![]() "Jay Honeck" wrote in message ps.com... I'm incredibly thankful that this happened at home, and not at some little podunk airport in Oklahoma, where we had stopped for lunch next Sunday. Where are you having lunch in Oklahoma? |
"Maxwell" wrote in message
... Where are you having lunch in Oklahoma? My choice would be Durant, and grab a ride to Chucks BBQ. |
![]() "Steve Foley" wrote in message news:AScIh.7993$pi.2627@trndny09... "Maxwell" wrote in message ... Where are you having lunch in Oklahoma? My choice would be Durant, and grab a ride to Chucks BBQ. Indeed. But I was going to recommend Ponca City. Excellent mexican food located right on the field. |
In rec.aviation.owning Jay Honeck wrote:
Anyone know if it's possible for a brake to hang up and not release, resulting in advanced wear like this? Sure. Short answer: Check the flex line (rubber line) on that side. If OK or not so equipped, see below. Long answer: When I got the engine running (for some value of running) in the first car I've owned that's older than me, I of course had to take it around the block. I had reasoned that its manual four-wheel drum brakes would not respond as well as the power-assisted front disc, rear drum brakes did on nearly every other car I had owned or driven. Still, when I got to the stop sign just down the block, I was glad it was one of the optional ones with the white stripe around it, because I got halfway into the intersection before I stopped. When I let off the pedal and tried to accelerate again, the car hesitated for a second, then there was a ping! from one of the front wheels and the hesitation was gone. At first I wondered if I was simply treading too lightly on the brakes, so I got the car back up to 15 mph and literally stood on the pedal. This still produced a rather anemic stop, so I was convinced something was wrong. Again, as I tried to accelerate away, I was held back until I heard the ping! from the front wheel. I carefully returned home to investigate. Online consultation with a group of enthusiasts brought a nearly unanimous answer: The rubber lines in the brake system tend to deteriorate on the inside as well as on the outside. Besides causing a reduced flow of brake fluid and poor braking in general, a flap of rubber will often form inside the line. This flap acts as a check valve: when you stomp on the pedal and bring up the pressure in the system, the fluid is forced past the flap and out to the wheel cylinder or caliper, applying the brake. When you let off the pedal, the shoes or pads are pushing back on the piston to return the fluid to the master cylinder, but this pressure is not as great, and the flap is enough to prevent it from returning. The result is that the brakes on that wheel stay engaged. Eventually enough fluid may get back through to release the brakes on that wheel - probably the ping! that I heard. Many people said they liked to replace the flex hoses immediately on any old car new to them, and then on a schedule of every 5 to 10 years thereafter. After a little further inspection, I decided that although the master cylinder and wheel cylinders were not original to the car, the flex lines probably were. I ordered a new set, and when they arrived, I swapped them out. I did a test on the old lines: with them lying on the ground, not connected to anything, I hooked up my hand vacuum pump to them. It should have been like sucking on a brand new soda straw, but instead it was like sucking on a bottle - I could pull a 25" Hg vacuum from either end of all the hoses. The brakes were probably only working as much as they did because the hydraulic pressure in the system was considerably higher, and could force a little fluid through the old hoses. A road test with the new hoses proved much more satisfying; I could reliably stop at both the optional and the mandatory stop signs. One diagnostic for this problem in a car is to raise the wheels off the ground and make sure they turn freely by hand. Then stomp on the brakes, and make sure that the wheels don't turn. Finally, let off the brakes, and see if the wheels turn freely again. If one of them doesn't, open the bleeder valve on that wheel cylinder or caliper. If you get a spurt of fluid from the valve and the wheel suddenly turns freely, then the problem is probably in the lines or master cylinder. If the wheel is still stuck, then the problem is probably in the wheel cylinder or caliper. An alternative way to see if a brake is dragging lightly is to travel in a straight line for some distance, stop, then compare the temperatures of the wheels from side to side. If you're optimizing for cheap, you can check with a careful hand or wet fingertip. If you're optimizing for shiny, this is a perfect excuse to buy one of those infrared remote thermometers. If you can't travel in a straight line, one of the brakes might be dragging more than lightly, or possibly the vehicle control system is affected by ethanol. I know that an airplane, in general, is not a car. On a Cessna 182, the one airplane that I've been around the most, if you start at the wheels and work in, the system is similar to a car. There is a pad moved by a piston at the wheel. Then, there is some combination of hard line and