Intercom Problem with New Radio
Old May 28th 07, 06:36 PM posted to rec.aviation.owning
RST Engineering
Default Intercom Problem with New Radio
Thanks for your suggestions. The COM 120 was wired to the COM 2 input
of the audio panel (KMA-134)
You really need to be quite specific when you make statements like this.
What lead/terminal/connection of the COM-120 was wired to which lead/... of
the audio panel? Audio panels will generally have two inputs, speaker and
phones. Each is terminated differently and are quite different
electrically. Was this the only connection between the COM 120 and the
audio panel or were the mic audio and key lines also connected? Did they do
an exact wire-for-wire swap or did they do some other mickey motion with the
new radio installation?
, and the audio panel output wired to the
SPA-4000.
Again, specifics please. Was the audio panel output wired to an input on
the intercom or were the two outputs paralleled?
I believe the shop just removed the COM 120 and wired the
SL40 in it's place, so it should still be the same. I haven't noticed
anything different or unusual, i.e. if I select COM 2 I only hear COM
2.
So how does "the shop" explain it? You paid good money for an installation
and you didn't get it. Can they explain it away to you?
I didn't check the intercom mode of the SL40. I'll do that.
That's a possiblity if the SL40's intercom is inverted in phase to the
intercom's output.
You say the intercom volume drops in half when you turn on the SL40. Is it
just turning on the power or do you have to have both transmit and receive
selected to the SL40 before the volume drop occurs?
more than 1 radio with Sigtronics Sport 200 S Two Place Intercom John Foreman Home Built 1 December 21st 06 07:24 PM
Garmin 496-XM Radio-PS Engineering Intercom Follow up... Jay Honeck Owning 25 December 9th 06 12:26 PM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
FS Helmets, Intercom, Radio [email protected] Aviation Marketplace 0 April 17th 04 04:40 PM
Intercom Audio Input and Satellite Radio John Golovich Owning 5 August 7th 03 10:00 AM
