In-Panel 396/496 Setups with the 430/530?
Old December 18th 06, 04:26 PM posted to rec.aviation.owning
Marco Leon
Default In-Panel 396/496 Setups with the 430/530?
Does anyone have this setup where the 396/496 (particularly the 496) is
in their panel hooked up through an RS232 cable to a 430 or 530? I saw
a post by Mikem with very good specifics on the pin-outs but I have a
couple of questions:
1) Does the 496 pick up the inputted flight plan/route from the
430/530?
2) If yes, what's the procedure? Does it act like another IFR box where
you need to use the cross-fill function or is it automatically filled?
3) Again, if yes, how critical is it to keep the 496 up to date with
the same database? Will it behave badly if it is not in sync and there
is a renamed fix in the active plan? I plan on updating the 496 only
once or twice per year while I have the 430 on the IFR-mandated 28-day
cycle (OK guys, don't get hung up on the term "mandated"--you know what
I mean).
One last question, has anyone done the panel mounting of the 396/496
themselves or is everyone going to an avionics shop? I may need to
travel a bit to do this since the nearest [reasonably-priced] avionics
shops are in Connecticut and the word that their local FSDO is very
strict and does not approve of the Airgizmos installation on certified
aircraft. The local FSDO at my location (Farmingdale) is OK with it and
looks at it as an installation that does not require a 337 (although
recommended). However, I will want to do the RS232 conx so doing it
myself is out of the question.
Marco
Old December 18th 06, 05:23 PM posted to rec.aviation.owning
Mike Granby
date with the same database? Will it behave badly if it
is not in sync and there is a renamed fix in the active
plan? I plan on updating the 496 only once or twice per
"mandated"--you know what I mean).
I have my 496 fed from either my KLN-94 or my KLN-90B, and the
databases are way out of sync. It works fine. The 496 will create a fix
if it has to, and it's position is different from that in the data from
the IFR unit, you just end up with an aliased user waypoint, offset
slightly from the 496's version.
Old December 18th 06, 06:16 PM posted to rec.aviation.owning
Frank Stutzman
I have my crusty 195 attached to my 430. Should be simular.
430/530?
Yes. Change the route on the 430 and it is automatically sent to the
handheld.
No cross-fill necessary.
cycle
Don't know, never noticed, and my 195 hasn't been updated in a couple of
years. On the other hand the airports or other way points don't move
change much.
Someone else will have to address this question. My avionics shop was
fine with giving me a unterminated serial cable. I put on the connector
and finished the handheld mounting to my satisfaction. Probably would
give some FSDO fits.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old December 18th 06, 07:41 PM posted to rec.aviation.owning
Marco Leon
Sounds like it plays nicely with a non-Garmin mate. Thanks.
Marco
Old December 18th 06, 07:45 PM posted to rec.aviation.owning
Marco Leon
handheld.
change much.
Thanks for your PIREP. If it plays nicely with the 195, sounds like it
should be fine with the 496. When I called my local FSDO, they stressed
that each FSDO was different in their point of view. I may take a look
around for a local avionics shop since In know my local FSDO is mostly
OK with it.
Marco
Why not a hinged panel? Jay Honeck Owning 22 March 8th 05 12:15 AM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 03:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 04:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 04:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 05:41 PM
