Electronic Artificial Horizon
Old May 3rd 07, 01:43 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Default Electronic Artificial Horizon
On May 2, 5:52 am, wrote:
for my money, if youve got an experimental glider, go for the Dynon
10A flight display. the power draw is low and you get a lot more info
than just an AI.
The spec at Dynon says 8 watts, which translates to 670 mA, which
doesn't sound low to me, at least for a glider. Or is the actual draw
less than the spec? Admittedly a lot less than a mechanical gyro, but
not something I could run continually for any time. I tried to find
the current draw of the TruTrak units, but couldn't. I think they're
better, but does anyone know for sure?
This probably won't be much help, but.....
There is no manual for the Tru-Trak T&S on their site - at least I
couldn't find one, but I did find one for the ADI, which is somewhat
similar. It didn't quote actual drain, but did say that the wiring and
fuse should handle 2 amps.
OTOH, instruments that I actually have the manual for (SDI C4, Filser
ATR-500) both ask for fuses that are rated well above actual current drain.
Has anybody got experience with the Tru-Trak ADI that they can share?
Would it be any better in a glider than their T&S, bearing in mind that
its twice the price?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
artificial horizon DavidH Home Built 14 March 14th 07 07:47 AM
Artificial horizon pinout? [email protected] Home Built 3 July 16th 06 02:02 PM
Artificial Horizon testing Rory O'Conor Soaring 6 April 5th 05 11:48 PM
New artificial horizon - Sigmatek or R.C. Allen? David Herman Owning 7 November 13th 04 01:38 PM
Artificial Horizon/Autopilot Connection Jay Honeck Owning 2 September 7th 03 05:07 PM
