#11
![]() On Jan 28, 5:14 pm, Mxsmanic wrote: Neil Gould writes: I don't think that's possible. There is no provision for the display system to reboot the hardware; that just isn't done via software, or even by physical switches located on the display unit(s). The display unit(s) can't turn on or off the individual modules either, so a software glitch of any kind -- or even total failure of the display -- isn't able to be the cause of a system-wide reboot.Virtually any bug can cause a reboot. Anything that produces a hardware exception can cause a reboot if it is unexpected, particularly if the system is doing privileged work at the time. A reboot is the typical response to any unhandled exception. The alternative is to let the system run hither and yon uncontrolled through the code, which is even worse than a reboot in most cases. Of course, in safety-of-life applications, there must not be any unexpected exceptions; if there are, it's a flaw in the design. Unfortunately, people from PC-land tend to take the system down whenever there's a spot in the code that they don't want to design or analyze in detail. A reboot of an individual display would not surprise me (although I've never seen it happen). A reboot of both would surprise me. However, NW_pilot's issue was a software bug associated with the long range tanks that were installed. I guess the computer failed working out the fuel calculations. Since both sides run the same software, both sides probably had the same fault. -Robert, CFII, FITS TAA instructor. |
Robert M. Gary writes:
Although many of the components of the G1000 have backups, many do not. There are a lot of failures you can have that don't effect the operation, but some do. Part of the transition training (especially for IFR pilots) is to understand the failure mode of the different components. Sadly, we're finding that we are only able to sign off most of our instrument pilots for VFR in the G1000. The biggest problem is getting behind the plane and not getting the approach set up in the system soon enough. This is mostly the older guys though. I dont' think anyone under 40 has had a problem. Why is it sad? You can still sign them off in an aircraft with more traditional gauges at a much lower cost, and without the risk of a software bug putting them in mortal danger. You can't really teach them the failure modes of the system completely, anyway, since even the manufacturer hasn't bothered to figure that out (which is one of the risks of these systems). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Robert M. Gary posted:
Neil Gould writes: I don't think that's possible. There is no provision for the display system to reboot the hardware; that just isn't done via software, or even by physical switches located on the display unit(s). The display unit(s) can't turn on or off the individual modules either, so a software glitch of any kind -- or even total failure of the display -- isn't able to be the cause of a system-wide reboot. A reboot of an individual display would not surprise me (although I've never seen it happen). A reboot of both would surprise me. Do you mean a display failure rather than a reboot? Anyway, as I understand it, there is no facility for the display to reboot the individual computers However, NW_pilot's issue was a software bug associated with the long range tanks that were installed. I guess the computer failed working out the fuel calculations. Since both sides run the same software, both sides probably had the same fault. That is my guess as well, based on the information from the seminar. As I understand it, the G1000 would disable (red "X") the readout of any component with an unresolvable conflict. Since the aux tank was "refilling" the main fuel tanks via the overflow return, it wouldn't be long before the flight computer data would be in conflict with the fuel level sensor and therefore generate an unresolvable error. It should be expected that both displays would show the same error condition. Neil |
On 29 Jan 2007 10:23:49 -0800, "Robert M. Gary"
wrote: A reboot of an individual display would not surprise me (although I've never seen it happen). A reboot of both would surprise me. However, NW_pilot's issue was a software bug associated with the long range tanks that were installed. I guess the computer failed working out the fuel calculations. Since both sides run the same software, both sides probably had the same fault. -Robert, CFII, FITS TAA instructor. If it was a software problem with handling the long range tank, don't you think it would have shown up in some other flight than his? It's not like he's the first to take ferry tanks and a G1000 equipped aircraft across the pond. The fuel indication system in the Cessna 172 G1000 is a plastic float attached to an arm which controls a rheostat and produces a variable resistance. The resistance is measured, from a high-ohm to a low-ohm limit (+-5ohm if I remember correctly) by the GEA and translated into a pointer on the display. It's not computed, it's not analyzed, it's not even compared with time-to-empty, fuel-flow, etc etc etc. In fact, the standard full-tanks is about 1hr flight above where the float starts generating something other than the signal "full" and the system doesn't reboot due to it. We've replaced many floats in my aircraft (they have a tendency to red X when the tanks are full until a couple of gallons are burned down) and not once was a red X for extended periods of time responsible for a system rebooting. In fact, I've never seen or heard of a system rebooting to "initializing system" outside of the one sample. The three shops I deal with for avionics, who are Cessna service centers and Garmin dealers, haven't seen this either. |
