It's been a while since I flew with MS flight simulator and I got back
in the cockpit the other day. I got CH yoke and rudder pedal and installed FSX. FSX is great but I have a problem (and in a way I think happened in older versions of MSFS): when I use the rudder to maintain runway alignment, it seems like the plane is jerking left and right a few times until its settles back. As I am in short final I try to use the rudder to keep myself aligned. If I apply right rudder, as soon as I let it go the plane jerks left then right and left until the yaw dampens. Now, I fly the Cessna 172 (I didn't mention this was done in C-172) in real life I the plane does not react that way. I turned P factor, gyro and all that other fun stuff off but I still see the problem. I even tried to lower the rudder pedals sensitivity but that did not help either. If anyone knows what the problem is or has any idea on a direction, I would appreciate the help. Thanks. |
Check the sensitivities, and increase or reduce the dead zones accordingly.
Crash Lander -- http://straightandlevel1973.spaces.live.com/ I'm not always right, But I'm never wrong! "SilkB" wrote in message oups.com... It's been a while since I flew with MS flight simulator and I got back in the cockpit the other day. I got CH yoke and rudder pedal and installed FSX. FSX is great but I have a problem (and in a way I think happened in older versions of MSFS): when I use the rudder to maintain runway alignment, it seems like the plane is jerking left and right a few times until its settles back. As I am in short final I try to use the rudder to keep myself aligned. If I apply right rudder, as soon as I let it go the plane jerks left then right and left until the yaw dampens. Now, I fly the Cessna 172 (I didn't mention this was done in C-172) in real life I the plane does not react that way. I turned P factor, gyro and all that other fun stuff off but I still see the problem. I even tried to lower the rudder pedals sensitivity but that did not help either. If anyone knows what the problem is or has any idea on a direction, I would appreciate the help. Thanks. |
Personally I find the horrible calibration problems of FS9 / FSX to be one
of the key shortcomings of the product. You can recalibrate, but ultimately to get the calibration to something comfortable you need to use the calibration functions in the third party product FSUIPC. Even then, it's a lot of work to figure out how to do FSUIPC calibrations well, and the calibrations often need to be redone many times. To me it is just ridiculous that Microsoft doesn't realize a lot of people are buying third party flight controls and try to reduce this to a much easier set of wizards and templates. It undoes a lot of the fantastic simulator work to have a one inch deflection of a rudder pedal send you off in a wild oscillation to either side of the runway. -- Will "SilkB" wrote in message oups.com... It's been a while since I flew with MS flight simulator and I got back in the cockpit the other day. I got CH yoke and rudder pedal and installed FSX. FSX is great but I have a problem (and in a way I think happened in older versions of MSFS): when I use the rudder to maintain runway alignment, it seems like the plane is jerking left and right a few times until its settles back. As I am in short final I try to use the rudder to keep myself aligned. If I apply right rudder, as soon as I let it go the plane jerks left then right and left until the yaw dampens. Now, I fly the Cessna 172 (I didn't mention this was done in C-172) in real life I the plane does not react that way. I turned P factor, gyro and all that other fun stuff off but I still see the problem. I even tried to lower the rudder pedals sensitivity but that did not help either. If anyone knows what the problem is or has any idea on a direction, I would appreciate the help. Thanks. |
SilkB wrote:
FSX is great but I have a problem (and in a way I think happened in older versions of MSFS): when I use the rudder to maintain runway alignment, it seems like the plane is jerking left and right a few times until its settles back. I have noticed that with all of the MS products. I think it has to do with the pot and digitizing algorithm to read that all pots. I have yet to seea smooth algoritm in this regard. I suspect that MS is just plain lazy in not polishing up this facet. A LOT better can be done. As I am in short final I try to use the rudder to keep myself aligned. If I apply right rudder, as soon as I let it go the plane jerks left then right and left until the yaw dampens. Linearity and lack of baclash are words not found in MS dictionary. It reminds me how stupid they can be. About the same mentality that alloewed FS to fly into (through) buildings. 9-11 resulted, IMHO. Now, I fly the Cessna 172 (I didn't mention this was done in C-172) in real life I the plane does not react that way. I turned P factor, gyro and all that other fun stuff off but I still see the problem. I even tried to lower the rudder pedals sensitivity but that did not help either. I always find my (real) flying is a lot smoother after a few FS sessions. My landngs are also much better! If anyone knows what the problem is or has any idea on a direction, I would appreciate the help. Learn to ive with it. Be alert for (non-MS) fixes. Angelo Campanella |
