Ratings for an Amphibian
Old June 15th 07, 09:05 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Ratings for an Amphibian
"Scott Skylane" wrote in message
I believe you do not, but a search of the regs to prove that has so far
proven fruitless for me.
Can anyone cite the reg that *requires* you to posses a sea rating to
operate on water?
§ 61.3 Requirement for certificates, ratings, and authorizations.
(a) Pilot certificate. A person may not act as pilot in command or in any
other capacity as a required pilot flight crewmember of a civil aircraft of
U.S. registry, unless that person-
(1) Has a valid pilot certificate or special purpose pilot authorization
issued under this part in that person's physical possession or readily
accessible in the aircraft when exercising the privileges of that pilot
certificate or authorization. However, when the aircraft is operated within
a foreign country, a current pilot license issued by the country in which
the aircraft is operated may be used; and
(2) Has a photo identification that is in that person's physical possession
or readily accessible in the aircraft when exercising the privileges of that
pilot certificate or authorization. The photo identification must be a:
(i) Valid driver's license issued by a State, the District of Columbia, or
territory or possession of the United States;
(ii) Government identification card issued by the Federal government, a
State, the District of Columbia, or a territory or possession of the United
States;
(iii) U.S. Armed Forces' identification card;
(iv) Official passport;
(v) Credential that authorizes unescorted access to a security
identification display area at an airport regulated under 49 CFR part 1542;
or
(vi) Other form of identification that the Administrator finds acceptable.
In the same vein, which reg *requires* you to posses an instrument rating
to operate in IMC?
(e) Instrument rating. No person may act as pilot in command of a civil
aircraft under IFR or in weather conditions less than the minimums
prescribed for VFR flight unless that person holds:
(1) The appropriate aircraft category, class, type (if required), and
instrument rating on that person's pilot certificate for any airplane,
helicopter, or powered-lift being flown;
(2) An airline transport pilot certificate with the appropriate aircraft
category, class, and type rating (if required) for the aircraft being flown;
(3) For a glider, a pilot certificate with a glider category rating and an
airplane instrument rating; or
(4) For an airship, a commercial pilot certificate with a lighter-than-air
category rating and airship class rating.
Old June 15th 07, 09:42 PM posted to rec.aviation.piloting
Scott Skylane
States;
or
/snip part referencing 61.3/
Hmmm, I still don't get where that says I have to posses a sea rating to
operate on the water.
Happy Flying!
Scott Skylane
Old June 15th 07, 10:07 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Has a valid pilot certificate or special purpose pilot authorization issued
under this part in that person's physical possession or readily accessible
in the aircraft when exercising the privileges of that pilot certificate or
authorization."
Old June 15th 07, 10:13 PM posted to rec.aviation.piloting
Ron Natalie
Where it talks about category and class ratings being required.
Seaplane is a class of the category airplane.
This is like the first week of ground school.
Old June 15th 07, 10:58 PM posted to rec.aviation.piloting
Steven P. McNicoll
m...
Where it talks about category and class ratings being required. Seaplane
Actually, I believe the class is "water".
Agreed.
An amphibian that sank? Flyingmonk Home Built 44 April 26th 06 09:54 PM
An amphibian that sank? Flyingmonk Piloting 40 April 26th 06 09:32 PM
Amphibian VTOL? Flyingmonk Piloting 6 January 6th 06 12:18 AM
Amphibian info need Alain Theroux - 2i Solutions Owning 0 July 21st 05 02:21 AM
New amphibian aircraft Sten-Anders Fellman Products 0 August 28th 04 11:47 PM
