Low fuel emergency in DFW
Old February 22nd 07, 05:37 AM posted to rec.aviation.piloting
Mike Schumann
Default Low fuel emergency in DFW
The controller made an interesting suggestion that if the aircraft was
really that low on fuel he should divert to a closer airport. I would
suggest that it would be wise to get the full info before jumping to
conclussions.
Obviously one major question is where the aircraft was when the pilot
declared a fuel emergency. Once you declare an emergency, particularly if
you suspect a fuel leak, I would think you should land at the closest
available field. It is certainly conceivable that the pilot didn't want the
hassle of making an unscheduled landing, and was trying to streach it to get
to DFW.
Mike Schumann
nk.net...
"Tony" wrote in message
ps.com...
Did anyone see the news about an AA (maybe 777) airplane declaring a
fuel emergency in DFW, requesting a downwind landing to I think 17
Center, and being told no, had to circle to land on 31 R?
I'm not exactly sure of those details, but it's close enough. It's
that old deal, when a pilot makes a mistake, the pilot dies, and when
a controller makes a mistake, the pilot dies. Turns out the airplane
had enough fuel to circle and land, butr damn it, heads should roll,
or at least jobs lost.
I hope the next time such an event happens the PIC TELLS the
Controller p@ic@ he is landing on 17 Center, rather than request it.
As it happens DFW was using 35 C runway for departures, and I gather
it would have been 'inconvenient' to make a suitable hole.
We should OWN the sky when we declare an emergency, and sort out the
details once the event is over, dammit!
I saw the report on ABC news. I agree completely, heads should roll. The
reporter said, I believe, that there was disagreement on who denied the
requested runway, the controller or the supervisor. Regardless, I think
both heads should roll.
Posted via a free Usenet account from http://www.teranews.com
Old February 22nd 07, 10:32 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Mike Schumann" wrote in message
conclussions.
the hassle of making an unscheduled landing, and was trying to streach it
to get to DFW.
I didn't jump to any conclusions. The pilot said he had an emergency, and
that he needed 17C at DFW. He was denied.
Old February 22nd 07, 10:57 AM posted to rec.aviation.piloting
Mxsmanic
Steven P. McNicoll writes:
Once you've declared an emergency, denial is moot. ATC's only responsibility
is to keep other people out of your way.
Old February 22nd 07, 12:37 PM posted to rec.aviation.piloting
Jim Macklin
How many "outraged" posters have ever flown into DFW as a
pilot? For ATC to turn the airport around takes about half
an hour, even if all they do is tell all the other airplanes
to go away. ATC did fit the "emergency" into the traffic,
which seems to be the better solution.
message
nk.net...
in message
the aircraft was
airport. I would
before jumping to
| conclussions.
when the pilot
at the closest
pilot didn't want
| to get to DFW.
an emergency, and
Old February 22nd 07, 02:56 PM posted to rec.aviation.piloting
Dylan Smith
to go away.
I'm sure if this had resulted in (a non-fiery, given the lack of fuel)
crash, this would really have comforted the crew and passengers on that
plane.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old February 22nd 07, 04:42 PM posted to rec.aviation.piloting
Morgans[_2_]
It would not have a been a "better solution" if he had run out of fuel
while maneuvering, and killed a few hundred people.
Deciding that an emergency is not all that urgent is not the controller's
right. He should have given the clearance requested, then later the
situation should be toughly investigated and the pilot reamed, if it was not
a true emergency, or if it was, then perhaps a different kind of reaming.
Jim in NC
Old February 22nd 07, 08:20 PM posted to rec.aviation.piloting
Mxsmanic
Morgans writes:
right. He should have given the clearance requested ...
A pilot in an emergency doesn't need a clearance; he only needs to state his
intentions.
Old February 23rd 07, 05:07 AM posted to rec.aviation.piloting
Mike Young
"Morgans" wrote in message
not a true emergency, or if it was, then perhaps a different kind of
reaming.
"Might I suggest a closer airport?" seems to sum it up.
If it were strictly a fuel emergency, diverting to take on fuel would solve
the problem completely without upsetting the whole sector. The real issue
was one pilot willing to maintain his route and schedule at the expense of
everyone else in the air, including those onboard his own plane. If there's
justice in this world, bury him in paperwork for the duration of his
administrative leave. After a humbly apologetic ASRS, write 100,000,000
times longhand "I will place the safety of others above my own convenience."
We learn and grow from our mistakes. His was such that he should reach 8 ft.
tall by summer.
Frankly, I'm dismayed and more than a little frightened by the shrill tone
that has become common on news broadcasts in the past few years, and the
unthinking echo emanating from the skulls they seem to penetrate so easily.
Old February 23rd 07, 10:51 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Mike Young" wrote in message
solve the problem completely without upsetting the whole sector. The real
issue was one pilot willing to maintain his route and schedule at the
expense of everyone else in the air, including those onboard his own
plane. If there's justice in this world, bury him in paperwork for the
duration of his administrative leave. After a humbly apologetic ASRS,
write 100,000,000 times longhand "I will place the safety of others above
my own convenience." We learn and grow from our mistakes. His was such
that he should reach 8 ft. tall by summer.
easily.
If ATC does not grant a pilot's request in an emergency and the flight does
not then land uneventfully, who will be held responsible?
Old February 23rd 07, 11:27 AM posted to rec.aviation.piloting
Tony
This may not be the best place in the thread to put this, however,
here we go. This, from Fox News, makes it clear ATC is saying they
screwed up. The time to beat up on the pilot is AFTER the airplane is
on the ground. "Emergency" does mean the pilot owns the sky, details
and blame will be sorted out later.
DFW Air Traffic Controllers Retrained
Created: Wednesday, 21 Feb 2007, 2:06 PM CST
DFW International Airport FORT WORTH --
Air traffic controllers at Dallas-Fort Worth International Airport
have been retrained after a pilot declared a low-fuel emergency but
wasn't allowed to land on the runway he requested.
The emergency was reported on an Aug. 31 American Airlines flight
between Tulsa and D-FW, according to a report in Wednesday editions of
The Dallas Morning News. The captain asked to land against the flow of
traffic.
"We're not sure if it's a fuel leak or what, but we need to get on
the ground right away, please," the pilot says on audiotapes obtained
by a television station.
A controller supervisor is heard saying that type of landing would
delay other flights. A comptroller suggests the pilot land on a
different runway or possibly go to Dallas Love Field. The pilot
accepted landing with the air traffic, and the flight got on the
ground safely.
"That is not normal," Denny Kelly, a retired Braniff Airways
captain and aviation consultant, said of the air traffic controller's
decision. "That airplane could have run out of fuel, flamed out and
crashed."
The Federal Aviation Administration has retrained D-FW controllers
to clarify handling of such incidents.
"This was a situation where there was confusion about the term
'minimal fuel' and 'fuel emergency,' " FAA spokeswoman Laura Brown
said. "The controller was confused about the distinction. When the
supervisors became aware of the incident afterward, they used the
tapes as an opportunity to retrain everyone in the facility that if a
pilot declares an emergency, he should be allowed to land on the
runway he's requested."
On Feb 23, 5:51 am, "Steven P. McNicoll"
easily.
not then land uneventfully, who will be held responsible?- Hide quoted text -
- Show quoted text -
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
