Captain Brian Udell, an F-15E fighter pilot will acknowledge the
anniversary of that fateful night without celebration because his Weapons Officer, Captain Dennis White, was killed during his ejection - or drowned after parachuting into a heavy sea at night. Udell miraculously survived one of the fastest known ejections in history at more than 780 mph. But exposing his body to the impact of supersonic speed had its special price tag. On a pitch dark evening, Udell and White took off from Seymour-Johnson AFB, in a four-ship formation. Their F-15E's were missioned to fly out over the Atlantic, split into pairs, then turn and engage. " We'd turn around and come at each other like we were in a jousting match", said Udell. But that dark night, they had to rely totally on their internal radar to ensure they'd never fly dangerously close to the opposing pair. Udell and White were in one of those turns when their tragic saga began. "I was reading my heads-up display, and it showed me in a 60-degree turn with my nose tilted 10 degrees down and going 400 knots at 4,000 feet. Perfect ," Udell said. "But as we're in this turn, I start hearing a wind rush - sort of like the sound you hear when you're increasing your speed down the highway and have to turn up your radio. But in a jet, this kind of wind rush usually comes when you're accelerating in excess of 500 knots." "I flipped on the electronic attitude direction indicator. It tells you if you're going up or down, making a right or left turn, going upside down or right side up, how fast you're going, and what altitude you're at. And it says I'm headed straight for the earth at about 600 knots [nearly 700 mph]." Because he didn't know which set of instruments was telling the truth, Udell moved his controls .. back and forth. The electronic back up system changed, but the heads-up display was stuck .. and they were screaming down toward the dark ocean below like a giant lawn dart. " The minimum altitude before ejecting out of an out-of-control aircraft is 10,000 feet. And the maximum safe ejection using our ACES II ejection seat was 600 knots. So I had to make a quick decision." "By this time we had penetrated 10,000 feet . . and we were exceeding 600 knots," on a a pitch black night, with no horizon to work with. I shouted : ' Bail out ! Bail out ! A second or two later, while descending rapidly through 4,500 feet and traveling faster than a rifle bullet . . White ejected. Passing through 3,000 feet at more than 780 mph - the pilot Udell ejected into the black. " I made the decision to bail out at 10,000 feet, got into good position and pulled the handles at 6,000 feet, left the aircraft at 3,000 feet, and got my parachute open at just under 1,000 feet," he said, taking a deep breath. "So if you crunch the numbers, I had about a half second to spare. If I'd waited for more than a half second, I would have impacted the water still in the seat," he added [ clapping his hands together in a sobering smack that echoed through the room]. As Udell floated to earth at the end of a parachute, he couldn't remember pounding into those granite-hard shock waves as his unarmored body pierced the sonic barrier. Those three seconds that sent all 190 pounds of him hurtling at a supersonic velocity appear mercifully lost forever." I don't know if it was because of the trauma my body went through, or the terror of : ' This is happening ! ' " he said [ his eyes widening.] Now, slowly descending, Udell felt as though he'd been struck by a train. His helmet and oxygen mask had been ripped from his head. His gloves and watch also were torn off. With the zippers still closed, his wallet and a water bottle had flown through his G-suit pockets. Beneath his flight suit, his T-shirt was shredded and his shoes laces were imbedded into the leather. Udell had no clue to the extent of his injuries, and began going through his post-ejection checklist. " You check the parachute canopy to make sure it's deployed properly ," said Udell. " I wasn't dropping like a rock, I figured it must be OK. and no visor or oxygen mask to be concerned with since my entire helmet had been blown off." He attempted to inflate his life preserver, but it had been shredded in the ejection. He figured he'd better reel in his life raft [that automatically deploys during ejection] to ensure he had some kind of flotation device when entering the water. That's when he discovered his left arm was injured. He hauled in the raft with his teeth and right arm. "Just about the time I got my hand on the raft, I hit the water." His struggle to get into the raft then began. He'd been trained in different techniques to board the one-man boat, but with four good limbs. He was down to one. An even that one limb had been dislocated . .. but somehow a shoulder had popped back into place. After making several unsuccessful attempts, before he simply stopped struggling and started praying. "This was notput-your-hands-together-and-bow-your-head-praying," Udell said candidly. "This was face-to-face, ' Hey, God . . I need your help' kind of praying." He gave it one more try, and somehow managed to inch his way onto the life raft. Sitting inside the rubber boat, he had his right leg straight out in front of him except for the part below the knee which dangled at an obscene 90-degree angle over the side. With his single good arm he grabbed the lower leg and jerked it into the raft. It flopped 180 degrees in the other direction. He adjusted it until the entire limb pointed the same direction. Then he did the same for his left ankle