#101
On Tue, 12 Dec 2006 14:50:04 -0800, Nomen Nescio wrote
(in article ): -----BEGIN PGP SIGNED MESSAGE----- From: "Brian" With perfect frictionless bearings it will take 0 force. If the engine is generating any thrust the airplane will move forward no matter what the treadmill does. As long as a magical massless wheel is attached to the magical frictionless bearing. There is no reason to assume that the treadmill will not fail first! So, not having enough information to determine if the treadmill will stop running before the wheels do, we cannot categorically say that the airplane will not take off because the wheels will fail. The motor of the treadmill might simply burn out first and the treadmill come to a stop. |
#102
On Mon, 11 Dec 2006 21:10:32 -0800, peter wrote
(in article om): Peter Duniho wrote: "peter" wrote in message oups.com... The problem is that as it is stated, the scenario is not one that could ever be created with a real treadmill subject to normal engineering constraints. [...] You can interpret the question in that way of course. However, the intent of the "puzzler" is clear, and the fact that it is poorly stated should not interfere with making a reasonable, good faith effort to address the intended question. It's well and good to nitpick about physically impossible situations, but rest assured if you started doing so in a true interactive situation in which the person stating the puzzle had the opportunity to restate it, you would quickly get past the nitpicking and get to the intended question. It's a waste of time to do the nitpicking in the first place. It's easy enough to infer what the interesting question really is. My view was that it was exactly the infinite feedback mechanism that made the problem as stated interesting. Otherwise it's trivial and boring. Heh, heh. So use a ski plane. Since the speed of the skis is "zero" under the terms of the problem, the treadmill will remain motionless! Problem solved. |
#103
Christopher Campbell wrote:
On Wed, 13 Dec 2006 14:34:54 -0800, peter wrote (in article . com): Christopher Campbell wrote: The other gotcha in this little puzzle is that it attempts to get you to divide by zero. Explain to us please where the statement of this problem ever involves division by zero. One can readily see where the statement implies a value of zero for air speed since in the absence of wheel slip: Treadmill speed = wheel speed (stated explicitly in the problem) and Air speed = wheel speed - treadmill speed (assuming calm air) this directly implies that Air speed = 0. But I don't see where division by zero ever comes into play. The stated problem does imply a runaway positive feedback in the treadmill speed control. I.e. the moment the plane starts to roll forward the control system would speed up the treadmill to match the wheel speed. The motion of the treadmill would then speed up the wheel rotation to a higher speed thus forcing the treadmill to move still faster to catch up. The result would be an ever increasing treadmill and wheel speed until something gives - most likely the tires (if we ignore the technical difficulty of building the specified treadmill). This is the old Achilles vs. the Tortoise conundrum that so puzzled ancient Greek mathematicians. The puzzle was this: Achilles and a Tortoise agree to have a race. Achilles agrees to let the Tortoise have a head start of getting half way to the finish line. The starting gun sounds and they are off! (Well, the Tortoise is, anyway.) The Tortoise reaches the half-way mark and Achilles starts running. But by the time that Achilles reaches the half-way mark, the Tortoise has moved forward. And by the time that Achilles reaches the point where the Tortoise has moved to, the Tortoise has moved forward again, albeit not as far as before. Again Achilles reaches the third point where the Tortoise was, but the Tortoise has moved forward again. No matter how fast Achilles runs, he can never catch up with the Tortoise. It was this sort of logic that led the Greeks to conclude that everything was imaginary and that motion was impossible. They could not solve the problem because they did not have the number zero. Zeno's Paradox. But I doubt if you could find any ancient Greeks who actually concluded that motion was impossible. Even while puzzling with Zeno over his problem, they continued to go to the markets to do their shopping and to their respective work places. And there's no need to have the concept of the number zero to solve Zeno's paradox, just the idea of the convergence of some types of infinite sums. I.e. if each successive run of Achilles is half as long as the previous one (say he walks twice as fast as the tortoise) then we have a sum for the total distance 'D' of the form: D = x + x/2 + x/4 + x/8 +... multiplying this by 2 gives: 2D = 2x + x + x/2 + x/4 + x/8 + ... = 2x + D subtract D from both sides and we solve for the total distance Achilles needs to walk: D = 2x; i.e. twice the distance of the headstart he gives the tortoise. The airplane-on-a-treadmill is just