Some seaplane props are featherable and reversable so the seaplane can
	stop or backup and so the prop can be used as a brake. I believe the Cessna Caravan in Seaplane config can do this, not sure.  |
The PT6 engine can be feathered or the blade angle can go to
	a reverse setting and the plane can be backed up, as can the King Air. The prop angle for feathering is about 90 degrees while normal flight is in the range of 15-45 degrees. Blade angles less than 15 degrees are called beta and when they get to 0- [15] degrees they are reverse. Those numbers are generally correct, but from my memory. The blade angle is changed when the prop control is pulled into the reverse range, which is before actually reaching 0 because of forward speed. Pulling the prop control further spools the engine back into a power range. Reverse is usually, but not always, locked out in flight. The Pilatus can be put in reverse in flight as can certain other planes. But some airplanes that can be reversed in flight are not safe to do so. A Beech test pilot told me that he had put a BE E90 in reverse in flight and the airplane did a very fast flip. On the other hand he also said that the T-tailed King Airs [f90-200-300] did not do this since the tail was not blocked by the slipstream. This may or may not be true, it is just something I was told. On the ground, dirt ingestion and prop damage are the limiting factors. "Doug" wrote in message oups.com... | Some seaplane props are featherable and reversable so the seaplane can | stop or backup and so the prop can be used as a brake. I believe the | Cessna Caravan in Seaplane config can do this, not sure. |  |
MT Propeller has a reversable prop the experimental guys put on Super
	Cubs and that sort of plane. It is MOST useful with a Seaplane and can be reversed on landing. It can't be reversed when you are over 1400 rpm or some such and cant be reversed in the air. Both Beta (feather) and reverse would be very useful in a Seaplane.  |
			 Jim Macklin wrote: The Pilatus can be put in reverse in flight as can certain other planes. But some airplanes that can be reversed in flight are not safe to do so. The PC12 POH warns against reversing pitch in-flight. My training captain beat that into my head when I was first training in the airplane. There are three situations when reverse should not be used IIRC. In flight, when the engine is shut down, and ... dammit, can't remeber the third... back to the books I go : )  |
			 "Kingfish" wrote in message ups.com... Jim Macklin wrote: The Pilatus can be put in reverse in flight as can certain other planes. But some airplanes that can be reversed in flight are not safe to do so. The PC12 POH warns against reversing pitch in-flight. My training captain beat that into my head when I was first training in the airplane. There are three situations when reverse should not be used IIRC. In flight, when the engine is shut down, and ... dammit, can't remeber the third... back to the books I go : ) When there's something behind you? Barrie  |
			 Barrie wrote: The PC12 POH warns against reversing pitch in-flight. My training captain beat that into my head when I was first training in the airplane. There are three situations when reverse should not be used IIRC. In flight, when the engine is shut down, and ... dammit, can't remeber the third... back to the books I go : ) When there's something behind you? THAT'S IT!! Thanks Barrie : )  |
Barrie wrote:
	The PC12 POH warns against reversing pitch in-flight. My training captain beat that into my head when I was first training in the airplane. There are three situations when reverse should not be used IIRC. In flight, when the engine is shut down, and ... dammit, can't remeber the third... back to the books I go : ) When there's something behind you? When the backup bell is inop! TheSmokingGnu  |
PC 6   high wing STOL bush plane
	http://images.google.com/imgres?imgu...LJ:en%26sa%3DN "Kingfish" wrote in message ups.com... | | Jim Macklin wrote: | The Pilatus can be put in reverse in flight as can certain other planes. | But some airplanes that can be reversed in flight are not | safe to do so. | | The PC12 POH warns against reversing pitch in-flight. My training | captain beat that into my head when I was first training in the | airplane. There are three situations when reverse should not be used | IIRC. In flight, when the engine is shut down, and ... dammit, can't | remeber the third... back to the books I go : ) |  |
better link
	http://www.quiberonairclub.com/Image...PC-6%20(3).jpg "Jim Macklin" wrote in message ... | PC 6 high wing STOL bush plane | http://images.google.com/imgres?imgu...LJ:en%26sa%3DN | | | | "Kingfish" wrote in message | ups.com... || || Jim Macklin wrote: || The Pilatus can be put in reverse in flight as can | certain other planes. || But some airplanes that can be reversed in flight are | not || safe to do so. || || The PC12 POH warns against reversing pitch in-flight. My | training || captain beat that into my head when I was first training | in the || airplane. There are three situations when reverse should | not be used || IIRC. In flight, when the engine is shut down, and ... | dammit, can't || remeber the third... back to the books I go : ) || | |  |
And the Lake  "Renagade": amphib can also....  reverse pitch for
	stopping and reversing. Dave On 27 Nov 2006 15:24:36 -0800, "Doug" wrote: Some seaplane props are featherable and reversable so the seaplane can stop or backup and so the prop can be used as a brake. I believe the Cessna Caravan in Seaplane config can do this, not sure.  |
| Thread Tools | |
| Display Modes | |
| Question on prop cycle | Frode Berg | Owning | 9 | April 25th 06 07:36 AM |
| Prop Balancing Question | A Lieberman | Owning | 3 | February 2nd 06 12:25 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