that had twisted around 180 degrees in another direction. " There was just nothing fastening them all togeth-er and the skin around them was distended out of proportion," he said, shaking his head. Once he had crudely immobilized both useless legs and his useless left arm, Udell searched his 6-foot 1 frame for other injuries. Finding nothing life-threatening he let his training take over and clicked into a prevent-shock mode. Out of an emergency pack he drank some water .. then he tried to get warm. " When the raft deploys, only the main donut ring inflates," he explained. " The raft's bottom and the side spray shields must each be manually inflated. Otherwise, I'm still hanging down in the water, and the waves were crashing over me." At that point, chilled to the bone, Udell tried to inflate the bottom section of the raft. "But when I first put the inflation tube in my mouth and tried to blow, I couldn't create a seal around the tube," he said. " I reached up and touched my face for the first time and it felt like a dish of kid's Play Dough. My lips were especially deformed. During the ejection, some blood vessels and underlying soft tissue in my face had burst and my whole face had no definition." Despite his desperate situation, he laughed when considered that he looked like Mush Mouth in a Fat Albert cartoon. "I stuck the tube back in my mouth," he said, still chuckling. " but the only way I could get a seal around the tube was to hold it between my teeth then clamp my fingers of my one good around my lips. My lips protruded beyond my hand's first three fingers, so they were hanging out there pretty far." Udell inflated the bottom of the raft, and finally puffed up the spray shields. And after bailing out water with plastic bags from his survival kit, he finally began to warm." I was exhausted and wanted to sleep . . but was afraid I'd never wake up again," he said. Meanwhile, the three other F-15E crews, incredibly had managed to pinpoint the crash site [within two miles] based on his last radio communications. The Coast Guard was on the way. Udell spent four hours in the night water before a Coast Guard helicopter found him. Even though his bulging lips could barely form the syllables, Udell kept hollering out to the empty sea for his flightmate: " DENNNNNNISSS ! " ... No answer. He also thought of his wife, Kristi who was four months pregnant with their first child. Using an emergency radio, he directed the Coast Guard helicopter to his location. " Because I didn't want the rotor wash to knock me out of the raft, I asked them not to (hover) too close," he said. Aviation Survivalman Jim Peterson fished Udell out of the raft and fastened him into a litter. "He was in a lot of pain, but he just bit his lip and dealt with it," Peterson said. "I even accidently bumped his legs a few times, but he never complained. Considering that he was all busted up . . he was a very strong man." Later, Udell admitted, he was so weakened by his exertion in the cold water he'd had difficulty pushing down the emergency radio button. And now cold struck again. " When he [Peterson] secured me in the litter, the helicopter flew overhead and lowered its winch, its rotors kicked up the wind and waves, and spray that felt like steel needles were hitting me and also created an effective air conditioner, giving me another big chill. However, I finally got pulled aboard, so I owe those guys a lot." Once in the helicopter, the Coast Guard rescue crew rushed the downed pilot to the nearest hospital. " When I arrived at the hospital, it seemed like 20 or 30 doctors and female nurses surrounded me," Udell said. " Within seconds I was buck naked, and all I could think about was that good ol' mom advice : ' Brian, make sure you have clean underwear on because you never know when you'll be in an accident.' " Soon an orthopedic surgeon walks in. He looks at the X-ray. "Right knee dislocated. Left ankle broken. Left arm dislocated," the doctor said. "I'm thinking, 'All right, pain medication,' " Udell said wistfully. "But without a hi, hello or how are you, that doctor walks up to me, grabs my right knee, and POP ! He snaps it back into place. I start screaming. Then he goes to my left ankle, POP ! I'm screaming even louder. Then he takes my left arm , POP ! " Doctors finally administered morphine, and he slipped into a happy place. Kristi Udell arrived in the hospital emergency room just as her husband began wailing in anguish. The doctor explained to her what was happening. "When I saw him, he looked vaguely familiar," Kristi said, shuddering at the thought. "His face was puffed up to the size of a basketball, and he had a gash that went across his eye." "How do I look?" he asked. "Great," she lied. In addition to his mangled face and broken and dislocated limbs .. he had a gash across his chest .. broken rib ..the back of his right thigh also had been slashed open .. both arms were a grotesque black and blue .. and various other scrapes, cuts and bruises maligned his body. But he was alive. During his first few hours in the hospital, the Udells found out White hadn't been so lucky. The violent force of the ejection killed him instantly. Still choking up at the memory, Udell said,"That was a depressing time for me. I'd held up pretty good until then. But when I found out he was dead, I just lost it. Dennis had left a wife and two kids." Doctors gave Udell additional morphine to help him sleep. Unfortunately, the drug caused him to dream. " I dreamt someone jumped on my leg, and the thought made me jerk and I popped my