a restatement of the same problem. It attempts to convince you that the airplane cannot move relative to an outside observer if the treadmill always moves at the same speed as the wheels. If the wheels accelerate, then the treadmill accelerates, so the plane cannot move, right? Wrong. The airplane does move, and it accelerates relative to an outside observer at the same rate as it would if the treadmill remained stationary. The only thing that changes is that the wheels spin faster. Sure, but airplane wheels have some maximum speed. Once the treadmill gets up to that maximum speed the airplane wheels would fail and the airplane is now sitting on a treadmill with a bunch of failed tires. So the question becomes whether a plane can still take off after you shoot out all the tires when it first begins its takeoff roll. And yes, postulating a frictionless surface for the treadmill gets around the problem and allows a normal takeoff. But the very term treadmill implies a surface with reasonable friction, i.e. the tread. Well, if you understand Zeno's paradox, then you understand enough that the airplane will move forward on the treadmill. If the tires don't blow, it will take off. On the contrary, *if* the treadmill is able to perform as explicitly stated in the problem; i.e. to always keep increasing speed so that it is moving at the speed of the wheels but in the opposite direction, then the plane won't be moving forward relative to the ground or still air. The ability of a real treadmill to do that isn't relevant since that performance is stipulated in the problem statement. I will refer you to the book "Godel, Escher, Bach" for a discussion of how the problem is created by an attempt to divide by zero. You're the one making that claim - how about supporting it rather than just handwaving about it being somewhere in a book? If your only argument is that airplane tires will not stand the stress, then you are placing a constraint on the problem that is not originally stated. You are basically changing the question. No, the problem doesn't say that there's anything out of the ordinary about the plane, so characteristics that are common to all actual planes will also apply to the one in the problem. Some airplane tires might stand the stress; others might not. Tires are highly variable in their design and intended purpose. You cannot flat-out declare that all tires would fail. The statement is true of all airplane tires that at some speed they will fail. In fact, why would not the treadmill break down before the tires? The motor could overheat and stop the treadmill entirely, or the treadmill surface could disintegrate, or it might be crushed by the airplane. The airplane could be so heavy that the treadmill could not turn at all. We cannot assume that the treadmill is any less immune to stress than anything else stated in the problem. But the problem explicitly states that the treadmill *will* keep up with the speed of the airplane wheels. Unlike the airplane, the treadmill is clearly a hypothetical construct that is only invented for the purposes of posing the problem. I am not assuming anything about it other than what is stated in the problem; i.e. that it is a "tread"mill and therefore can be assumed to have a reasonable friction surface, and that it is controlled and propelled in such a way as to always keep up with the speed of the airplane wheels as they spin. If the treadmill were to break and therefore no longer keep up with the wheel speed that would be a direct contradiction of the explicit problem statement. So, lacking any further limitations as stated in the problem, tires must be assumed to be capable of withstanding the stress of the treadmill. Otherwise, why not throw in all other kinds of variables not stated in the problem, like flap settings, wind, temperature, density altitude, fuel on board, payload, visibility, clearance, and whether it would violate FAA rules? The problem makes no statement about these variables, nor about the tire strength, for the very reason that these are not hypothetical constructs like the treadmill, but common to everyday airplane operations at every airport on a daily basis. The question is whether a normal plane, operated with normal engines, normal controls, normal tires, etc. can take off under the very abnormal condition of being on a hypothetical treadmill with the given characteristics. No, go with the problem as stated, and let us not make it a trick question by assuming facts not presented to the audience. I *am* going with the problem as stated. In particular where it explicitly states that the treadmill will move backwards at the speed of the airplane's wheels. Unless the tires are slipping, which rubber tires shouldn't do appreciably on a 'treadmill' surface, then Ground speed = wheel speed - treadmill speed and since the problem stipulates that treadmill speed = wheel speed we can easily solve this as: Ground speed = wheel speed - wheel speed = 0. If you're claiming that the ground speed (i.e. relative to the earth and still