Senior Pilot and Command pilot ratings
Old September 5th 03, 12:17 AM
Tarver Engineering
"Mike Marron" wrote in message
Ed Rasimus wrote:
Mike Marron wrote:
USAF Command Pilot wings are much larger in size (rightfully so!)
than other aviation badges. I don't think it's no accident that I
haven't lost Dad's Command Pilot wings but I did (regrettably)
somehow manage to lose his medals back when I was a young
kid. The silver wings have tarnished a bit over the years but that's
OK since you can clearly see the imprint where he used his thumb
to pin the wings onto his dress blues.
Sorry, Mike, but, unless things have changed drastically, the wing
size remains the same with the exception that Senior Pilot has the
star affixed to the shield and Command Pilot adds the wreath around
the star. Otherwise, the wings are the same size.
I was simply comparing the size of USAF Command Pilot wings to the
size of wings of other wings worn by various military personnel
(paratrooper wings, for example).
Sure.
Old September 5th 03, 12:26 AM
Tarver Engineering
"Phineas Pinkham" wrote in message
"Ed Rasimus" wrote in message
The first pilot
time requirements reflect a recognition of the difference between
small airplanes where an aviator is flying and multi-place airplanes
where an aviator is observing.
What a childish comment from an immature arschloch.
Reflects the mentality of single seat numb-nuts versus the
professionalism
of multi-engine Pilots.
Man in the loop, right side monitor.
Old September 5th 03, 12:49 AM
Ed Rasimus
I could be wrong, but when I visually compare Command Pilot wings
to any other wings -- Command Pilot wings soar above the rest WRT
size, no?
Size is often in the view of the beholder. If that matters....
Ed Rasimus
Fighter Pilot (ret)
***"When Thunder Rolled:
*** An F-105 Pilot Over N. Vietnam"
*** from Smithsonian Books
ISBN: 1588341038
Old September 5th 03, 12:51 AM
Tarver Engineering
size, no?
You two need to get a room.
Old September 5th 03, 12:56 AM
Ed Rasimus
The first pilot
Ed Rasimus
Reflects the mentality of single seat numb-nuts versus the professionalism
I guess the difference in time requirement 2000 vs 1300 and 3000 vs
2300 was an adjustment for the delays built in waiting for the
assistant pilot to respond to those checklist challenges.
Here's an excerpt from book 2, in draft, regarding my time in droning
airplanes with passengers in back--checking out in the T-29 at
Randolph AFB while assigned to Hq.:
"Check-out in the airplane was a disaster. It started with a local
orientation flight. Half a dozen staff types loaded onto an airplane
and over a four-hour flight we sat in the airline-style seats reading
magazines and waiting for a chance to take the controls for a period
ranging from fifteen minutes to an hour. I was eventually called to
the cockpit where I was directed into the left seat. The view was
pretty good, but the big steering wheel was clearly converting flying
into an unnatural act. The throttle quadrant was between the seats,
requiring power control with the wrong hand, and there were a
profusion of knobs and levers on the quadrant that implied the
airplane had a lot more than the two engines I knew were out there on
the wing. Trim wasn't through an electrical thumb switch, but rather
with a large wheel mounted vertically on the side of the throttle
pedestal. My first attempt at a slight turn met with no result. It
quickly became apparent that the fingertip flying of high performance
jets wasn't the mode of operation for reciprocating engine trash
haulers. It took considerable muscling to get the airplane to move out
of straight and level. Control pressures weren't the solution, brute
force manipulation of the wheel was.
After the chuckles of the instructor pilot and flight mechanic over my
control technique subsided, we entered the traffic pattern. "We're
going to do a couple of visual touch-and-goes," the IP said. "Call for
the before landing checklist."
"OK" I responded. Nothing happened.
"Call for the before landing checklist," he repeated.
"Right. Give it to me," I tried again. Still nothing.
"You have to say the words," he scolded. "You have to say, 'before
landing checklist.'"
"You're kidding aren't you? OK, before landing checklist," I intoned.
"Props?" The flight mechanic opened his greasy yellow checklist and
began reading. I looked quizzically at the IP. He pointed to two of
the knobs at the top of the throttle quadrant. Then held them down for
about eight seconds until the RPM of the engines magically, without
moving the throttles, moved to 2400. "That sets the props to proper
pitch," the mech explained. "You're supposed to do that and then say,
'2400, set.'"
"Flaps," the flight mechanic continued then looked expectantly at me
again.
I looked out the window on my side of the cockpit and determined that
I couldn't see any flaps. Without a clue about what was needed, I
said, "OK, set them."
"No," the mech warned, "You're supposed to say fifteen degrees."
