On Jun 1, 5:03 pm, Steve - KDMW wrote:
Another tidbit of info. The intercom comes back to normal if the Garmin radio is on and not selected. It doesn't load down the intercom simply by virtue of being on, it has to be on and selected. That sounds like the SL40's intercom function is competing with the SPA400 |
On Jun 1, 9:35 pm, mikem wrote:
On Jun 1, 5:03 pm, Steve - KDMW wrote: Another tidbit of info. The intercom comes back to normal if the Garmin radio is on and not selected. It doesn't load down the intercom simply by virtue of being on, it has to be on and selected. That sounds like the SL40's intercom function is competing with the SPA400 I forgot to mention... I also checked to see if the Sl40's pin 12 was shorted to ground, which would enable the SL40's Intercom function and it wasn't. But just for the heck of it, I changed the Sl40's intercom volume from 000 (slaved to the volume knob) to 001 (lowest volume possible) to see if it would have any effect and it didn't. |
On Jun 1, 7:35 pm, mikem wrote:
On Jun 1, 5:03 pm, Steve - KDMW wrote: Another tidbit of info. The intercom comes back to normal if the Garmin radio is on and not selected. It doesn't load down the intercom simply by virtue of being on, it has to be on and selected. ... Another thought: If the summing resistor normally in series with COM2 input inside the Audio Panel has been removed or shorted out by some strapping jumper, then you would get this behavior. I'm not familiar with your audio panel, but each input should have a series resistor between the input pin and the summing junction (op amp input). If for whatever reason, this resistor is missing, the SL40's low output impedance would upset the balance at the summing junction. Opening the COM2 switch would make the problem go away. If the old COM that was removed had some resistance in series with its output, then it would NOT have upset the balance... |
On Jun 3, 2:54 am, mikem wrote:
On Jun 1, 7:35 pm, mikem wrote: On Jun 1, 5:03 pm, Steve - KDMW wrote: Another tidbit of info. The intercom comes back to normal if the Garmin radio is on and not selected. It doesn't load down the intercom simply by virtue of being on, it has to be on and selected. ... Another thought: If the summing resistor normally in series with COM2 input inside the Audio Panel has been removed or shorted out by some strapping jumper, then you would get this behavior. I'm not familiar with your audio panel, but each input should have a series resistor between the input pin and the summing junction (op amp input). If for whatever reason, this resistor is missing, the SL40's low output impedance would upset the balance at the summing junction. Opening the COM2 switch would make the problem go away. If the old COM that was removed had some resistance in series with its output, then it would NOT have upset the balance... The KA-134 has an open chassis. I could take a look. I'll trace the solder track from pin D. If I don't find anything, I'll try a 100-ohm resistor on the Com 2 input. |
On Jun 1, 7:35 pm, mikem wrote: On Jun 1, 5:03 pm, Steve - KDMW wrote: Another tidbit of info. The intercom comes back to normal if the Garmin radio is on and not selected. It doesn't load down the intercom simply by virtue of being on, it has to be on and selected. ... Another thought: If the summing resistor normally in series with COM2 input inside the Audio Panel has been removed or shorted out by some strapping jumper, then you would get this behavior. I'm not familiar with your audio panel, but each input should have a series resistor between the input pin and the summing junction (op amp input). If for whatever reason, this resistor is missing, the SL40's low output impedance would upset the balance at the summing junction. Opening the COM2 switch would make the problem go away. If the old COM that was removed had some resistance in series with its output, then it would NOT have upset the balance... I got ahold of a KA-134 schematic and discovered that there is no summing amplifier in a KA-134. The radio inputs go through a purely mechanical switch matrix for the Speaker switch and the Both switch, but are fed directly to the Headphones output of the audio panel. It is purely a mechanical swtiching device for the audio portion. So the SPA-400 is seeing the radio output directly, and not isolated/ conditioned by the audio panel whatsoever. I don't see how I can attach the schematic file here (a .jpg file), or I'd attach it so you can see. |
On Jun 3, 6:28 pm, Steve - KDMW wrote:
.... I got ahold of a KA-134 schematic and discovered that there is no summing amplifier in a KA-134. The radio inputs go through a purely mechanical switch matrix for the Speaker switch and the Both switch, but are fed directly to the Headphones output of the audio panel. It is purely a mechanical swtiching device for the audio portion. So the SPA-400 is seeing the radio output directly, and not isolated/ conditioned by the audio panel whatsoever. I don't see how I can attach the schematic file here (a .jpg file), or I'd attach it so you can see. Ok, then the fact that the Narco's headphone audio output had a higher output impedance than the SL40 must be the key. Just go ahead and put 47 to 220 Ohms in series between the SL40 and pin D, and call it good... You will have to run the volume on the SL40 slightly higher, but that probably wont matter... |
On Jun 3, 10:48 pm, mikem wrote:
On Jun 3, 6:28 pm, Steve - KDMW wrote: ... I got ahold of a KA-134 schematic and discovered that there is no summing amplifier in a KA-134. The radio inputs go through a purely mechanical switch matrix for the Speaker switch and the Both switch, but are fed directly to the Headphones output of the audio panel. It is purely a mechanical swtiching device for the audio portion. So the SPA-400 is seeing the radio output directly, and not isolated/ conditioned by the audio panel whatsoever. I don't see how I can attach the schematic file here (a .jpg file), or I'd attach it so you can see. Ok, then the fact that the Narco's headphone audio output had a higher output impedance than the SL40 must be the key. Just go ahead and put 47 to 220 Ohms in series between the SL40 and pin D, and call it good... You will have to run the volume on the SL40 slightly higher, but that probably wont matter... Success... I did a cut and jumper mod and added a 220 ohm resistor to the Com 2 audio input of the KA-134 and now everything works great. Intercom value is equal (loud and clear) with either Com1 or Com 2 selected. Thanks for all of your input (no pun intended). |
more than 1 radio with Sigtronics Sport 200 S Two Place Intercom | John Foreman | Home Built | 1 | December 21st 06 07:24 PM |
Garmin 496-XM Radio-PS Engineering Intercom Follow up... | Jay Honeck | Owning | 25 | December 9th 06 12:26 PM |
Good panel mount COM radio and intercom w/push-to-talk? | John Huebbe | Home Built | 10 | November 27th 04 07:58 PM |
FS Helmets, Intercom, Radio | [email protected] | Aviation Marketplace | 0 | April 17th 04 04:40 PM |
Intercom Audio Input and Satellite Radio | John Golovich | Owning | 5 | August 7th 03 10:00 AM |
