"James M. Knox" wrote in message
I asked Phil Boyer what he thought of it, namely would it help attract new pilots. He said essentially no, he expected pretty close to zero (and admittedly any is better than none) new pilots. I don't know. I would think that being able to buy a brand new Zodiac 601 XL, ready-to-fly for $42,500 would be welcome news to flight schools. The Rotax engine will also burn 90 octane mogas which should be welcome as well. The Zodiac has aluminum skin and can be tied down, rather than hangared; it should work almost identically to a Piper Tomahawk for less money. Perhaps this could translate to more introductory rides and perhaps to a larger rental fleet. I think this could compliment local EAA chapters since this same plane can be assembled from a kit. The really nice part of this is that with Light Sport, the kit could be more than 49% assembled by the factory. With more complete assembly and higher volumes, the cost could also drop a bit as efficiency would increase. |
"Brent Rehmel" wrote in
news:dNpbb.540612$o%2.237741@sccrnsc02: I don't know. I would think that being able to buy a brand new Zodiac 601 XL, ready-to-fly for $42,500 would be welcome news to flight schools. The Rotax engine will also burn 90 octane mogas which should be welcome as well. The Zodiac has aluminum skin and can be tied down, rather than hangared; it should work almost identically to a Piper Tomahawk for less money. Perhaps this could translate to more introductory rides and perhaps to a larger rental fleet. Hopefully you will be correct. A significant part of the per hour cost of a rental is the "return on investment" - especially for the rare school that has nicer looking (newer) planes. It's not entirely clear yet exactly how all this could translate for those pursuing a regular PP-ASEL. For example, could you do all your training in a Zodiac certificated under Light Sport but still get a regular PP ticket? ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
... It's not entirely clear yet exactly how all this could translate for those pursuing a regular PP-ASEL. For example, could you do all your training in a Zodiac certificated under Light Sport but still get a regular PP ticket? Yes, you can. The main distinction is the Instructor's rating. You can train in a Light Sport aircraft under a Light Sport instructor and get a Light Sport Pilot's License. However, if your instructor has a regular instructor rating then the aircraft is promoted and counted the same as a certified aircraft; you could get a full PP License from a regular instructor in a Light Sport aircraft. If your instructor only has a Light Sport instructor rating he can only train in Light Sport aircraft and you can only get a Light Sport license from him. However, even if you train under a Light Sport Instructor, there is nothing to stop you from adding the extra hours and extending your rating to a full Private Pilots License. Basically, all of your flight hours from Light Sport count toward a PP License. There would be some additional ground school and a little more instructor time (with a regular instructor) since Light Sport does not include night flying or landing at controlled airports. You would also need a medical since Light Sport doesn't require this. In other words, most people solo in 10 - 20 hours and then need to fly additional hours to have 40 before they can get a PP License. If you had 40 hours logged flight time under Light Sport then you would only need the extra instruction but not additional flight time to get a PP License. The reason this is significant is because in the past we have had only two kinds of aircraft: certified and experimental. I don't believe you are allowed to do instruction in an experimental, but even if you can, this wouldn't be practical anyway since a flight school would have to asemble 51% of each aircraft. In contrast, Light Sport becomes a third classification; you can buy a non-certified Light Sport aircraft already assembled and flyable. And, you are allowed to do instruction in this aircraft. Interestingly enough, some of the characteristics of Light Sport aircraft get promoted depending on the Pilot's rating. So, for example, a Light Sport pilot flying a Light Sport aircraft cannot fly at night, however, if the pilot has a PP license then the aircraft can. In other words, the aircraft is limited by the pilot's rating, with a PP License you can treat the aircraft the same as a certified aircraft. This should provide exactly what we need which is a step in between ultralights and certified aircraft. For example, right now, ultralight time counts for nothing. However, many ultralights could be designated Light Sport and the time could actually be logged after some intial Instructor time. Yes, there is a distinction between weight shift and regular control; you could not, for example, obtain a Light Sport License with only weight shift time and then fly regular aircraft, you would need time and an instructor endorsement similar to a type rating. |
![]() "Brent Rehmel" I don't believe you are allowed to do instruction in an experimental, \ You can, for example buy a homebuilt, them hire an instructor to give you dual in your homebuilt. -- Jim in NC |
![]() "Morgans" wrote in message You can, for example buy a homebuilt, them hire an instructor to give you dual in your homebuilt. Okay, that's what I thought. A flight school couldn't use one. This is quite a difference because flight schools will be able to use light-sport aircraft. |
I don't believe you are allowed to do instruction in an experimental, but even if you can, this wouldn't be practical anyway since a flight school would have to asemble 51% of each aircraft. As an instructor you can instruct in your own homebuilt with an EAA exemption... but not primary instruction. Check out "Experimental Aircraft Rentals": http://www.avweb.com/news/homeblts/182021-1.html Eric |
![]() "James M. Knox" wrote in message It's not entirely clear yet exactly how all this could translate for those pursuing a regular PP-ASEL. For example, could you do all your training in a Zodiac certificated under Light Sport but still get a regular PP ticket? In case my previous post is confusing, I'll try to make this a bit more orderly. 1. Ultralight. Time in an ultralight can be logged and used toward a sport pilot certificate.The ultralight would not need to be classed as a light-sport aircraft. 20 hours of logged ultralight time with proper instruction would make the pilot eligible for a sport pilot certificate. Ultralight time cannot however be used for a higher rating than sport pilot. This would make most current ultralight pilots eligible for a sport pilot certificate with only a little ground school and an instructor's endorsement. 2. Sport pilot. You can receive a sport pilot certificate with 20 hours flight time. With 150 logged hours and 100 hours as pilot in command, you can apply for a flight instructor certificate with sport pilot rating; this is not the same as a regular instructor certificate. This is basically a sport pilot with an instructor rating; and this instructor can only give instruction for sport pilot. The distinction is that this instructor could have 100 hours in an ultralight counting as part of his hours and only needs 50 hours in a regular aircraft. 3. Higher ratings. All logged time and instruction for sport pilot is credited to higher ratings. 4. You should be able to obtain a private pilot certificate in a light-sport aircraft (like a Zodiac) if the instructor has a regular instructor rating and not merely a sport pilot instructor rating. Because the pilot has a rating higher than sport pilot, the aircraft is counted the same as a certified aircraft. 5. A private pilot certificate encompasses sport pilot; so, the holder of a private pilot's license is already qualified for everything in sport pilot except as regards specific type ratings. For example, to fly a powered chute, the private pilot would still need instruction for a powered chute and a logbook endorsement from reviewer who was not the instructor. This is basically the same as is currently done for sailplanes, lighter than air, and hot air balloons. The new regulations simply add weight shift and powered chutes as distinct types. Similarly, a regular instructors rating encompasses the sport pilot instructors rating. Regular instructors can give instruction for sport pilots without any additional requirement other than a minimum of 5 hours logged pilot in command time in the specific make and model used for instruction. |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
