Unconventional uses for avionics
Old September 30th 03, 03:47 PM
George R. Gonzalez
Default Unconventional uses for avionics
What's some of the unusual uses for avionics you've heard of?
I'll start off with a few:
Some airrline pilots turn on the weather radar during takeoff, their
superstition
is that it scares away birds.
During WWII, there was just enough space between some tubes in one radio set
to
hide a thin flask of hooch. A later model of the same radio was much
disliked,
as the design was perhaps changed intentionally to eliminate this
cubby-hole.
Old September 30th 03, 04:34 PM
Mike Marron
superstition is that it scares away birds.
to hide a thin flask of hooch. A later model of the same radio was much
disliked, as the design was perhaps changed intentionally to eliminate this
cubby-hole.
Don't know how "unusual" this is, but during an emergency under a
very low ceiling with a fast moving front approaching I've used my
handheld GPS (w/moving map) for NOE navigation which possibly
saved my life.
Old September 30th 03, 07:45 PM
WaltBJ
"George R. Gonzalez" wrote in message news:jIgeb.639605$Ho3.131537@sccrnsc03...
Hoho:
1) On long XCs in the T33 tuning to the 'bottom' on the VOR would
yield a commercial FM radio station and music, etc. (ISTR that was
108.3mhz)
2) The F102A's upper electronics bay would hold two adults with the
bay door shut so the space was utilized a lot on flights from Canada
to the US for other (ahem) freight - like eight cases . . . I
understand the same opportunity existed in the F89 series, accessed
from a panel above and between the engine exhausts, although this,
strictly speaking, wasn't an electronics bay.
WaltBJ
Old September 30th 03, 09:59 PM
Buzzer
Not electronics, but chaff tanks on EB-57s had been known to carry
smoked hams, shrimp, and beer.
Old September 30th 03, 11:27 PM
Engine sling compartments on Lancasters, wheel well fairings on
P2V-7's and the Hydraulics bay between the bomb bay's on the
Argus were all the sweet spots for transporting 'goods' when
homeward bound from jaunts to Bermuda, Lajes and other ASW
haunts.
(memories of CC for a buck a fourty...Bacardi's two bucks a
fourty or Cockspur Rum for SEVENTY CENTS!!
-Gord.
Old October 1st 03, 12:23 AM
Frank May
Don't know how "unusual" it is, but when ADF's were common, they were
used to point out lightning, long before there was a "Strikefinder",
which I've heard was developed from a cheap ADF.
Old October 1st 03, 04:41 AM
WaltBJ
"Gord Beaman" ) wrote in message . ..
SNIP:
Chaff tanks! 2 ALE-2s on a T33, call ahead, the dealer would be there
at BaseOps at Dow AFB with 300 lobsters - 150 per tank, seaweed and
ice and two quick ops-stop hops back to Homestead FL! Quite a sight to
see the bugs crawing about the 319th FIS ramp before the feast.
Walt BJ
Old October 1st 03, 04:58 AM
Chad Irby
I saw a guy crack some walnuts with a processor from an ALR-46 RWR once
(a hundred thousand bucks worth of electronics). The funny part was
that it was a repair action (the cards inside got loose, and the common
way to reseat them was to undo some lock screws and whack the thing on a
solid surface from a couple of inches up).
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old October 1st 03, 07:19 AM
Jim Thomas
It wasn't really avionics, but in the bad old days when lots of us
smoked (and could, in the A-1), a pilot who forgot his lighter could
light up by using the light bulb in the gun sight (unscrew the fitting,
turn the sight on, hold against cigarette).
Jim Thomas
superstition
to
disliked,
cubby-hole.
