#11
On Wed, 15 Aug 2007 12:03:41 -0400, Jonathan Goodish wrote:
The network displays cloud to ground strikes. How does it work that it can discern the difference? - Andrew |
On Wed, 15 Aug 2007 08:02:51 -0400, "Peter R."
wrote: On 8/14/2007 7:51:18 PM, Peter Clark wrote: It should be noted that the KDR510 FIS uplink unit from Bendix/King has also been obsoleted with 6/08 EOL. Their replacement is the KDR610 XM unit. Interesting. What is Bendix doing to transition their customers to this new unit? Providing the equipment for free? Labor to install it? Little to nothing. They're providing the equipment at reduced cost (pro-rated based on when you purchased it, assuming you have a current working FIS subscription). Antenna is extra, installation is extra (and of course you have to yank the headliners out to run the cabling for the on-top-of-aircraft antenna rather than the underneath FIS antenna, etc etc etc). Including labor it's looking like around $3500 - $5500 per aircraft to upgrade depending on time since the KDR510 was purchased. They already turned off the annual subscription option too so you're down to 30 or 90 day increments with the commeserate increase in cost over the old annual package. They really want people off this stuff right now. Personally I'm going to a GMX200 and GDL69A in my Malibu when the time comes this fall. I'm going to have it done as part of the dual 530W upgrade (since everything has to be ripped apart anyway, Piper didn't put the good enough the GPS antenna wiring in when it was manufactured) once Meggitt/S-Tec comes out with the MAGIC software update. Haven't decided what to do with the Cessnas yet. |
On 8/15/2007 4:34:45 PM, Peter Clark wrote:
Little to nothing. They're providing the equipment at reduced cost (pro-rated based on when you purchased it, assuming you have a current working FIS subscription). Antenna is extra, installation is extra (and of course you have to yank the headliners out to run the cabling for the on-top-of-aircraft antenna rather than the underneath FIS antenna, etc etc etc). Including labor it's looking like around $3500 - $5500 per aircraft to upgrade depending on time since the KDR510 was purchased. Wow, it seems that B/K is making a customer's decision to move over to XM or WSI a bit easier. -- Peter |
"Jonathan Goodish" wrote in message
... In article .com, Paul kgyy wrote: Someone asked a while back what the source was for the opinion that XM shows only cloud to ground lightning. This is explicitly stated in the XM manual that came with my new 396. Most weather providers obtain lightning data from the National Lightning Detection Network, which is operated by Vaisala. The network displays cloud to ground strikes. WSI uses data from their own lightning detection network, which can detect both cloud to cloud and cloud to ground. I'm not sure what their InFlight product displays. In any case, both products pale in comparison to sferics devices for in-flight lightning detection. The engineer in me is dying to know how the sensors knows the difference between cloud to ground and cloud to cloud. Anybody know. Danny Deger www.dannydeger.net JKG |
![]() "Jonathan Goodish" wrote in message ... Most weather providers obtain lightning data from the National Lightning Detection Network, which is operated by Vaisala. The network displays cloud to ground strikes. Thanks! I just learned something. You can get a free lightning map he https://thunderstorm.vaisala.com/tux...r/explorer.jsp It is for the entire USA, and only updated every 20 minutes, so you can hardly use it to pick your way through the cells, but it could sure help you decide if it is healthy to go flying. |
![]() "Danny Deger" wrote in message ... The engineer in me is dying to know how the sensors knows the difference between cloud to ground and cloud to cloud. Anybody know. Danny Deger www.dannydeger.net Polarity? Maybe something with the pulse shape? |
On Aug 15, 8:16 pm, "Danny Deger" wrote:
The engineer in me is dying to know how the sensors knows the difference between cloud to ground and cloud to cloud. Anybody know. Cloud to ground lightning creates a unique RF signature. By recording these radio waves and by using time from GPS satellites to corrdinate those receptions, then the NLDN could pinpoint those ground strikes. When too many ground strikes occur, the network tends to become overloaded; does not detect all strikes. Then the NY Times made some inquires in response to a lightning strike in the area of the former WTC that killed one person. Direct lightning strikes known to have hit both the WTC and Empire State Building (on average 25 and 40 times annually) were not detected; apparently did not create that RF signature. No followup information is available as best I can tell. |
![]() "w_tom" wrote Cloud to ground lightning creates a unique RF signature. By recording these radio waves and by using time from GPS satellites to corrdinate those receptions, then the NLDN could pinpoint those ground strikes. When too many ground strikes occur, the network tends to become overloaded; does not detect all strikes. In a gross simplification, cloud to ground flashes produce disturbances in the LF and VLF EM bands. They are received over very long distances, so they are easier to get a map of over a complete region, even with a sparse location of sensors. Probably why it is desirable. Cloud to cloud flashes are mainly in the VHF range, and therefore are line of sight. For a very complete explanation, see https://www.thelightningpeople.com/htm/about/events/ildc/ildc2000/docs/03_CUMMINS.pdf -- Jim in NC |
On Aug 17, 2:35 am, "Morgans" wrote:
In a gross simplification, cloud to ground flashes produce disturbances in the LF and VLF EM bands. They are received over very long distances, so they are easier to get a map of over a complete region, even with a sparse location of sensors. Probably why it is desirable. Cloud to cloud flashes are mainly in the VHF range, and therefore are line of sight. Now explain why the system saw no strikes when 25 and 40 direct lightning strikes hit the Empire State Building and WTC annually. I have long been waiting for that answer. Do strikes to tall buildings not create LF and VLF EM radiation? |
Lightning anyone? | Frode Berg | Piloting | 11 | May 16th 09 05:04 PM |
Warm Weather Pilots, Cold Weather Ops | john smith | Piloting | 3 | December 2nd 04 04:00 PM |
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 04:03 PM |
