You are really asking two different questions....
The Fragment Envelope for the weapon (how high, far, fast do fragments travel) .... And the safe release height for that weapon.... In level flight you can drop (a single MK-82 for example) from an altitude lower than the maximum height of the frag pattern (due to your forward velocity during the time of fall and the time for the fragments to travel outward). The slower you are the higher you need to drop and vice versa Then you need to throw in the fuze arming delay, diving deliveries, ripple deliveries, type of escape maneuver (level, climbing, turning, lateral, backup) etc.... So if you were going to check out your modeling, and simply looked at maximum height of the frag pattern to determine if you were a 'mort' or not, I'd think you'd be given a false view of what's really going on. FWIW Mark "Mike D" wrote in message om... Am trying to find some info to help accurize (a somewhat outdated) Vietnam era flight sim - Janes Fighters Anthology. Can any of you military folks remember any numbers about the blast frag distances for various aircraft bombs - 500/750/2000/3000 lb? How about nape/CBUs/2.75 in FFARs? What would be the safe release heights for each or any of these before you can expect to be affected by your own ordnance? I don't have access to an F-105 or F-4 dash 34 manual, but I bet that would answer my questions. Thanks, Mike Druzolowski |
Thanks for the responses. I guess what I'm looking for is the minimum
safe release altitude (estimate) where you could release in a dive then level out right over the target (I know, not recommended) and not heve to worry about being knocked out of the sky. (I just don't want to be able to drop a 3000 lb. M118 from 900 feet at 190 knots and fly away unscathed, because I suspect that this is way too low! The DuoSoft Toolkit allows creation and/or modification of ordnance used within the sim, but I don't have any real world info to base some of the characteristics on. Thanks again everyone. Mike D. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