On Mon, 29 Jan 2007 21:17:47 GMT, "Neil Gould"
wrote: That is my guess as well, based on the information from the seminar. As I understand it, the G1000 would disable (red "X") the readout of any component with an unresolvable conflict. Since the aux tank was "refilling" the main fuel tanks via the overflow return, it wouldn't be long before the flight computer data would be in conflict with the fuel level sensor and therefore generate an unresolvable error. It should be expected that both displays would show the same error condition. I guess that would be based on the invalid presumption that the fuel computer, time to empty, fuel flow, etc have any interaction with the fuel level indicators. They don't. You tell the time-to-empty computer how much fuel is onboard and it deducts based on current fuel flow. If you don't refresh it's fuel on board at the beginning of a flight you can get 0:00 minutes to empty with hours worth of fuel left in the tanks. |
Recently, Peter Clark posted:
On Mon, 29 Jan 2007 21:17:47 GMT, "Neil Gould" wrote: That is my guess as well, based on the information from the seminar. As I understand it, the G1000 would disable (red "X") the readout of any component with an unresolvable conflict. Since the aux tank was "refilling" the main fuel tanks via the overflow return, it wouldn't be long before the flight computer data would be in conflict with the fuel level sensor and therefore generate an unresolvable error. It should be expected that both displays would show the same error condition. I guess that would be based on the invalid presumption that the fuel computer, time to empty, fuel flow, etc have any interaction with the fuel level indicators. Yes, that would be it. ;-) They don't. Thanks for the clarification, as it is not the answer that I got to the question I asked about it. But, as you apparently own one and have observed this condition, your knowledge resolves the conflict. ;-) So, what happens if the fuel level indicators report "full" after a few of hours of flying, which could be the case in NW_Pilot's ferrying scenario? Might the GEA presume that they weren't working, and "X" it out on the display? Neil |
On Mon, 29 Jan 2007 17:50:21 -0600, "Neil Gould"
wrote: Thanks for the clarification, as it is not the answer that I got to the question I asked about it. But, as you apparently own one and have observed this condition, your knowledge resolves the conflict. ;-) No worries. So, what happens if the fuel level indicators report "full" after a few of hours of flying, which could be the case in NW_Pilot's ferrying scenario? Might the GEA presume that they weren't working, and "X" it out on the display? I can't say with absolute certainty as I don't have access to the code directly, but in my experience the GEA happily continues on showing the pointer at F. It doesn't appear to process the data coming in beyond saying "input ohm x, display level y". The first issue NW experienced (Xing the level) was likely similar to issues we've had when the float produces an out-of-range resistance. They seem to do that routinely when the tanks are topped off to the point of fuel coming out of the filler cap when opened and will function fine when the fuel level goes down a bit. I've seen over 2 hours of an X'd fuel gauge due to tippy-topped tanks, 182, and uneven burn keeping one tank high. I even asked at the factory last time I picked one up about the ferry account and they hadn't heard about it. I still think the most likely culprit in his account was the third-party non-integrated (XM? CD?) player hacked into the system. As I mentioned in another post, it's not like these things haven't been ferried routinely since 2004, and the lack of field issues like this in all the aircraft makes and models with G1000 equipment IMO just doesn't support the assertions that this is some kind of inherent design defect. |
