I had thought a chandelle was really half a loop followed by a half
roll to get right side up, but most describe it as a climbing turn (almost like a wing over?). It was a long time ago, but I seem to remember being in an Aerobat and started a loop by diving and getting to maybe 140 kts before the pilot pulled back. The question nagging at me is, if in something like an Arrrow or a Mooney, if you were in a cruise at 140 knots would you have enough speed to pull back into a half loop to make a fast 180 degree change in turn in a tight space? I suppose I could calculate if one maintained 2 gs worth of backpressure what would happen (it would be a funny half loop, turn radius would get tighter and tighter as speed decreases and gravity started pulling at the tail instead of at the wheels, but real life experience is better than calculations, if anyone has such experience. |
wrote in message ups.com... I had thought a chandelle was really half a loop followed by a half roll to get right side up, but most describe it as a climbing turn (almost like a wing over?). You're describing an Immelmann. |
Thanks!
On Jun 29, 3:19 pm, "Steven P. McNicoll" wrote: wrote in message ups.com... I had thought a chandelle was really half a loop followed by a half roll to get right side up, but most describe it as a climbing turn (almost like a wing over?). You're describing an Immelmann. |
What you describe is an Immeleman. Front half loop followed by half roll to
upright. The opposite (half roll to inverted, followed by back half of loop) is a split S. Chandelle (a commercial maneuver, in the CPL PTS) is a climbing 180 deg turn. First 90 deg of turn, establish 30 deg AOB, and begin pitching, Second 90 deg of turn is slowly rolling wings level and increasing pitch such that the a/c goes into stall warning. Recovery is accelerate straight ahead (180 from initial heading) without losing altitude gained in the maneuver. Watson wrote in message ups.com... I had thought a chandelle was really half a loop followed by a half roll to get right side up, but most describe it as a climbing turn (almost like a wing over?). It was a long time ago, but I seem to remember being in an Aerobat and started a loop by diving and getting to maybe 140 kts before the pilot pulled back. The question nagging at me is, if in something like an Arrrow or a Mooney, if you were in a cruise at 140 knots would you have enough speed to pull back into a half loop to make a fast 180 degree change in turn in a tight space? I suppose I could calculate if one maintained 2 gs worth of backpressure what would happen (it would be a funny half loop, turn radius would get tighter and tighter as speed decreases and gravity started pulling at the tail instead of at the wheels, but real life experience is better than calculations, if anyone has such experience. |
The Visitor wrote:
I thought of it as a maximum performance climbing turn. And it is. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
wrote in message ups.com... I had thought a chandelle was really half a loop followed by a half roll to get right side up, but most describe it as a climbing turn (almost like a wing over?). It was a long time ago, but I seem to remember being in an Aerobat and started a loop by diving and getting to maybe 140 kts before the pilot pulled back. The question nagging at me is, if in something like an Arrrow or a Mooney, if you were in a cruise at 140 knots would you have enough speed to pull back into a half loop to make a fast 180 degree change in turn in a tight space? snip I don't fly a Mooney or Arrow, but the answer is probably yes, assuming we're talking about indicated airspeed, as opposed to true airspeed. I fly loops beginning at 140-150 knots IAS in my RV-6 (fixed pitch) fairly often. They require a 3.5 G initial pull, tapering off as the airspeed declines. With full power the loop results in an 800' altitude gain at the apex with about 80 knots of airspeed over the top of the loop. The Mooney or Arrow's constant speed props would have advantages over my RV's fixed pitch setup, although the RV has a higher power to weight ratio. Those two factors probably net out as a wash... By the way, this is a purely hypothetical answer. Don't try to prove or disprove it with the real hardware. KB |
wrote in message ups.com... It was a long time ago, but I seem to remember being in an Aerobat and started a loop by diving and getting to maybe 140 kts before the pilot pulled back. The question nagging at me is, if in something like an Arrrow or a Mooney, if you were in a cruise at 140 knots would you have enough speed to pull back into a half loop to make a fast 180 degree change in turn in a tight space? I suppose I could calculate if one maintained 2 gs worth of backpressure what would happen (it would be a funny half loop, turn radius would get tighter and tighter as speed decreases and gravity started pulling at the tail instead of at the wheels, but real life experience is better than calculations, if anyone has such experience. Assuming 140 knots and full power, I think most 4 place singles could complete an eliptical loop. Your right, maintaining back pressure and tighting the radius around the top would be necessary, but it could save your butt in a box canyon or downtown NY. I have actually done it in a 150, 172 and 182, no problem. But don't try it without a real emergency or the proper training and equipment. It can also kill some gyros. |
when you did it, did you wait until manovering speed before pulling
all the way back? I'd worry, in the Mooney, if the pilot in command (he loves being called that) pulled back to the stops at cruise. If you kept your wits about you, I'd guess firm back until I think 130 knots, then to the aft limit in that airplane, would probably only break a gyro or two, and not the backbone of the airplane. I don't know if its gyros are rated for more than 60 degrees back or pitch. I think the numbers would work out that we'd be well above stall at the top still pulling positive gees, then a roll to upright, with altitude in the bank. Be fun to try it in a simulator, but my personal PIC would not do it in the airplane unless there was building in front of him. |
wrote in message oups.com... when you did it, did you wait until manovering speed before pulling all the way back? I'd worry, in the Mooney, if the pilot in command (he loves being called that) pulled back to the stops at cruise. If you kept your wits about you, I'd guess firm back until I think 130 knots, then to the aft limit in that airplane, would probably only break a gyro or two, and not the backbone of the airplane. I don't know if its gyros are rated for more than 60 degrees back or pitch. First things first, don't over stress the aircraft under any circumstances, it shouldn't be necessary. You shouldn't need more than 2.5 Gs max, if that much. But keep the Gs on. As the aircraft slows, maintaining those Gs assures you the tightest possible loop radius, and is the quickest way over the top. In this case, unlike demonstration aerobatics, you want an elliptical loop. You shouldn't hit the stops until you get very near the top, and very slow, if even then. Nine times out of ten these days, you won't hurt the gyros, but there is no guarantee unless they are designed for such duty or can be caged. I think the numbers would work out that we'd be well above stall at the top still pulling positive gees, then a roll to upright, with altitude in the bank. Be fun to try it in a simulator, but my personal PIC would not do it in the airplane unless there was building in front of him. I'd recommend some fundamental aerobatic training to ALL pilots. Just make sure you have the proper equipment, and a good instructor. Nothing can prepare you more for the unexpected, and make you feel more at easy during your routine piloting. And an Immelmann as you describe, is a good move to practice often. |
| Thread Tools | |
| Display Modes | |
| F-15C in a tight turn | Tom Callahan | Aviation Photos | 1 | April 16th 07 07:58 PM |
| Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 05:47 PM |
| Tight Screw Causes Sea King Crash | Shiver Me Timbers | Rotorcraft | 0 | August 30th 04 05:12 PM |
| Fly tight for tight bomb patterns on the ground. | ArtKramr | Military Aviation | 120 | August 30th 04 09:42 AM |
| Tight patterns? | Bob Martin | Piloting | 51 | January 26th 04 09:42 AM |
