Ron Natalie writes:
Sometimes, and yes. What makes them asymmetrical? Spiral is not an oscillation. Spiral is a departure from positive stability when you push things too far. Spiral instability. Absolutely and totally incorrect. It depends on the aircraft, but my generalization is mostly valid. You should go read a introductory pilots book section on flight aerodynamics. That's the problem with pilots' books: they never go past the introduction to these complex topics. Now your an aerodynamics expert? I've never claimed to be an expert. But I do know something about it. Asserting or sharing knowledge is not a claim of expertise. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Ron Natalie writes: Sometimes, and yes. What makes them asymmetrical? Spiral is not an oscillation. Spiral is a departure from positive stability when you push things too far. Spiral instability. Instability is not necessarily an oscillation. You said oscillation. You are wrong Absolutely and totally incorrect. It depends on the aircraft, but my generalization is mostly valid. No it isn't. If you think the control surfaces can't move without either the pilot or the autopilot acting on them, you're daft. It's true in EVERY SINGLE AIRPLANE IN THE WORLD. Have you ever heard of the concept of trim? This is a little aerodynamic device that moves the control surface dynamically to obtain given stable position. Further some airliners don't even have a direct connection between the yoke/autopilot and the control surface. Instead, these are connected to a servo tab that moves the surface by aerodynamic means. You should go read a introductory pilots book section on flight aerodynamics. That's the problem with pilots' books: they never go past the introduction to these complex topics. Yes, but they explain the simple topics you don't seem to begin to understand. |
Commercial 250nm VFR flight - all 3 landings on the same day? | Jim Macklin | Instrument Flight Rules | 39 | December 20th 06 12:11 PM |
Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 09:40 AM |
Looping during a commercial flight | LordAvalon | Aerobatics | 10 | October 23rd 04 04:05 PM |
Nixon on Commercial Flight | Flyin'[email protected] | Piloting | 1 | June 16th 04 05:51 PM |
Flight Unlimited 2 on Windows Xp .- any known problems? | tw | Simulators | 2 | April 25th 04 05:05 PM |
