![]() "Wayne Paul" wrote in message ... According to http://www.aircraftone.com/aircraft/..._7_79001kz.asp there are two registered in the US; however, there is a note that the one in Placerville, CA may not be airworthy. This is a case where the registration files can be particularly difficult to use, since most BG-7s were apparently homebuilts. For example: a homebuilt Briegleb BG-7 built by John Doe might be registered as a "Doe BG7"- Also, the sailplane directory mentions that modifications were common, including spoilers, cockpit mods, fuze lengthening, and vertical fin mods. The bottom line is that there may be several BG-7s in the USA hiding under assumed names and obscured with clever disguises. Vaughn |
WTB: Plans for Briegleb BG-12 BD | noel56z | Soaring | 1 | September 9th 05 12:35 AM |
Briegleb 12B - Opinions? | Eggs | Soaring | 22 | December 31st 03 07:20 PM |
