OK, how long before we can employ this in homebuilt aircraft?
Dan, U. S. Airforce, retired I wouldn't recommend it, as flutter is a BIG problem with flexible wings, tails, fins, etc. The safety issues outweigh any performance gains here for a homebuilt -- especially for a high-performance one. I think flexible winged craft could be safer. A really flexible and evenly-tapered wing, gradated from high to low density toward the core, would bend to allow its force to be spread over a large enough area to keep the force constant. A wing suit with both arm and leg wings would enable a person to "run" through the air, except that the motion would be closer to doggy paddling. Flying would be easier than scrambling up a flight of stairs on all fours. See the "SphericonWing" design at my webpage: http://patricktimony.tvheaven.com/photo3.html Patrick Timony |
![]() "patrick timony" wrote in message om... OK, how long before we can employ this in homebuilt aircraft? Dan, U. S. Airforce, retired I wouldn't recommend it, as flutter is a BIG problem with flexible wings, tails, fins, etc. The safety issues outweigh any performance gains here for a homebuilt -- especially for a high-performance one. I think flexible winged craft could be safer. A really flexible and evenly-tapered wing, gradated from high to low density toward the core, would bend to allow its force to be spread over a large enough area to keep the force constant. A wing suit with both arm and leg wings would enable a person to "run" through the air, except that the motion would be closer to doggy paddling. Flying would be easier than scrambling up a flight of stairs on all fours. See the "SphericonWing" design at my webpage: http://patricktimony.tvheaven.com/photo3.html Patrick Timony Kid, get your HEAD OUT OF THE CLOWDS. Man does not have enough strength to support or directly control flight loads. If he did, someone else would have done it by now. This is a sophisticated group, with much knowledge and experience on making flying machines, and man's muscles are used via mechanical advantage only, to direct flight, not support or sustain it. Make a deal with yourself. Build an airplane or two, then try building whatever you want to dream up. Then, you will clearly see what the problems and solutions are. -- Jim in NC |
Morgans wrote:
"patrick timony"... I think flexible winged craft could be safer. A really flexible and evenly-tapered wing, gradated from high to low density toward the core, would bend to allow its force to be spread over a large enough area to keep the force constant. A wing suit with both arm and leg wings would enable a person to "run" through the air, except that the motion would be closer to doggy paddling. Kid, get your HEAD OUT OF THE CLOWDS. Man does not have enough strength to support or directly control flight loads. If he did, someone else would have done it by now. This is a sophisticated group, with much knowledge and experience on making flying machines, and man's muscles are used via mechanical advantage only, to direct flight, not support or sustain it. Yea, and man doesn't have enough muscle to lift a thousand pounds of dirt in one load, which is why he invented the backhoe. You could make a man-powered suit with power assist, ala power steering, power brakes, or any other number of analogies. It just takes smaller power sources and actuators, and we're moving in that direction. Keep the dream alive. Here's a sort of rigid/flexible concept that works now. http://www.freewing.com/ Mike "never say never" Y. |
![]() "nafod40" wrote Yea, and man doesn't have enough muscle to lift a thousand pounds of dirt in one load, which is why he invented the backhoe. You could make a man-powered suit with power assist, ala power steering, power brakes, or any other number of analogies. It just takes smaller power sources and actuators, and we're moving in that direction. Keep the dream alive. Here's a sort of rigid/flexible concept that works now. http://www.freewing.com/ Mike "never say never" Y. Let's see, if we have a power steering type assist, and then we need power to run the assist, then that means we need a power source, like an engine. Do we still have man powered flight? NOPE By the way, anyone seen one of those man powered, power assisted flying units at your airport? Come on now, there must be at least one out there somewhere. -- Jim in NC |
"I think there is a man powered airplane somewhere. I remember reading
that a college class had built it to meet a challenge of flying a 1/4 mile (or thereabouts) course. It looked like a giant ultralight with a huge wingspan and was powered by a man (in very good shape) using a pedal system to drive the propeller. Totally impractical as a flying machine, but interesting anyway. Perhaps someone in the group will remember more about this accomplishment. Mike |
"Mike" wrote in message
m... "I think there is a man powered airplane somewhere. I remember reading that a college class had built it to meet a challenge of flying a 1/4 mile (or thereabouts) course. It looked like a giant ultralight with a huge wingspan and was powered by a man (in very good shape) using a pedal system to drive the propeller. Totally impractical as a flying machine, but interesting anyway. Perhaps someone in the group will remember more about this accomplishment. Mike You're thinking about the Gossamer Condor, which won the Kremer 50,000 pound prize for flying over a figure 8 course 1977, followed by the 1979 crossing of the English Channel to win the Kremer 100,000 pound prize by the Gossamer Albatross. Both were designed by Paul MacCready Jr and piloted by Bryan Allen. Only impractical in that Bryan Allen was a trained cyclist whereas most of us are not. Both amazing design and athletic feats. At the time of the challenge, the Gossamer Condor weighed 70 pounds, the pilot weighed 137 pounds. Wing span: 96 feet Wing area: 760 sq ft. Aspect ratio: 12.8 The wings were covered with 1/2 mil mylar sheet on top and 1/4 mil mylar sheets on the bottom. Canard area 93 sq ft. Length: 30 ft. Height 18 ft. Prop diameter: 12 ft. The total flight path was 1.35 miles, while the Kremer circuit itself was 1.15 miles flown in 6 minutes and 22.5 seconds for an average speed of 10.82 miles per hour. Don't have the figures for the Gossamer Albatross handy right now. Eric |
Mike wrote: "I think there is a man powered airplane somewhere. I remember reading that a college class had built it to meet a challenge of flying a 1/4 mile (or thereabouts) course. It looked like a giant ultralight with a huge wingspan and was powered by a man (in very good shape) using a pedal system to drive the propeller. Totally impractical as a flying machine, but interesting anyway. Perhaps someone in the group will remember more about this accomplishment. Mike There's the "Gossamer Albatross", that, in 1979 managed a *man*powered* flight across the English Channel. details available via google. |
