Pitot heat element failed. Options?
Old January 11th 07, 01:40 PM posted to rec.aviation.owning
Peter R.
Default Pitot heat element failed. Options?
Just this past week my Bonanza V35's pitot heat element failed. I had a
mechanic look at it to determine if the cause was power/wiring related or
if the element itself had failed.
Of course, it was the element itself that had failed, which apparently in
the Bonanza's case means a new pitot tube.
New pitot tubes are over US$1000, or at least that was the first quote I
received. Are there used aircraft parts, or boneyards, that might carry
these? If so, who are reputable groups here in the US?
Peter
Old January 11th 07, 07:38 PM posted to rec.aviation.owning
mikem
Peter R. wrote:
... Are there used aircraft parts, or boneyards, that might carry
these?
Try Wentworth for starters.
I own Cessnas and a Piper . I'm a member of Cessna Pilot's Assoc. and
Short Wing Piper Club. Both organizations maintain lists of used parts
dealers. Join your Type Club.
Old January 11th 07, 10:28 PM posted to rec.aviation.owning
Michael[_1_]
If you are going to observe the legalities, it sure does. I might or
might not know of several Bonanzas flying with rebuilt pitot tubes...
Take any old copy of Trade-A-Plane, flip through it, and you will find
plenty. Just start calling around. You would be amazed how many odd
parts they will have.
Michael
Old January 11th 07, 10:38 PM posted to rec.aviation.owning
Newps
No legal reason you have to buy a new pitot tube.
Old January 12th 07, 07:19 AM posted to rec.aviation.owning
Roger[_4_]
On 11 Jan 2007 11:38:58 -0800, "mikem" wrote:
these?
Try http://www.bonanza.org/
It's a good group for Bonanza owners.
www.rogerhalstead.com
Old January 12th 07, 03:04 PM posted to rec.aviation.owning
Marco Leon
Peter,
My heating element went south on my Piper pitot tube. Apparently there
were two heating elements in there and I was able to purchase them
separately. You may want to explore the option of purchasing just the
heating elements.
Marco
Old January 12th 07, 04:34 PM posted to rec.aviation.owning
Peter R.
heating elements.
Thanks, Marco, but in the Bonanza's case, the heating element and the tube
are one unit.
I contacted American Bonanza Society and they have given me some contacts
to explore. Of course the issue is time, since I am flying a lot this
winter in the Northeast US I have to have the Pitot heat back working
relatively quickly.
Peter
Old January 12th 07, 08:06 PM posted to rec.aviation.owning
Marco Leon
are one unit.
relatively quickly.
Yes, these clouds up here are no joke. Good luck with finding it for
less than 1 AMU. I wonder if it's economically feasible to buy off eBay
and get it yellow-tagged? Here's one (not sure if it's your model) from
a guy parting out some Bonanzas: Item number: 320069500778
Marco
Old January 16th 07, 12:13 AM posted to rec.aviation.owning
Michael[_1_]
It is certainly feasible - provided you have the right mechanic. A
yellow tag is not magic - it's not even necessarily yellow. It is
documentation of a condition/operational inspection and certifies that
the part is serviceable. For a pitot tube, that would mean:
External inspection - not cracked, bent, etc.
Internal inspection - pitot tube not plugged, drain hole (if one
exists) not plugged, static port (if one exists) not plugged, no leaks,
electrical connections not frayed, plug or terminals in good condition
Electrical inspection - not shorted or open or intermittent, draws a
reasonable amount of current (less than the fuse/breaker is rated for,
enough to get hot quickly)
At most, I might need an hour to do all this, including the paperwork
(and I'm slow). I charge $45/hr for stuff like this. I would be
surprised if you had to pay more than about $300 for used pitot tube -
more likely a lot less. There are lots out there.
Taking parts off a totaled airplane and installing them on a working
plane is standard, accepted maintenance practice. Fact is, you don't
even need a yellow tag. All that has to happen is your mechanic does
the above tests, then makes an entry in your logbook to that effect
(noting which plane the part came from, to establish traceability).
Then he installs it, logs the installation - and you are good to go.
What you can't (legally) do is repair one - because you have no
acceptable data on which to base the repair. Not that it doesn't
happen, mind you.
Michael
Pitot Heat Failure in a Piper Marco Leon Owning 10 February 9th 06 01:35 AM
28 volt pitot heat B2431 Home Built 15 April 17th 04 03:25 PM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
Pitot heat Paul Mennen Owning 10 November 6th 03 09:54 AM
Pitot heat Paul Mennen Piloting 10 November 6th 03 09:54 AM
