In flight recorder
Old March 21st 07, 04:58 PM posted to rec.aviation.piloting
Lou
Default In flight recorder
Has anyone ever made their own in-flight recorder? I'm curious how
this would be done. I don't think it would be that difficult if you
use a regular cassette in one of those small fire safes. Just
drill a small hole to accomadate the mic wire. But how would you hook
it up to the intercom?
Or would you have a small lapel mic attatched to your headset? Anyway,
has anyone tried this?
Lou
Old March 21st 07, 06:13 PM posted to rec.aviation.piloting
Gig 601XL Builder
Lou
What possible purpose would you have for it? That's a lot of weight (the
safe) that will be of no use to anyone.
Old March 21st 07, 06:45 PM posted to rec.aviation.piloting
Longworth[_1_]
I did it during my IFR training week. I used a small mp3 player/
recorder and put the tiny mic inside my earcup of my headset. It
worked fine.
Hai Longworth
Old March 21st 07, 08:42 PM posted to rec.aviation.piloting
Lou
worked fine.
Hai Longworth
Thats perfect. It's a long way off, but when I finish my plane I
thought it would be cool to
record the first flights.
Lou
P.S., the safe was incase of disaster.
Old March 21st 07, 09:25 PM posted to rec.aviation.piloting
Gig 601XL Builder
worked fine.
Hai Longworth
Lou
I have no problem with the idea of a recorder in the cockpit. I just see no
use for the safe.
Old March 21st 07, 10:46 PM posted to rec.aviation.piloting
Lou
On Mar 21, 3:25 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
worked fine.
Hai Longworth
Lou
use for the safe.
Ok, Ok, I was just thinking the worst possible ending of a flight.
The
safe was to protect the recorder from fire.
Lou
So I watch too much tv.
Old March 22nd 07, 12:05 AM posted to rec.aviation.piloting
Andrew Sarangan
worked fine.
Hai Longworth
Lou
Recording the sound should be the last thing on your mind when making
a first flight on an experimental aircraft. If you must, leave the
recording to someone else on the ground with a scanner.
Old March 22nd 07, 12:06 AM posted to rec.aviation.piloting
Jim Stewart
worked fine.
Hai Longworth
Lou
use for the safe.
The
Put the recorder on a scanner or handheld on the
ground. It's safe and it's less distraction
for the pilot.
Old March 22nd 07, 12:19 AM posted to rec.aviation.piloting
John T
"Lou" wrote in message
ups.com
Here's how I do it:
http://sage1solutions.com/users/john/flights/cockpitvideo.htm
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old March 22nd 07, 12:39 AM posted to rec.aviation.piloting
Richard Turner
Back when I was working as a flight test instrumentation engineer at the
USAF Test Pilot School, we were trying to figure out an easy way to
record audio. The easiest way we found, short of doing a modification
to the airplanes and including expensive flight-qualified recorders, was
to take a little audio-activated voice recorder and ran a small
microphone inside the ear cup of one of our headsets. We'd put the
small recorder in our pockets. It worked really well at catching
everything that was said through the intercom.
It's not a "fireproof" solution, but hopefully this might get you
thinking in other areas.
Rich
N734BV @ 75FL
Lou
How to Share a Flight Recorder in a Club? ContestID67 Soaring 17 September 26th 06 02:23 AM
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
EW B-Model flight recorder BDS Soaring 12 August 19th 06 04:39 PM
US: Flight Recorder Alert Judy Ruprecht Soaring 8 July 19th 04 09:04 PM
who does Flight Recorder calibration... ken ward Soaring 4 March 5th 04 02:28 AM
