[AU] Light plane sparked terror alert
Old August 30th 03, 03:50 AM
matt weber
On Fri, 29 Aug 2003 06:54:35 -0400, Cub Driver
commanders had full authority to order the Hornet to shoot it down.
Certainly they have the authority. This does not mean they'd exercise
that authority.
In the U.S., to judge by a recent incident, the intercepting a/c are
configured for slow flight. They first try to contact the offending
a/c on the designated emergency channels, including 121.5 civil.
(Pilots are required to monitor 121.5 "if able"; I'm not able, so
don't do it. Instead I look around a lot.) The next step is to fire
red flares. I'm not sure about the step after that, because to the
best of my knowledge it has happened. Most likely it involves bouncing
the lightplane around in fighter-induced turbulence. I doubt that the
F-15/16/18 would go straight to missiles hot.
It is not clear how effective a missle would be. A small aircraft
doesn't have much of a heat signature,and what there is greatly
reduced by the turbulence produced by airflow. Exhaust is at the
front.
In addition, the speeds are so low, that you don't get any leading
edge heating. In short I am not at all convinced that an IR guided
missile would be able to lock onto a prop powered 100hp aircraft. It
just isn't much of an IR or a radar target...
These things often don't have much of a radar signature. There is the
Cessna that made it all the way to Moscow during the cold war and
landed in Red Square....
Old August 30th 03, 05:40 AM
David Bromage
Plus speeds are so low that it would be hard to line up a cannot shot.
This was the problem the RAAF had with the pilotless Auster in 1955. The
Auster was going 30mph slower than the stall speed of a Meteor.
Cheers
David
Old September 1st 03, 02:05 PM
Coop
Cheers
David
So... maybe they should have stood off a little ways and treated it as a
stationary target.....
Coop
Old August 30th 03, 12:18 PM
Keith Willshaw
"matt weber" wrote in message
that authority.
front.
IR missiles have no problem in homing in on the heat signature
of a lycoming engine
Which has nothing to do with radar signature, they show quite nicely
on ATC radars let alone military sets, the problem with the Cessna
in Moscow was more political indecision than anything technical
Keith
Old August 31st 03, 01:14 AM
matt weber
On Sat, 30 Aug 2003 12:18:13 +0100, "Keith Willshaw"
that authority.
front.
They show up on most ATC radars only because they have a transponder.
Note the difficulties US ATC had in locating 757's and 767's on 9/11
after the transponders were turned off, and 757 or 767 has a far far
larger radar cross section than a single engine cessna.
ATC radars generally only see either very large targets, or very
cooperative targets (transponders).
Old August 31st 03, 01:32 AM
Mike Marron
After 9/11, I heard them ask aircraft in the vicinity to assist with
identifying unindentified primary targets on their scopes. And
they didn't seem to have any difficulties painting me as a primary
target whenever my transponder went inop (which was not all that
infrequent in those old single-engine C-210's).
-Mike Marron
Old August 31st 03, 11:11 AM
Keith Willshaw
Nonsense they show up on primary radar very well
Again this is nonsense, the radar tracks of those aircraft have been
produced in evidence primary radar is more than adequate
Wrong, ATC radars track light aircraft every day.
Hell the radars of WW2 had no problem tracking aircraft of the
same size, its for damm sure that modern radars are better
Keith
Old September 1st 03, 07:17 AM
matt weber
On Sun, 31 Aug 2003 11:11:10 +0100, "Keith Willshaw"
It is more then adequate, as long as they never get more than about 35
miles away from the RADAR.
After that, the combination of the inverse square law, and the very
limited RCS of many light aircraft makes them just about impossible to
see. that is one of the reasons that ATC in the USA also receives data
from far more capable military RADAR systems that are not limited by
Civilian energy exposure limits.
Most of the track data for both JFK Jr's crash, and the EgyptAir crash
came not from civilian ATC radars, but Military Radars which share
data with ATC.
I suggest you do the arithmetic sometime on what sort of power you
need to radiate to be able to get a reliably detectable return on a 1
m^2 RCS at 50km. 1m^2 is fairly typical of Cessa single. Some of the
older aircraft with fabric instead of metal are considerably smaller
RCS.
After you have done that calculation, decide how near you would like
to live to that particular radar.
Only at short range.
My father assures me that was not the case, and he WAS the Radar
officer on a US Carrier in WW II. I'll take his word on that subject
over yours anytime
A TBD or a Betty could be seen at about 100 miles, but they are a
whole lot bigger than a Cessna 172
The Radar in an F16 in Air to Air mode has a 50% probability of
detecting a 1 m^2 RCS at 40km..
Old September 1st 03, 11:51 AM
Keith Willshaw
Actual range depends on height, RCS , transmitted power and
the sensitivity of the radar, However its a matter of historical
fact that during WW2 the primitive Chain Home system could
detect aircraft out to 200 miles
http://www.radarpages.co.uk/mob/chl/chl.htm
However your original claim was that they couldnt be seen
at all unless they had a transponder !
Come now make up your mind , are they impossible to see
or is it just that the range is limited ?
data with ATC.
RCS.
A Cessna in the head on aspect may indeed have an RCS as small
as 1 m2 , this is around the same as an F-16 !
Take a look at the free space coverage diagram for the
Raytheon ASR-23SS surveilance radar at
http://www.raytheon.com/products/asr...docs/asr23.pdf
You'll find that this civil aradt ssytem is quite capable of detecting
a 2 sq m target at 10,000 ft at 40 nautical miles
Range isnt the problem, height is, if the aircraft is down in the
weeds you will indeed be limited to 20 miles or less
Thats why we have AWACS
Keith
Keith
over yours anytime
Yet 1930's era radar could detect an Me-109 over France from
the UK, the Me-109 has a wingspan roughly the same as a Cessna
at 32 ft
The US Army SCR-270 could detect aircraft at around 120 miles
out. One such set detected the Pearl Harbor raid 30 minutes before the
attack.
A Cessna Skylane has a wingspan of 35 ft, a TBD had a wingspan of
50ft and an Aichi Val a wingspan of 47.1 ft
We arent talking about an F-16 radar, we are talking about the
more capable search radars at ground stations.
Keith
Old September 1st 03, 01:06 PM
RT
Keith Willshaw wrote in message ...
Keith
And now you will explain how FA18s picked up and intercepted an intruder (a
Cherokee Arrow - about a week ago) without having "more capable search
radars at ground stations" during a live firing exercise at a range, using
their on-board stuff. When, in fact, the intruder had disappeared from
civil radar some time before.
In other words, you don't have the faintest ****ing clue about what you're
mouthing off about.
But since you know it all, you can doubtless nominate the range involved,
the destination of the Arrow and the actions taken by the FA18 pilots and
civil ATC.
"more capable search radars at ground stations"
- mmm - radar is not really your forte, eh?.......
or do you think they are going to chop the wings and u/c off the Wedgetail
and sell that for scrap while they set up the remainder propped up by a
coupla fenceposts on a deserted airfield?
Keith, baby - you just stick to raising guinea pigs and leave the wheels and
levers stuff to people who have a clue, eh?
Kit Plane Instrument light dimmer Mickey Home Built 1 December 3rd 03 05:46 PM
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 10:09 PM
Looking for a fast light plane Dave lentle Home Built 2 August 6th 03 03:41 AM
Slats and Fowler Flaps On Light Plane Brock Home Built 28 July 31st 03 10:12 PM
