6 fatal). Clue - Look at fleet size, then adjust for that, and come back with some more meaningful statistics. How many bazillion C172's are there out there, vs. Cirrus? One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. It is only a bit better if you compare both Cirrus and Cessna types. The parachute should make Cirrus accidents more survivable, not less. John Halpenny |
On 31 Oct 2006 17:28:21 -0800, "John Halpenny"
wrote in .com: One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. It is only a bit better if you compare both Cirrus and Cessna types. The parachute should make Cirrus accidents more survivable, not less. What's the SR20's stall speed compared to the C-172? The kinetic energy expended in a mishap increases exponentially with the square of the velocity. |
"John Halpenny" wrote in message
oups.com... One thing these figures seem to say is that 50% of SR20 accidents are fatal, but only 10% of 172 accidents are. As I pointed out previously, there aren't enough SR20 accidents (or even SR20 and SR22 combined) to make any valid statistical conclusions. The statistical error on the sample size exceeds the number of samples. Pete |
Recently, Peter Duniho posted:
A quick NTSB database search shows in the last six months 4 accidents (2 fatal) involving a Cirrus SR20, and 52 (5 fatal) involving a Cessna 172. The SR22 was involved in 7 accidents (2 fatal), while the Cessna 182 was involved in 36 (6 fatal). One might say that the fatal accident rate seems disproportionate (50% of the SR20, 25% for the SR22 versus 10% for the 172 and 20% for the 182), but at the sample sizes present, there's absolutely no reasonable way to draw any valid statistical conclusion (and note that for the SR22 and the 182, the rates are actually similar). The fact is, none of these airplanes are actually involved in fatal accidents all that often, and the absolute numbers for overall accidents are significantly lower for the Cirrus types than for comparable Cessna types (of course, with a presumably much smaller fleet size, that's to be expected, even without accounting for differences in utilization). Without the total fleet numbers, it is difficult to establish a proportionate accident rate, but there is face validity to the notion that the Cessna accident rate is far lower than Cirrus', given other methods of comparison such as time flown per type or number of TOs & Landings. Looking only at the type of accidents, one may conclude that pilot error is the primary cause for either make of plane. Neil So, it seems to me that before we start throwing around statements like "the problem is with the pilots, not the airplanes", it ought to be established that there *is* a problem in the first place. Pete |
On Fri, 27 Oct 2006 18:26:33 -0400, "Kyle Boatright"
wrote: "john smith" wrote in message ... With the recent spate of Cirrus accidents, the question arises, "Is it time for a special certification review?" Any aircraft has a baseline accident rate. I think the Cirrus has a higher accident rate because a handful of pilots get themselves into a mindset where they are willing to enter conditions they would have not entered without the big round "insurance policy". Often they get away with pushing things. Sometimes they don't, and those accidents are the ones that are taking the Cirrus accident rate to higher than predicted levels. The problem is with the pilots, not the airplanes. I agree. This discussion has come up at least twice a year since the SR-20 and 22 came out. The SR-22 is a capable airplane. It has the BRS for "just in case", it has the weeping wing deice for "just in case". It's not for know icing, but just in case, it has the simple (er) set of engine and prop controls, and it has fixed gear. BUT it has high wing loading. A fair amount higher than most fixed gear pilots are used to and noticeable heavier than a Bo. SR-22 loading is about 23.5 while the Bo is on the order as about the same as a Cherokee at 17.2. The Bo wing loading covers a wide rage from about 16 to 19# per sq ft. It's one whale of a lot slipperier though than the Cherokee though. This is almost 32% heavier loading compared to the Cherokee and the lighter Bonanzas and Debonairs. That is not to be taken lightly and there is no pun intended. Over a 30% change in wing loading is a serious change particularly for low time pilots. I thought I'd take the easy way out and do a quick search instead of calculating a bunch of wing loadings. The first thing that came up was: http://www.aviation-pilots.com/construct/thread41.html Then I noted who did the calculations. Careful what you say as it's sometimes surprising as to where it shows up. :-)) At any rate, the SR-22 has all these whiz bang safety features AND it's fixed gear, but it has the performance of a Bonanza with up to 30% heavier wing loading. The safety features are great, but here we have an airplane that is meant for, or should be meant for experienced pilots used to high performance be it fixed or retract gear. Put all these features in a plane and then put the typical pilot with a fixed gear mentality behind the yoke and it could be a recipe for disaster. I mean no disrespect to fixed gear pilots. The typical fixed gear pilot moving to the SR-22 would be akin to me moving to a TBM-700 or 850 One is a pilot with a 130 MPH mind moving to a 200 MPH airplane while I'd be the pilot with a 200 MPH mind moving to a 360 MPH airplane. OTOH I do have at least a little experience with faster planes with much higher wing loading, but not enough to be safe though. My point is that even with all the training provided and *required* the pilots *appear* "to me" to be flying a 200 MPH high performance airplane as if it were a 130 MPH airplane. As a purely personal opinion, I think they should forget it has a fixed gear and fly it as if it were a retract. Actually I think the retract has an advantage. The SR-22 is slippery with a high wing loading. In a Bonanza if you get into trouble they tell you to put the gear down and forget the doors. When the gear goes down even at pattern speed it feels like some one put the brakes on although the brakes with those tires don't have that much authority on the runway. :-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
"Roger (K8RI)" wrote: In a Bonanza if you get into trouble they tell you to put the gear down and forget the doors. When the gear goes down even at pattern speed it feels like some one put the brakes on although the brakes with those tires don't have that much authority on the runway. :-)) The best way to slow a retract down is to put the gear down in the air, and pick it up again in the flare. :-) |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
