Balloons
Old February 5th 07, 09:06 AM posted to rec.aviation.piloting
G. Sylvester
Default Balloons
I had another close encounter with a (party / decoration-type) balloon.
I was flying back to SQL with 3 passengers in an Archer at 2500
AGL/MSL when out of the corner of my eye this black thing flew (no pun
intended) by. I asked a passenger what it was and they said it was a
balloon. I think this is the 3rd or 4th time out of ~250 hours that
I've been very close (less than 100 feet) to a balloon. One of the
times it was at 10,500 feet over Los Angeles. Any else see balloons all
the time? I'm guessing they can't do too much damage unless they go
into the engine air inlets or hit the ADF antenna. Now that would be
bad luck.
At least birds stay out of the way....unfortunately not all of the time.
Gerald
Old February 5th 07, 12:24 PM posted to rec.aviation.piloting
Judah
Default Balloons
"G. Sylvester" wrote in news:ksCxh.52308
bad luck.
In 500 or so hours, I've seen at least 4 or 5 Mylar Baloons at altitude
(although I don't think at 10,000'). So you are about right.
Old February 5th 07, 01:00 PM posted to rec.aviation.piloting
Jay Honeck
Default Balloons
Must be a Left Coast thing. I can't say that I've seen more than one
or two party balloons in the 1600 or so hours Mary and I have been
airborne...
I've seen quite a few R/C planes, but only when we flew over their
local airfield.
And we saw a humongous rocket, once. (It was NOTAM'd, and ATC warned
us about them...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 5th 07, 01:47 PM posted to rec.aviation.piloting
Jim[_11_]
Default Balloons
I remember seeing balloons on two separate occasions and hearing a balloon
report to Center on one other occasion. The last was a report from
commercial traffic inbound to ORD reporting the balloons up around 12,000ft.
Center nonchalantly acknowledged and the pilot clarified: "No, I don't mean
these are just some little party balloons, these are BIG, like from a mall
grand opening or a car lot!" This brought an immediate broadcast advisory
from Center about the location and altitude.
(slayer of 2 birds, 0 balloons)
"G. Sylvester" wrote in message
. net...
bad luck.
Gerald
Old February 5th 07, 02:36 PM posted to rec.aviation.piloting
G. Sylvester
Default Balloons
airborne...
no reference the Larry the Lawnchair Man? There was a radio call from a
now defunkt airline (Eastern?) that checked in with SoCal Center
"Airline XXX, one four thousand, at my 3 o'clock and 5 mile there
appears to be a man in a chair attached to a bunch of weather balloons."
IIRC, Larry got fined $200 for no transponder. These days the guy
would get shot down and then nailed for about 20 offenses including jail
time. then again, his lawnchair weighed as much as a 152. ;-)
us about them...)
I really wish I flew down by Edwards to see SpaceShipOne go off. Their
next flight, I am definitely flying.
Gerald
Old February 5th 07, 03:34 PM posted to rec.aviation.piloting
Brad[_1_]
Default Balloons
bad luck.
Gerald
Flying low level traffic reporting, I've seen probably 6 or 7 party
balloon in a thousand hours. When solo, it was an opportunity to
dogfight...and surprisingly difficult to intercept.
....and before someone says it...no, the string is not going to wrap
around prop hub and seize the engine.
Old February 5th 07, 03:42 PM posted to rec.aviation.piloting
Gary[_2_]
Default Balloons
us about them...)
Jay Honeck
I've not seen a high-power model rocket from the air, but I do belong
to a club that actively flies them. We generally get an FAA waiver
for rocket flight to 12,000 feet one weekend a month (and the NOTAMS
do issue, I've had to fly around the launches several times myself).
The NOTAMS seem to have the unfortunate effect of bringing in curious
pilots. We spend a lot of time waiting for over-curious light planes
circling the launch to leave, so we can fly. It is sometimes a sore
spot, as the larger rocket projects generally have electronics with
finite battery life on board (altimeters, minimally, but often GPS,
still or video cameras, etc), the launch window is of limited
duration, and we have other fliers waiting for their turn at the
pads.
