The wire shielding is made from ground strap, it's available everywhere/. It
is braided tubing pressed flat. Just squeeze it and it opens up, then push on it lengthwise and it gets bigger. Run your wire threw it and pull it tight. Someone makes little cans that the unsheilded plugs go in and take the shielded wire. If you want I'll find out who. I don't go to this list often, so email me direct. bill "Michael Horowitz" wrote in message ... Folks - First time use of a handheld around my Tcraft. Flipped the prop and turned on the handheld (using an external ant. mounted below my feet) and the magneto noise became very apparent. My instructor/A&P immediately advised that I get a shielded harness and plugs, which would run about $300. Seems to me that a home-brew solution would be possible. Is anyone aware of anyone having done this successfully? There seem to be two issues to be addressed: shielding the plug and shielding the cable. I think I can do the latter with shielding taken off a suitable diameter piece of coax. The question then becomes "How to shield the plugs?" Any suggestions are appreciated - Mike |
Electronic Ignition | Andre | Home Built | 1 | September 5th 03 06:15 PM |
Ignition Exciter Wiring | Juan E Jimenez | Home Built | 0 | August 31st 03 06:03 AM |
WTB: Ignition Exciter | Juan E Jimenez | Home Built | 0 | August 27th 03 08:09 PM |
Wright Flyer Ignition | Dan Thomas | Home Built | 6 | July 22nd 03 03:45 AM |
2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 01:37 AM |
