Glareshield Overhaul?
Old March 21st 07, 10:42 PM posted to rec.aviation.owning
Mike Spera
Default Glareshield Overhaul?
After 13 years since recovering, my Cherokee 140 glareshield vinyl has
developed a crack that has gotten pretty ugly.
I was happy with the original (when the covering was new). I liked the
fact that it was solid and could be grabbed as a handhold.
I understand that these things have screws along the top of the
instrument panel just behind the overlays. After the screws are removed,
it is tilted up and slid out from the lip on the top fascia.
Is this correct?
Does anyone have a premade complete replacement? Or, does anyone sell
the vinyl and padding? I'll do it myself.
I ordered and received the Aircraft Door Seals unit and I am returning
it. If your plane's top fascia is deteriorating (mine is not but many
are), then this unit is for you. It replaces the glareshield and covers
the entire top fascia to the windshield. My top fascia is fine so their
unit is not at all what I expected or wanted. I'll let you know how the
return goes.
Any other alternatives?
Thanks,
Mike
Old March 22nd 07, 03:57 PM posted to rec.aviation.owning
Paul kgyy
Is this correct?
return goes.
Thanks,
Mike
Dennis Ashby makes one out of fiberglass, sort of flat black textured
on top. I have it in my Arrow. It has a lip on the front that can be
used as a hand grab, and the lip drops down enough that you can mount
a panel light strip underneath it.
I can't tell you anything about installation, sorry - was in the plane
when I bought it.
Old March 22nd 07, 05:40 PM posted to rec.aviation.owning
Robert M. Gary
Is this correct?
return goes.
Thanks,
Mike
Good luck. I had a similar experience in my Mooney. Sadly no one makes
an aftermarket glareshield for the Mooney and buying one from Mooney
will set you back a few AMU's. I settled to do some grinding to get it
to fit better and then took it to an automotive interior place to have
new leather put on it. Sad to put it back in only 70% good but its
much better than it was before.
-Robert
Old March 22nd 07, 08:23 PM posted to rec.aviation.owning
Dave Butler
I'm surprised you think it's a good idea to use it as a handhold. Most
of the glareshield installations I'm familiar with are just attached
with a few flimsy screws.
Old March 22nd 07, 08:34 PM posted to rec.aviation.owning
dave
I have an after market glare shield. The glare shield is simply held
down with Velcro. It's part of the STC for the installation of the one
piece windshield and modern instrument panel. Very nice setup that
came with the plane. The Velcro however could use a little more muscle.
Dave
M35
Old March 22nd 07, 11:13 PM posted to rec.aviation.owning
Mike Spera
Mine must be screwed in pretty good. It ain't movin. I really appreciate
it when I am under the panel changing vac filters and such. If I put in
this flimsy velcro installed thing I have no idea what I would haul
myself up with.
Mike
Old March 23rd 07, 09:39 PM posted to rec.aviation.owning
jgalban
return goes.
I'm confused as to what you're looking for. Is it just the eyebrow?
Old March 23rd 07, 11:34 PM posted to rec.aviation.owning
Mike Spera
return goes.
Yes.
To overhaul or not to Overhaul, that is the question- EridanMan Owning 19 May 12th 06 11:58 PM
ASI overhaul? [email protected] Owning 7 June 4th 04 02:56 PM
ASW20A Glareshield needed Tim Mara Soaring 0 April 19th 04 04:17 AM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 12:39 PM
Overhaul at TBO? Greg Esres Piloting 5 October 23rd 03 12:52 AM
