Green Arc Red Zone
Old December 26th 06, 05:45 AM posted to rec.aviation.piloting
BT
Default Green Arc Red Zone
it is constant speed props on the Arrow and Cardinal..
and there is still a harmonic vibration range
BT
"Morgans" wrote in message
"Dudley Henriques" wrote
The Lockheed Electra sure could have used a prop AD for this one!
So there was a RPM restriction on the Electra?
What do you recall? Didn't a constant speed prop pretty much bypass it?
Jim in NC
Old December 26th 06, 06:10 AM posted to rec.aviation.piloting
Morgans[_5_]
I only have a vague recall on this. It came up during a safety meeting at
the Naval Test Pilots School many years ago.
If I remember right, it involved a harmonic mode (whirl I believe) not
transmitting correctly through the outboard engine mounts on the airplane.
They specified certain conditions that caused this to happen but I don't
remember what they were. I seem to recall that after the issue was
addressed by Lockheed and the mounts were redesigned, there was a further
wing issue as well that had to be dealt with.
Yeah, I remember that coming up once before, now that the whirl mode is
mentioned. I don't recall the details, either.
Jim in NC
Old December 26th 06, 06:12 AM posted to rec.aviation.piloting
Jim Macklin
Thanks, but I'm not really an expert on the Electra. But I
also read that they harmonic was such that a whirl-mode
began [as you also said] and this caused several complete
airframe failures.
The NTSB probably has a file.
this one!
much bypass it?
| Jim in NC
safety meeting at
believe) not
on the airplane.
happen but I don't
issue was addressed
further wing issue
| I think Macklin will probably be the guy who can best deal
with exactly what
| was going on.
| Dudley Henriques
Old December 26th 06, 06:37 AM posted to rec.aviation.piloting
Jim Macklin
Google found this
http://www.cs.clemson.edu/~steve/Spiro/electra1.html
this one!
much bypass it?
| Jim in NC
safety meeting at
believe) not
on the airplane.
happen but I don't
issue was addressed
further wing issue
with exactly what
| was going on.
| Dudley Henriques
Old December 26th 06, 07:11 AM posted to rec.aviation.piloting
Morgans[_5_]
Google found this
And here is part 2.
http://www.cs.clemson.edu/~steve/Spiro/electra2.html
Jim in NC
Old December 26th 06, 07:22 AM posted to rec.aviation.piloting
Peter Dohm
"Jim Macklin" wrote in message
Google found this
The second page of the above story is located at:
(The link embedded at the end of the first page is obsolete)
Peter
this one!
much bypass it?
| Jim in NC
safety meeting at
believe) not
on the airplane.
happen but I don't
issue was addressed
further wing issue
with exactly what
| was going on.
| Dudley Henriques
Old December 26th 06, 01:07 PM posted to rec.aviation.piloting
Jim Macklin
I saw part two is linked at the bottom of the page, so
didn't bother to put both there.
Didn't know the link was bad when I posted. Thanks.
What did you think of the article? It seems to be a an
aviation history students
paper.
| Google found this
| And here is part 2.
| Jim in NC
Old December 26th 06, 02:27 PM posted to rec.aviation.piloting
Bob Moore
The Electra (L-188) engine (Allison) always turned at 1061 RPM except at
ground idle. It had no Prop Control.
Bob Moore
ATP L-188
Combat Aircrew Commander P-3B
Old December 26th 06, 06:50 PM posted to rec.aviation.piloting
Morgans[_5_]
paper.
Perhaps more like a journalist student who is interested in aviation. I
noticed the poetic license, and the big buzz words, like "tube of death."
Some technical items not quite right, but if this is a journalist, it is
better accident reporting, than most! g
Jim in NC
Old December 26th 06, 06:53 PM posted to rec.aviation.piloting
Morgans[_5_]
"Bob Moore" wrote in message
46.128...
So, fixing the mounts and stiffening the wings was the only thing that was
changed; no different operating procedures?
Jim in NC
Verdant green... Jay Honeck Piloting 17 July 9th 06 07:58 AM
Military Green Laser Pointer [email protected] Naval Aviation 0 July 5th 05 07:42 PM
Simple Green Pirep JJS Owning 13 May 19th 05 04:35 AM
I am in The Killing Zone Marco Rispoli Piloting 68 June 14th 04 06:16 PM
Garmin gpsmap 76s airspace zone home made maps (follow up) Gilles_Sauvagnat Soaring 0 May 13th 04 09:41 PM
