Looking for a tool
Old June 17th 07, 01:02 AM posted to rec.aviation.homebuilt
Lou
Default Looking for a tool
A short time ago someone had posted a link to a tool that
could hold a screw so you could drill a hole for cotter pins.
I thought I had bookmarked it but just can't seem to find it.
Could anyone help?
Lou
Old June 17th 07, 02:47 AM posted to rec.aviation.homebuilt
Drew Dalgleish
Could anyone help?
Lou
Assuming that you mean bolt instead of screw. I just run a nut onto
the bolt and drill through both.
Old June 17th 07, 03:49 AM posted to rec.aviation.homebuilt
Dan[_2_]
Could anyone help?
Lou
If you insist on spending money Aircraft Spruce sells them.
Dan, U.S. Air Force, retired
Old June 17th 07, 12:30 PM posted to rec.aviation.homebuilt
Lou
I've looked at A/S and its not the one I'm looking for.
Yes, I could drill a hole in a nut, and I'll probebly end
up doing that, but the one I'm looking for has threaded
holes for different sizes and predrilled holes.
Lou
Old June 17th 07, 01:04 PM posted to rec.aviation.homebuilt
Dan[_2_]
Lou
Try this; take a brass bar, drill appropriate clearance holes, solder
an assortment of nuts over the holes such that the flats are parallel to
one edge of the bar, then drill holes in each nut. Viola, you have a
drilling fixture. When you want to drill a bolt screw it in to the
correct nut and make with a drill and, cello, you have a hole where you
want it.
If just want to drill a few holes just drill holes through the bar
such that the bolts just fit in, the technical term is "a tad snug" and
drill guide holes through the bar. Stuff a boll into a hole, drill and,
violin, you have it.
Old June 17th 07, 01:09 PM posted to rec.aviation.homebuilt
JP[_1_]
"Lou" wrote in
groups.com...
Lou
You're probably looking for this:
http://www.aircraft-tool.com/pdf/catalogs/ECat2006.pdf
page 75 - AERO SafTblock
JP
Old June 17th 07, 06:09 PM posted to rec.aviation.homebuilt
JP[_1_]
"Lou" wrote in
groups.com...
Lou
JP
Just google: aero saftblock
(It's called safety wire drill guide)
JP
Old June 17th 07, 05:27 PM posted to rec.aviation.homebuilt
Michelle P
Could anyone help?
Lou
V-block.
A/C tool kit Stuart & Kathryn Fields Home Built 13 March 20th 07 07:48 PM
Looking For a Tool Curtis Naval Aviation 1 October 20th 04 01:06 AM
Looking For a Tool Curtis Simulators 0 October 19th 04 08:58 PM
Looking For a Tool Curtis Soaring 0 October 19th 04 08:58 PM
xc tool. Todd Neidinger Piloting 8 July 22nd 04 04:29 PM
