Bob Moore writes:
Head and body should remain perpendicular to the floor of the cockpit. This comes naturally if the turn is coordinated. Interesting. When you learn to ride a motorcycle, you're taught to keep your head normal to the horizon in turns ... because turning your head with the bike as you lean into a turn results in disorientation. Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). I note from in-cockpit videos of aerobatic pilots that they keep their heads level with the horizon, not level with the aircraft. |
On Jun 10, 1:26 pm, Mxsmanic wrote:
Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). That means real pilots get disoriented in visual flight. Amazing factoid. Here you go again. F-- |
Mxsmanic,
When you learn to ride a motorcycle, you're taught to keep your head normal to the horizon in turns ... because turning your head with the bike as you lean into a turn results in disorientation. So what is the difference between a bike and a plane in a turn? And why would your idea below lead to more disorientation in a plane, not less? You can figure it out. Just try. Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). Ah, I was wondering what angle you would come up with this time to present a really stupid idea as wisdom superior to what actual pilots do. You never fail to deliver. I guess it requires some kind of intellect... -- Thomas Borchert (EDDH) |
Thomas Borchert writes:
So what is the difference between a bike and a plane in a turn? None, if the turn is level and coordinated, from a vestibular standpoint. And why would your idea below lead to more disorientation in a plane, not less? You can figure it out. Just try. Explain it to me. |
Mxsmanic wrote in
: Thomas Borchert writes: So what is the difference between a bike and a plane in a turn? None, if the turn is level and coordinated, from a vestibular standpoint. And why would your idea below lead to more disorientation in a plane, not less? You can figure it out. Just try. Explain it to me. Why? Bertie |
![]() "Mxsmanic" wrote in message ... Explain it to me. Somebody talk to me, I'm looney. |
Mxsmanic wrote
I note from in-cockpit videos of aerobatic pilots that they keep their heads level with the horizon, not level with the aircraft. Because they are not normally operating in coordinated flight. Bob Moore |
Bob Moore writes:
Because they are not normally operating in coordinated flight. Why would that make a difference? What they seem to be doing is minimizing the tilting of their heads, just as motorcycle racers, ballet dancers, and ice skaters do. |
Mxsmanic wrote in
: Bob Moore writes: Because they are not normally operating in coordinated flight. Why would that make a difference? What they seem to be doing is minimizing the tilting of their heads, just as motorcycle racers, ballet dancers, and ice skaters do. You're an idiot. Bertie |
Mxsmanic wrote:
Bob Moore writes: Because they are not normally operating in coordinated flight. Why would that make a difference? What they seem to be doing is minimizing the tilting of their heads, just as motorcycle racers, ballet dancers, and ice skaters do. Nope, during any sort of flight, turns, straight and level, whatever, a motorcycle racer, ballet dancer, or an ice skater would still sit with a straight back and neck if they want to continue a respectable level of flight. Hell, I do software and IT and I sit the same as they would during flight. |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
CAP Orientation Pilot? | Robert M. Gary | Piloting | 7 | August 3rd 05 02:22 AM |
ADV: AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | General Aviation | 0 | December 30th 03 11:37 AM |
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | Aviation Marketplace | 0 | December 30th 03 11:36 AM |
sounds of aviation navigation equipment as head on a scanner radio | Dan Jacobson | Instrument Flight Rules | 5 | December 4th 03 07:27 PM |
