On Thu, 4 Jan 2007 23:10:53 -0800, "Aluckyguess" wrote:
"Ron Rosenfeld" wrote in message .. . On Wed, 3 Jan 2007 14:13:28 -0800, "Aluckyguess" wrote: I have a Bonanza V35 with a IO 470. Before and after engine overhaul the oil pressure after the engine warms up goes just into the red. They have tried turning the pressure up but this seems to only make the pressure go up when cold. If the temperature outside is real cool the pressure goes over 200 psi. The engine builder said its in spec. I think there is a problem somewhere. I want the oil pressure to run in the green. Does anybody have any ideas on what could be causing this. I'm afraid its going to blow the gage out one cold morning. Thanks When this was happening to my Lycoming IO360A1A, the problem turned out to be a leaking nose bearing. Oil temperatures were also running high. It was diagnosed by measuring differential pressures between the front and rear of the case. --ron Was it leaking back into the engine or on to the ground.? There was no oil leaking to the ground. But I'd be surprised if the problem, in your case, survived an overhaul. I suppose it could've happened, but ... --ron |
So...about that plane on the treadmill... | Ray | Piloting | 135 | December 18th 06 10:30 PM |
Jet engines vs. leaf blowers | 01-- Zero One | Soaring | 6 | September 8th 05 01:59 AM |
High Oil Pressure (was: Low oil pressure, high oil temp?) | Thomas Ploch | Owning | 4 | October 5th 04 04:34 AM |
Why are TE probes so long? | Duane Eisenbeiss | Soaring | 36 | May 9th 04 06:58 AM |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