I'm nothing if not a quick study. "That sounds right. OK, set the
flaps." Nothing happened.
The IP was now beginning to glare a bit impatiently. "You have to say,
"fifteen degrees, then the copilot will set them while you fly the
airplane."
Determined to play the game, I say, "fifteen degrees." Now there's
action from the IP who fiddles with a little lever and leans
myopically forward to stare at the flap position indicator setting it
to exactly fifteen, not fourteen, not sixteen, but precisely fifteen.
He's gotten where he is today by being precise.
The flight mech continues down the list. "Mixture?" I ask what the
proper response is. The IP says to set the red levers to full forward
or rich. I ask who is authorized to do that and the IP motions to the
flight mechanic sitting between us and hovering over the throttles. I
tell him to go ahead.
"Sir, I can't do it unless you say 'full rich,' then I move the
levers." The enlisted mechanic is frustrated by my manifest
incompetence.
I'm in an airplane that barely responds to control inputs, that
requires some sort of Gilbert and Sullivan duet to get anything done
and which apparently is dependent upon an exaggerated "simon says"
game before anything happens. Frustrated, I ask the IP "why, if
everyone here but me knows the answer, do we have to ask the
questions? If I ask for the before landing checklist, and now you know
that's what I want, why don't you just do it?" He shakes his head at
the ignorance of this former single-seat, single-engine fighter pilot
who is now adrift on his many-motored, trash-hauling turf. It begins
to dawn on me that I'm dead meat in this game of aeronautical
one-upmanship. I'm learning about something called crew coordination."
Ed Rasimus
Fighter Pilot (ret)
ISBN: 1588341038
Old September 5th 03, 12:59 AM
Mike Marron
size, no?
OK, whose got the biggest ahh, WINGS of all?
-Mike (pass me them calipers) Marron
Old September 5th 03, 02:11 AM
Ed Rasimus
I had a girlfriend like that at one time...great for the ego.
-Gord.
Old September 5th 03, 02:48 AM
Phineas Pinkham
"Ed Rasimus" wrote in message ...
professionalism
You should get a ghost writer and collaborate on a book.
Old September 5th 03, 07:41 AM
Walt BJ
SNIP:Reflects the mentality of single seat numb-nuts versus the
professionalism
SNIP:
You write from ignorance, old man. It takes a lot of sorties to rack
up 1300 and 3000 hours in single-seat single-engine jets at 1:30 per
sortie. A lot of my classmates had to go TDY to the AEW 121s to get
enough time to qualify. I was lucky; I made it the hard way. As for
professionalism, a single-seat pilot has to do everything a multi crew
does - by himself. When I was picking up tired aging fighters from the
ANG for the Boneyard and taking the ANG new ones from North American
(LAX) I was operating in high density IFR areas - LAX, of course, and
then up in the New England area. No one changed my radio channels for
me, no one copied clearances for me, no one navigated for me or
figured out new ETAs for me when my route was changed by ATC. No one
backed me up on an IFR approach to a strange field. Oh, by the way our
minimums for these flights were USAF minimums. And nope, I didn't have
an autopilot.
Professionalism? Try night dive bombing or a night low level. By
yourself. Try a 5-minute scramble to a night low altitude intercept a
hundred miles out over the ocean on an unknown bogie running
blacked-out. Fly 250 miles north of Thule on a single engine. And how
often have multi-engine crews ever flown their airplane to its design
operational limits? How many times have they ever fought vertigo? One
'hood' ride to show proficiency in the 'unusual attitude' instrument
recoveries would turn most (not all) multi pilots' hair stark white.
(I knew a few who went from B52s to F4s and loved it.) Quite a bit
different from a canned computerized flight plan, a nice leisurely
takeoff and an autopilot cruise at a fixed altitude to a destination
with never a bank over 30 degrees, if that. Coffee at hand, you can
get up and walk around, doze while the other guy 'flies' the
autopilot, and even have a meal! And most multi crews have basically
only one mission - in the F4 we had air defense, air superiority, nuke
strike, close air support and interdiction. Oh, yes, refueling day and
night, not to mention side lines like formation flying in night and
weather (flying wing at night in the weather is one long battle with
vertigo!), missile/gunnery target tow, and for a few lucky ones test
hops. Now and then a nice long deployment where you could log lots of
hours between takeoff and landing.
Professionalism is easy to profess - the proof is in how well you do a
complex job. Now, which job is more complex?
Walt BJ
Old September 5th 03, 01:31 PM
Phineas Pinkham
You win!
"Walt BJ" wrote in message
om...
professionalism
SNIP:
an autopilot.
Walt BJ
