"Tim Hickey" wrote in message
... I have a Zenith CH-300 with an O-320. I had a similar problem in the beginning. I did as you have done, plus insulated the fuel lines, installed a small heat reflective shield over the gascolater, and ran a blast tube down to the mechanical fuel pump. Since then (about 1990) I have run over 9000 gallons of mogas through the machine with out problem. Although I will always let the engine (and the fuel pump that is bolted to the case) cool between flights. If I know that I will be doing flights without allowing a cool down period, I will put 100LL in one tank, and take off on it. Sounds like you have addressed all the issues that might arise from burning "good" mogas. Obviously, nothing can insure failure from bad or contaminated fuel, whatever the grade. I had insulated all my firewall-forward tubing during the original construction, but insulation only delays heat, it doesn't stop it. Sometimes I wish I had a thermometer which would monitor under cowl temps. When it gets hot out, I can't believe the blast furnace air that emits from the oil filler door. I remember one featured airplane in Sport Aviation which had cowl vents which fell open whenever there was no air pressure inside the cowl. Seems like a good idea to vent the hot air when you shut down. My Emeraude has both a mechanical pump and an electric pump. If I had to do it over again, I would mount the electric pump near the rear tank, to insure fuel flow. There is something to be said for the original design which had nothing but gravity flow from the cowl tank along with a forward-facing tube on the fuel cap. Sometimes simple is best. Tailwinds, Rich S. |
"good" mogas. Obviously, nothing can insure failure from bad or contaminated fuel, whatever the grade. I had insulated all my firewall-forward tubing during the original construction, but insulation only delays heat, it doesn't stop it. Sometimes I wish I had a thermometer which would monitor under cowl temps. When it gets hot out, I can't believe the blast furnace air that emits from the oil filler door. I remember one featured airplane in Sport Aviation which had cowl vents which fell open whenever there was no air pressure inside the cowl. Seems like a good idea to vent the hot air when you shut down. All good ideas. I, too, have often wondered why I have all the data in the world on my JPI engine analyzer, but no "under-the-cowl" temperature readings. I suppose CHT and EGT are the pertinent temps, but that doesn't show what all those hoses, wires, and connections are enduring. I'd bet it's well over 200 degrees at the firewall, in the summer during a long taxi -- but I don't honestly know. Regardless, as you know we've run over 8500 gallons of mogas through Atlas (and an unknown amount through our old O-320-powered Warrior) without so much as a burp. Different fuel systems, I guess. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
All good ideas. I, too, have often wondered why I have all the data in the world on my JPI engine analyzer, but no "under-the-cowl" temperature readings. Jay, there's no reason you couldn't take one of the unused channels and put a thermocouple on it. Hmm, maybe not. If you put it on the IAT, I think that will change the carb temp to TIT. That's assuming you have the oil temp, OAT, and carb temp probes like I do. |
Fuel prices | Paul kgyy | Owning | 14 | October 19th 05 10:55 PM |
Fuel Prices | Ross Richardson | Owning | 60 | September 30th 05 02:06 AM |
Fuel Prices | ~R | Rotorcraft | 0 | September 10th 05 03:56 PM |
Our local fuel prices just went up again! | Peter R. | Piloting | 17 | May 28th 04 06:08 PM |
Fuel Prices | S Green | Piloting | 0 | May 9th 04 09:47 PM |