flex line that goes from the wheel back to the fuselage - the flex line is there to account for relative motion between the wheel/landing gear and the fuselage. Then it's hard line back to the master cylinder. The mechanical linkage to operate the master cylinder is different, but the principle is the same as in a car. It could be that your airplane doesn't have any flex lines in its braking system. In that case, you have to decide whether to go after the wheel cylinder or the master cylinder next. You might be able to swap existing parts from side to side to see if the trouble follows the part or not. Or, tear down the parts from both sides, and play "One Of These Things Is Not Like The Others." Disclaimer: This is based on experience with braking systems on ground vehicles. I don't have an A&P; I don't even have a TG&Y. Some of this may not be allowable owner maintenance. Your mileage may vary. Matt Roberds |
vehicles. I don't have an A&P; I don't even have a TG&Y. Some of this may not be allowable owner maintenance. Your mileage may vary. Thanks, Matt -- I appreciate the brake system primer. I will definitely be checking the flexible lines. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Anyone know if it's possible for a brake to hang up and not release, resulting in advanced wear like this? Or should I keep blaming Mary for riding the (right) brake? No no no...it's "Hail Mary", not "Blame Mary". :-) -- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
Now Jack here is obviously a successfully married man... ;-) Well, the parts arrived from Spruce by 10 AM this morning, and the brakes were fixed by lunch. Atlas is tucked safely back in his hangar, fully fueled and ready to go. All we need now is some nice weather on Sunday. It's 35 degrees and raining, right now -- ain't nuthin' flying around Iowa City... Prog charts show a big chunk of (argh!) thunderstorms moving into Oklahoma and Texas on Sunday morning... :-( -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mar 9, 8:47 pm, "Jay Honeck" wrote:
Prog charts show a big chunk of (argh!) thunderstorms moving into Oklahoma and Texas on Sunday morning... Yep, low ceilings, crappy visibility, possibly rain and thundershowers from west of Wichita Falls all along the Red River all the way to Lake Texoma forecast for most of the day Sunday. MVFR at best, probably actually gonna be IMC though. Might be a better idea to try again Monday. Or if you can, leave Saturday morning. It's supposed to be very clear and almost no winds all day Saturday across the local region here. |
Saturday morning. It's supposed to be very clear and almost no winds all day Saturday across the local region here. Yeah, we'll probably only make it half-way down Sunday anyway...so flying in to Fredericksburg on Monday is no biggie. Can't leave today, dang it. Got a million loose ends to tie before we can leave the hotel for a week... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2007-03-10, Jay Honeck wrote:
Prog charts show a big chunk of (argh!) thunderstorms moving into Oklahoma and Texas on Sunday morning... In my experience of (around 800 or 900 hours of) flying around Texas - prog charts showing possible thunderstorms are not necessarily doom to a trip. My usual strategy was to look again at the radar just before departure, and pick a point where I could stop and re-check the radar to see how it was progressing. Around 70% of the time, the entire trip was a 'go' because the thunderstorms turned out to be very widely scattered. It also depends what the thunderstorms were associated with. Thunderstorms embedded in a front, with low IMC? I'm not going to even bother going to the airport. But basically reasonable VMC conditions, and an area of widely scattered storms? Flight watch, and a stop at a nearby airport to get a full update on the weather would usually prove useful. About half the time, thunderstorms in the prog charts wouldn't even materialise on the day of the trip and it was obvious from just looking out of the window or calling Flight Watch that there was no need to stop. Of course, it's wise to exercise caution if you've no experience flying in the area (because you don't get that gut feel whether they are airplane-eating monsters or easily avoidable airmass storms), and the usual advice to have an 'out' is something that can't be ignored. But isn't it funny that on the day of a trip, all this weather always seems to show up? I've done the Houston to Pinckneyville trip about half a dozen times, and I can predict years in advance that there will be a cold front lined up such that it lies right over the middle of Arkansas on the Friday afternoon just when I'm passing. It's _always_ there on that particular Friday, like a big cosmic meterological taunt! -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Bad timing... | Jay Honeck | Piloting | 39 | March 13th 07 08:19 PM |
timing holds | [email protected] | Instrument Flight Rules | 16 | February 17th 05 12:18 AM |
Approach Timing | john smith | Instrument Flight Rules | 36 | September 9th 04 03:37 PM |
Timing light for electronic ignition | Ron | Home Built | 4 | August 20th 04 05:18 PM |
Timing on Subaru EJ22 ??? | Randy | Rotorcraft | 1 | November 9th 03 06:15 AM |