"angelo Campanella" wrote in message
news ![]() Linearity and lack of baclash are words not found in MS dictionary. It reminds me how stupid they can be. About the same mentality that alloewed FS to fly into (through) buildings. 9-11 resulted, IMHO. Angelo Campanella So you believe that Microsoft is responsible for 9-11? Hope you got your flame proof jocks on mate. Crash Lander -- http://straightandlevel1973.spaces.live.com/ I'm not always right, But I'm never wrong! |
Guys,
Thanks for all you comments. The solution lies in the CH control manager. At first, I didn't fiddle with it because I thought MS knew what they were doing but I guess CH knew better. What did the trick for me was not only the sensitivity but also being able to control the curves. It took a lot of iterations until I got to something I can use - I am sure I will have to play with it more in the future. Silk |
On Jul 17, 8:07 pm, angelo Campanella wrote: SilkB wrote: FSX is great but I have a problem (and in a way I think happened in older versions of MSFS): when I use the rudder to maintain runway alignment, it seems like the plane is jerking left and right a few times until its settles back. I have noticed that with all of the MS products. I think it has to do with the pot and digitizing algorithm to read that all pots. I have yet to seea smooth algoritm in this regard. I suspect that MS is just plain lazy in not polishing up this facet. A LOT better can be done. As I am in short final I try to use the rudder to keep myself aligned. If I apply right rudder, as soon as I let it go the plane jerks left then right and left until the yaw dampens. Linearity and lack of baclash are words not found in MS dictionary. It reminds me how stupid they can be. About the same mentality that alloewed FS to fly into (through) buildings. 9-11 resulted, IMHO. Now, I fly the Cessna 172 (I didn't mention this was done in C-172) in real life I the plane does not react that way. I turned P factor, gyro and all that other fun stuff off but I still see the problem. I even tried to lower the rudder pedals sensitivity but that did not help either. I always find my (real) flying is a lot smoother after a few FS sessions. My landngs are also much better! If anyone knows what the problem is or has any idea on a direction, I would appreciate the help. Learn to ive with it. Be alert for (non-MS) fixes. Angelo Campanella Guys, Thanks for all you comments. The solution lies in the CH control manager. At first, I didn't fiddle with it because I thought MS knew what they were doing but I guess CH knew better. What did the trick for me was not only the sensitivity but also being able to control the curves. It took a lot of iterations until I got to something I can use - I am sure I will have to play with it more in the future. Silk |
Crash Lander wrote: "angelo Campanella" wrote in message news ![]() Linearity and lack of backlash are words not found in MS dictionary. It reminds me how stupid they can be. About the same mentality that alloewed FS to fly into (through) buildings. 9-11 resulted, IMHO. Angelo Campanella So you believe that Microsoft is responsible for 9-11? Hope you got your flame proof jocks on mate. Agreed... I have another: Mayor Daley's decision to trash Meigs Field (for general aviation use) might have been inspired by FS's use of Meigs Field as home base, noting that the capability to fly to the Sears Tower as noted.. Just musing....one never knows what permeates the minds of politicians, paranoid as they may be. Angelo campanella |
politicians, paranoid as they may be. Just because you're paranoid doesn't mean you aren't being followed... ![]() BTW - I'd go to a different brand of glue...... |
On Jul 20, 6:43 am, "ManhattanMan" wrote:
angelo Campanella wrote: politicians, paranoid as they may be. Just because you're paranoid doesn't mean you aren't being followed... ![]() BTW - I'd go to a different brand of glue...... "Paranoid? Paranoid!?! WHO Told You I Was Paranoid!!!???!!!" ;O) Jay Beckman PP-ASEL Chandler, AZ www.pbase.com/flyingphotog |
| Thread Tools | |
| Display Modes | |
| FLIGHT SIMULATOR X DELUXE 2006-2007 (SIMULATION) 1DVD,Microsoft Flight Simulator 2004, and Addons, FLITESTAR V8.51 - JEPPESEN, MapInfo StreetPro U.S.A. [11 CDs], Rand McNally StreetFinder & TripMaker Deluxe 2004 [3 CDs], other | T.E.L. | General Aviation | 0 | October 15th 06 12:38 AM |
| FLIGHT SIMULATOR X DELUXE 2006-2007 (SIMULATION) 1DVD,Microsoft Flight Simulator 2004, and Addons, FLITESTAR V8.51 - JEPPESEN, MapInfo StreetPro U.S.A. [11 CDs], Rand McNally StreetFinder & TripMaker Deluxe 2004 [3 CDs], other | T.E.L. | Simulators | 0 | October 14th 06 10:08 PM |
| Flight Sim rudder pedals. | news.ozemail.com.au | Simulators | 5 | May 23rd 06 12:33 AM |
| problem when installing flight simulator 2004 | mostafa il idrissi | Simulators | 3 | March 28th 05 08:51 PM |
| Value of rudder for MS Flight Simulator | Darrell Criswell | Simulators | 10 | January 6th 05 03:41 PM |