I add this here as a plea for pilots to not circle the NOTAM'd launch
area waiting to see something go up. If a plane is nearby, the
rockets don't fly. A 'typical' high-power model rocket might be 3 to
8 feet long, weigh 3 to 20 lbs, and hit a top speed of 300-400 mph on
it's way to apogee at 2000-3000' agl... Serious enough, but the
heaviest projects can weigh several hundred pounds, the fastest
rockets can top mach 2 (getting past mach 1 is a rite of passage for
many rocketeers, so someone is sure to have a supersonic project at
any launch), and the high fliers will hit at least a mile AGL, and
often two or three miles. The high-power model rocket altitude
record is about 37,000 feet, and a couple of years ago an experimental
amateur rocket (they operate under different regulations than the
model rocket crowd) finally crossed the 50 NM threshold which
typically defines 'space'. To minimize drift, the rockets usually
recover with only a very small drogue chute deployed (hard to see)
until they are perhaps 500-1000'AGL, when the main chute deploys.
These launches are a lot of fun to watch from the ground. Check out:
http://www.nar.org/ or http://www.tripoli.org/ for more information.
If you're in the Northeast, my club is: http://
www.metrarocketclub.org/
Gary
Old February 5th 07, 04:24 PM posted to rec.aviation.piloting
Judah
Default Balloons
Maybe... They sell A LOT of Mylar balloons here in NY. They even sell them
at the local Pharmacy!
I don't think we're called Yuppies anymore, but the modern-day equivalent
of Yuppies don't like to bring anything home to the kids that doesn't last
a few days... I doubt there will be much Mylar out there today in this half
of the country. It's on the too-cold side of the icing curve out there!
Besides, who has parties anymore?
I saw an RC planes from the air only once that I can recall. It was big
enough, high enough, and close enough to the field that I thought it was in
the pattern.
Can't say I've seen any rockets from the air. I see 'em on TV sometimes,
but they are usually in Florida or Houston or something.
"Jay Honeck" wrote in news:1170680414.893628.128670
@q2g2000cwa.googlegroups.com:
airborne...
local airfield.
us about them...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 5th 07, 04:51 PM posted to rec.aviation.piloting
Stubby
Default Balloons
I was flying back to SQL with 3 passengers in an Archer at 2500 AGL/MSL
when out of the corner of my eye this black thing flew (no pun intended)
by. I asked a passenger what it was and they said it was a balloon. I
think this is the 3rd or 4th time out of ~250 hours that I've been very
close (less than 100 feet) to a balloon. One of the times it was at
10,500 feet over Los Angeles. Any else see balloons all the time? I'm
guessing they can't do too much damage unless they go into the engine
air inlets or hit the ADF antenna. Now that would be bad luck.
Balloons are aircraft, just the same as airplanes. They should be
talking to local ATC towers etc, and getting winds aloft from FSS.
Typically, flights are just above tree tops for a good view, seeing the
deer, finding calm areas for landing, etc. But LTA craft need to be
exceedingly careful about power lines.
In Eastern MA and Southern NH it is not unusual to see a half dozen
balloons in the air just after sunrise. Landing in the afternoon is
possible but there is diminishing light making power lines hard to see,
landing spots are harder to pick, winds can be difficult and of course,
fuel will be low. Then, having landed you can have a hard time locating
all your equipment such as gloves, shrouds, etc in the dark.
The ballooning community is very active here. I suspect everywhere, in
fact. Take a look at some of the ballooning web sites and you will
locate where the local groups launch. Start hanging around with them.
Pitch in and maybe you will earn a free flight (take awhile!).
Old February 5th 07, 04:55 PM posted to rec.aviation.piloting
John Clear
Default Balloons
I've passed bunches of ~10 balloons several times over San Jose at
3500ft or so. From the size of the clusters, I'd blame the car
dealerships for them, since they seem to be the ones that use
balloons in their advertising the most.
It is a real "whoa, what was that?" moment when the balloons streak
past you at 120kts.
John
John Clear - http://www.clear-prop.org/
Cell service from balloons legal in the cockpit? Rob Piloting 7 February 2nd 06 03:53 AM
Balloons Airships vintage book FA [email protected] General Aviation 0 July 16th 05 01:12 AM
Balloons maybe a new glider launch method NOT Mal Soaring 4 December 14th 04 05:19 AM
I need materials to make helium balloons. John Doe Home Built 19 December 7th 04 05:51 AM
Questions about hot air balloons L. Hines Owning 9 February 1st 04 05:31 AM
