Fuel pressure Problems
Old September 7th 03, 04:17 AM
smf
Default Fuel pressure Problems
Problem: Glasair with I-0 360. With Vision Microsystem fuel pressure guage
and sensor.
My fuel pressure fluctuates from 23lbs down to about 10lbs and then back up
then to 16lbs and then maybe up to 23 for 15 minutes and then starts again.
If I turn the boost pump on it stays up to 23lbs.
I can let it go down to 10lbs or so in cruise but the engine doesn't miss or
quit.
I changed the Mech. fuel pump. It still does the same thing.
Could the pulse of the mech fuel pump be affecting the sensor?
Any Ideas or experience with this problem???
thanks
Steve
Old September 7th 03, 05:44 AM
Barnyard BOb --
and sensor.
quit.
thanks
Steve
No experience here.
If the engine runs fine - bad electrical ground someplace?
Is 23 psi even acceptable.... by the book.
Barnyard BOb --
Old September 7th 03, 02:30 PM
smf
The book shows Inlet to Fuel Injector is 45max - 14 min.
Steve
Barnyard BOb --
Old September 7th 03, 08:25 PM
Orval Fairbairn
and sensor.
quit.
thanks
Steve
It sounds as if you have incipient vapor lock. Check your fuel system
for:
€ 90 deg. bends in the engine compartment
€ fuel line too close to exhaust pipes
€ engine cooling exit air flowing over fuel lines
€ gascolator mounted high on the firewall
€ heat sources blowing on the gascolator
€ malfunctioning pressure transducer
€ You may have to route a coolong vent over the gascolator
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 12:08 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