air) is something other than zero, then it is you who is not going with the explicit statement of the problem. As for making it a trick question, I'd note that it is a puzzle question, not an engineering design question. Puzzle questions are generally intended to be trick questions in one or more ways - that's what makes them interesting and provokes contradictory responses. If it were given to me as an engineering question then I'd immediately point out that the treadmill being requested can't possibly be built since it requires instant acceleration of a massive structure and would request that the project be modified to come up with something feasible. But as a puzzle question having a gigantic treadmill that can instantly accelerate to thousands of miles per hour is perfectly legitimate - just don't ask me to build one. |
#104
On Wed, 13 Dec 2006 23:37:37 -0800, peter wrote:
On the contrary, *if* the treadmill is able to perform as explicitly stated in the problem; i.e. to always keep increasing speed so that it is moving at the speed of the wheels but in the opposite direction, then the plane won't be moving forward relative to the ground or still air. The ability of a real treadmill to do that isn't relevant since that performance is stipulated in the problem statement. Lock the brakes and do the takeoff... The treadmill will sense it as an attempt of the wheels to go backwards and and start moving in the direction that the plane wants to go anyway... |
#105
Grumman-581 wrote:
On Wed, 13 Dec 2006 23:37:37 -0800, peter wrote: On the contrary, *if* the treadmill is able to perform as explicitly stated in the problem; i.e. to always keep increasing speed so that it is moving at the speed of the wheels but in the opposite direction, then the plane won't be moving forward relative to the ground or still air. The ability of a real treadmill to do that isn't relevant since that performance is stipulated in the problem statement. Lock the brakes and do the takeoff... The treadmill will sense it as an attempt of the wheels to go backwards and and start moving in the direction that the plane wants to go anyway... If the brakes are locked then the wheel speed is zero and the treadmill speed (as specified in the problem) must also immediately go to zero. |
#106
("peter" wrote)
If it were given to me as an engineering question then I'd immediately point out that the treadmill being requested can't possibly be built since it requires instant acceleration of a massive structure and would request that the project be modified to come up with something feasible. But as a puzzle question having a gigantic treadmill that can instantly accelerate to thousands of miles per hour is perfectly legitimate - just don't ask me to build one. The treadmill need only be (approx) 6-ft wide x 8-ft long. (If it needs to be any longer, your answer is wrong) The object (the plane) isn't THAT heavy. Our GIGANTIC treadmill only needs to average both accelerations - not have instant acceleration. (Kind of like your home's thermostat keeping the room at 68F. It has a 3 or 4 degree temp spread so it isn't "popping" on all the time. BTDT) When the plane roles forward two inches, the electric motors speed up ....until the 'curb feeler' sensors detect the axle has returned to point X. Then, with basic computing, the treadmill readjusts its speed. It might be only an inch for the "forward" or "back" tolerances ...or it might be a foot. It's a small Cessna/Piper/Cri-Cri we're dealing with, here. NOT an F-18 off a carrier deck! If you can't slap one of these puppies together in an afternoon... :-) Montblack-to-the-drawing-board |
#107
Montblack wrote:
("peter" wrote) If it were given to me as an engineering question then I'd immediately point out that the treadmill being requested can't possibly be built since it requires instant acceleration of a massive structure and would request that the project be modified to come up with something feasible. But as a puzzle question having a gigantic treadmill that can instantly accelerate to thousands of miles per hour is perfectly legitimate - just don't ask me to build one. The treadmill need only be (approx) 6-ft wide x 8-ft long. (If it needs to be any longer, your answer is wrong) Unlike other responders here, I'm trying to go by what the problem actually states, not what they think it should state instead. In particular, the problem says "Imagine a plane is sitting on a massive conveyor belt, as wide and as long as a runway." So it needs to be as wide and long as a real runway to be in agreement with the problem statement - that's much bigger than 6' x 8' - at least based on the real runways I've come across. (But I commend you on your short field landing and take off skills.) The object (the plane) isn't THAT heavy. Our GIGANTIC treadmill only needs to average both accelerations - not have instant acceleration. (Kind of like your home's thermostat keeping the room at 68F. It has a 3 or 4 degree temp spread so it isn't "popping" on all the time. BTDT) Your home heating system is