On Mon, 29 Jan 2007 17:50:21 -0600, "Neil Gould" wrote: So, what happens if the fuel level indicators report "full" after a few of hours of flying, which could be the case in NW_Pilot's ferrying scenario? Might the GEA presume that they weren't working, and "X" it out on the display? I can't say with absolute certainty as I don't have access to the code directly, but in my experience the GEA happily continues on showing the pointer at F. It doesn't appear to process the data coming in beyond saying "input ohm x, display level y". I suppose that's what one could expect if there is no interaction between the readout and any other engine information. The first issue NW experienced (Xing the level) was likely similar to issues we've had when the float produces an out-of-range resistance. They seem to do that routinely when the tanks are topped off to the point of fuel coming out of the filler cap when opened and will function fine when the fuel level goes down a bit. I've seen over 2 hours of an X'd fuel gauge due to tippy-topped tanks, 182, and uneven burn keeping one tank high. I even asked at the factory last time I picked one up about the ferry account and they hadn't heard about it. That anomaly was mentioned in the seminar, and could explain NW's observations because the tanks would be "over full" if fuel was venting in-flight. I still think the most likely culprit in his account was the third-party non-integrated (XM? CD?) player hacked into the system. I agree that the reboot problem was most likely something related to the third-party panel mods. As I mentioned in another post, it's not like these things haven't been ferried routinely since 2004, and the lack of field issues like this in all the aircraft makes and models with G1000 equipment IMO just doesn't support the assertions that this is some kind of inherent design defect. Again, I agree. Overall, the system would seem unlikely to reboot in the way NW experienced. Neil |
On Jan 29, 1:53 pm, Peter Clark
wrote: On Mon, 29 Jan 2007 21:17:47 GMT, "Neil Gould" wrote: That is my guess as well, based on the information from the seminar. As I understand it, the G1000 would disable (red "X") the readout of any component with an unresolvable conflict. Since the aux tank was "refilling" the main fuel tanks via the overflow return, it wouldn't be long before the flight computer data would be in conflict with the fuel level sensor and therefore generate an unresolvable error. It should be expected that both displays would show the same error condition. I guess that would be based on the invalid presumption that the fuel computer, time to empty, fuel flow, etc have any interaction with the fuel level indicators. They don't. You tell the time-to-empty computer how much fuel is onboard and it deducts based on current fuel flow. If you don't refresh it's fuel on board at the beginning of a flight you can get 0:00 minutes to empty with hours worth of fuel left in the tanks. From the pilot's point of view that's true. However, a fault in the GEA 71 system could cause the entire thing to get sick. Your argument is a bit like saying Word could never hang because of a fault in IE. Ideally, yea, practically, maybe not. -Robert, CFII G1000 instructor |
On Jan 29, 11:05 am, Mxsmanic wrote:
Robert M. Gary writes: Although many of the components of the G1000 have backups, many do not. There are a lot of failures you can have that don't effect the operation, but some do. Part of the transition training (especially for IFR pilots) is to understand the failure mode of the different components. Sadly, we're finding that we are only able to sign off most of our instrument pilots for VFR in the G1000. The biggest problem is getting behind the plane and not getting the approach set up in the system soon enough. This is mostly the older guys though. I dont' think anyone under 40 has had a problem. Why is it sad? You can still sign them off in an aircraft with more traditional gauges at a much lower cost, and without the risk of a software bug putting them in mortal danger. I feel *WAY* safer in the G1000 system than the steam gauges. Look at how often an attitude indicator goes out in the steam gauges. I for one would not welcome having to shoot an actual ILS on the TC. Everyone has heard the 1 or 2 stores of hard failures in the G1000 but most of us have personally had hard failures of an attitude indicator, a TC, an airspeed indicator, etc. Besides, even if the entire G1000 system went TU, you are left with you basic 3 steam gauges anyway, no worse than in an old plane. You can't really teach them the failure modes of the system completely, anyway, since even the manufacturer hasn't bothered to figure that out (which is one of the risks of these systems). While I'm sure you can come up with some strange "this happened to my brother-in-law" stories, Garmin clearly documents what each LRU is responsible for and disabling any LRU gives a predictable set of failures. I've had a few actual failures in the G1000, none were very interesting, and none as bad as what I've had happen in steam gauges. -Robert |
G1000 vs Steam guages initial thoughts... | [email protected] | Instrument Flight Rules | 48 | September 12th 06 12:33 AM |
IPC G1000 | [email protected] | Instrument Flight Rules | 38 | September 3rd 06 12:22 AM |
G1000 question | Robert M. Gary | Piloting | 0 | May 1st 06 10:36 PM |
G1000 trainer simulator problems | akiley | Simulators | 2 | March 25th 06 07:54 PM |
G1000 Check out | Michelle | Piloting | 105 | January 7th 06 04:33 AM |
