Ground control vs. clearance delivery for VFR
Old July 17th 07, 01:35 AM posted to rec.aviation.piloting
B A R R Y
Default Ground control vs. clearance delivery for VFR
On Mon, 16 Jul 2007 17:12:04 -0600, Newps wrote:
There's never a reason to have the transponder on any other setting than
ALT, unless otherwise directed by ATC.
I know. G It is on ALT when normally responding, ON is usually
for bad mode C responses. My miscommunication!
I was referring to transpoding vs. not transponding while taxiing.
Some of the Charlie and Bravo space I visit has equipment that reads
transponder codes on the ground. PVD ground knew the minute I
mentioned my parked cargo ramp location that I was not squawking 1200.
Old July 17th 07, 02:07 AM posted to rec.aviation.piloting
Newps
All ATC facilities have the ability to see transponders at any altitude.
All ATC facilities also have software to inhibit the display of
replies so the radar display doesn't get cluttered up on the airport.
You took my response to be only while flying. I meant it all inclusive.
There's never a reason to have your transponder on any other setting
than ALT, unless otherwise directed by ATC.
Old July 17th 07, 03:11 AM posted to rec.aviation.piloting
Don Poitras
How about to avoid the ****y tone in their request to turn it off 10
seconds after landing?
Don Poitras
Old July 17th 07, 12:35 PM posted to rec.aviation.piloting
Dan Luke[_2_]
"Don Poitras" wrote:
it all inclusive.
Never heard that, and I never turn mine off ALT.
Where'd you get bitched at?
Dan
T-182T at BFM
Old July 17th 07, 12:58 PM posted to rec.aviation.piloting
B A R R Y[_2_]
All ATC facilities also have software to inhibit the display of replies
I did not know that. Thanks!
Old July 17th 07, 02:10 PM posted to rec.aviation.piloting
Newps
Why would ATC tell you to turn it off shortly after landing? There's no
reason for that. Tell him to properly set up his ARTS software.
Old July 17th 07, 03:24 PM posted to rec.aviation.piloting
Mike Isaksen
"Dan Luke" wrote ...
Hi Dan,
Now that you got one of them there "fancy pants" airplanes G, does it turn
the ALT on and off for you automatically?
  #28
Old July 17th 07, 04:14 PM posted to rec.aviation.piloting
Dennis Johnson
Newps,
I've always found your postings here helpful and a valuable perspective on
the air traffic control system. I'm not disputing the wisdom of your
suggestion to have the transponder in the "ALT" position whenever it's on,
including while on the ground, but the AIM says,
4-1-19 a.3. ...transponders should be adjusted to the "on" or normal
operating position as late as practicable prior to takeoff and to "off" or
"standby" as soon as practicable after completing landing roll...
I know the AIM is not regulatory, but I often find comfort in following its
suggestions in the hope that it represents genuinely good advice. Do you
think that this passage from the AIM represents outdated policy that is no
longer relevant?
Thanks,
Dennis
  #29
Old July 17th 07, 04:41 PM posted to rec.aviation.piloting
Gig 601XL Builder
Dennis Johnson wrote:
Newps,
perspective on the air traffic control system. I'm not disputing the
wisdom of your suggestion to have the transponder in the "ALT"
position whenever it's on, including while on the ground, but the AIM
says,
"off" or "standby" as soon as practicable after completing landing
roll...
following its suggestions in the hope that it represents genuinely
good advice. Do you think that this passage from the AIM represents
outdated policy that is no longer relevant?
Thanks,
Dennis
The AIM statement and having the Xponder set to ALT when it is on are not
counter to one another.
  #30
Old July 17th 07, 07:19 PM posted to rec.aviation.piloting
Newps
Newps,
longer relevant?
Yes. I know that to be the case.
AFSS Clearance Delivery Stan Prevost Instrument Flight Rules 2 January 4th 05 04:43 PM
clearance delivery question PaulH Instrument Flight Rules 13 November 19th 04 09:19 PM
Ground speed control Roger Long Piloting 2 July 7th 04 10:13 PM
Pop-up IFR from Clearance Delivery Andrew Sarangan Instrument Flight Rules 43 March 28th 04 07:20 PM
AFSS clearance delivery Dan Luke Instrument Flight Rules 7 February 9th 04 12:56 AM