in a negative feedback, well-controlled situation as opposed to the treadmill which is in a positive feedback, runaway and out-of-control situation. In the first case the action taken in response to the stimulus (turning on the furnace when it gets too cold) acts to reduce the stimulus. But in the second case, speeding up the treadmill when the wheels speed up, only acts to make the stimulus worse. So the faster the treadmill goes, the more it pulls the wheels of the plane around and makes them spin even faster. I've experienced that kind of positive feedback in miswired electronic control circuits and it results in rapid escalation out of the physical bounds of the devices - i.e. as soon as it was turned on there was a sudden flash, a puff of smoke, and generation of lots of heat. When the plane rolls forward two inches, the electric motors speed up ...until the 'curb feeler' sensors detect the axle has returned to point X. But that won't happen easily since the plane is being pushed forward by the thrust of its motor (a substantial force) and the only thing pushing it back to point X is the slight frictional drag of the spinning wheels. So until the treadmill reaches a really high speed where that frictional drag becomes significant (probably when either the wheel bearings start to overheat or the tire starts to fail) the plane will keep moving forward and triggering the treadmill to go ever faster. Then, with basic computing, the treadmill readjusts its speed. It might be only an inch for the "forward" or "back" tolerances ...or it might be a foot. Let's give it your maximum tolerance of a foot. That means that in the time it takes your Cessna 150/whatever to move forward just one foot the treadmill needs to speed up to the point where the wheel drag is enough to equal the thrust from propellor. A 150 may not have a whole lot of thrust, but it's still large compared to the drag of the wheels turning at say 100 mph. I'd call an acceleration from 0 to 100mph in the time it takes the plane to move a foot pretty impressive for a treadmill the size of a runway - and that wouldn't even be enough since the thrust is still larger than the 100 mph drag force. So the treadmill has to go still faster until something in the plane's landing gear (tires/bearings/etc.) breaks and results in a greater frictional drag force which can counter the propellor thrust. It's a small Cessna/Piper/Cri-Cri we're dealing with, here. NOT an F-18 off a carrier deck! If you can't slap one of these puppies together in an afternoon... :-) I think you're seriously underestimating the difficulty of the design, but you're welcome to prove me wrong with a working model. |
#108
In article .com,
"peter" wrote: On the contrary, *if* the treadmill is able to perform as explicitly stated in the problem; i.e. to always keep increasing speed so that it is moving at the speed of the wheels but in the opposite direction, then the plane won't be moving forward relative to the ground or still air. The ability of a real treadmill to do that isn't relevant since that performance is stipulated in the problem statement. What keeps the wheels in contact with the treadmill when the treadmill (and wheels) are going supersonic? -- Bob Noel Looking for a sig the lawyers will hate |
#109
"Travis Marlatte" wrote in message ... "Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message What you saw was an aircraft that failed to achieve and or retain a critical airspeed. Either the catapult failed or the engine failed or, well any number of things. There is a reason carriers turn into the wind to launch aircraft. There is also a reason that carriers can't launch fixed wing aircraft while tied to the dock. Well they might be able to but a lot of things have to be perfect. Thanks. But it was a joke. I do question the word "can't" in your explanation. I would believe "can't launch some fixed wing aircraft but not as a general statement. That's why I added the sentence that immediately follows the one you have a problem with. |
#110
"Bob Noel" wrote in message ... In article .com, "peter" wrote: On the contrary, *if* the treadmill is able to perform as explicitly stated in the problem; i.e. to always keep increasing speed so that it is moving at the speed of the wheels but in the opposite direction, then the plane won't be moving forward relative to the ground or still air. The ability of a real treadmill to do that isn't relevant since that performance is stipulated in the problem statement. What keeps the wheels in contact with the treadmill when the treadmill (and wheels) are going supersonic? -- Bob Noel Looking for a sig the lawyers will hate In the original problem statement; nothing except gravity causes contact of the wheels, or any other part of the airplane, to the treadmill at any speed. Peter |
| Thread Tools | |
| Display Modes | |
| VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 7th 06 12:13 AM |
| Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 8th 05 12:17 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