left knee popped back out of its socket." Because his leg was already in a cast, it wasn't until three days later that doctors found the knee dislocated once again. " My kneecap was swollen to the size of a cantaloupe and laid over to the side kind of funny," Udell said. His tendons and ligaments had been torn apart, so nothing held his knee in place. It snapped out of joint three more times before they managed to cast it again. After the swelling went down, two titanium rods had to be temporarily inserted into the knee to help hold it in place and keep it immobilized. After four surgeries and with six stainless steel screws in each leg, Udell began intensive physical therapy and his trek to walk . . and maybe even fly again. Nearly two months after the accident, he took his first step. "I didn't want to just lie around," Udell said. " I'd get in my wheelchair and wheel myself down to physical therapy every morning and work out for about an hour. Then I'd do the same thing in the afternoon. By the time I wheeled myself back to my hospital room that evening, I was exhausted and would go right to sleep." For months, Udell increased his rehabilitation workouts until he was riding a bike, lifting weights, doing water exercises and other various muscle-building routines eight to ten hours each day. By the sixth month, he felt he was ready to fly again .. it was something nobody had thought possible. "Some people get depressed when going through the slow rehabilitation process," said Kriquette Alexander, senior program director where Udell performed much of his rehab. "But Brian was an inspiration to everyone. He pushed himself. And was very focused. He's a cool critter." Even after so much progress, a skeptical medical board still had to be convinced that he was ready to fly again. "They took me and a 'healthy' guy out to an airplane to demonstrate an emergency ground egress out of the aircraft," Udell said smugly. "We had to pretend the aircraft was on fire .. unstrap .. jump overboard .. and run 50 yards away. They timed us both. I beat the other guy by 10 seconds." Ten months after the injury, after going through a battery of tests and getting waivers for the metal screws he'd carry for the rest of his life, Udell flew again. On his second flight, he soared back over the same area where he crashed. "I was just so excited to get back in the cockpit, I didn't have time to get scared," said Udell, whose father, retired Air Force Colonel Maurice Udell, taught him to fly when he was 9. "I just love to fly. It's all I ever wanted to do." Although Brian is back in the cockpit, he still has to go through stringent medical exams each year to stay on flying status. That's because the injuries to his limbs make him highly susceptible to degenerative arthritis. But for Udell, who had graduated at the top of his undergraduate pilot training class and had a strong resume package into the Thunderbirds before the crash, flying is no longer the number one priority in his life. He said, " When I clung onto that raft for dear life, I wasn't thinking about flying or drinking beer with my buddies. I prayed to God that he would let me see my wife again, and be there when my child was born." His first son was born while he labored through rehabilitation. In the hospital room during his first son's birth, the baby's head just made its way out into this world when he opened his eyes and looked up at his father. Brian's eyes welled up with tears . . it was God's answer to one of Udell's desperate prayers. [From the "FIGHTER PILOT" email list.] |
Wow...
-John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
great post
-- G Hassenpflug * IJN & JMSDF equipment/history fan |
"PosterBoy" wrote in message news:YxOfb.19847$9l5.1343@pd7tw2no... The most current example, from Mike Marron, should have credited the author of this piece as: Tech. Sgt. Timothy P. Barela, USAF. Not only does the law insist upon it, but common courtesy should dictate it here. snip He may not have known ? (from the last line of his post ) :- [From the "FIGHTER PILOT" email list.] |
"Sunny" wrote in message ... "PosterBoy" wrote in message news:YxOfb.19847$9l5.1343@pd7tw2no... The most current example, from Mike Marron, should have credited the author of this piece as: Tech. Sgt. Timothy P. Barela, USAF. Not only does the law insist upon it, but common courtesy should dictate it here. snip He may not have known ? (from the last line of his post ) :- [From the "FIGHTER PILOT" email list.] Marron knew and he has been called on this sort of thing before, he is just lazy. It is however better than if Marron posted his own run-ons. |
I understand that White perished during the ejection, rather than following
water entry. A small mercy, at least. -- Steve Davies "F-15 Eagle & Strike Eagle. Combat Legends" ISBN 1840 373 776 "F-15E Strike Eagle; The Inside Story" ISBN 1840 373 784 www.f-15e.net |
"PosterBoy" wrote:
While I am always pleased to read military aviation articles that are not easily available on the 'net, I am getting increasingly annoyed with the reproduction of original work here upon which a copyright should be noted. The most current example, from Mike Marron, should have credited the author of this piece as: Tech. Sgt. Timothy P. Barela, USAF. Not only does the law insist upon it, but common courtesy should dictate it here. Speaking of "common courtesy," a simple "thank you" would've sufficed. With regards to the law, right or wrong anything in my inbox I pretty much consider as mine to do with as I damn well see fit. As I've explained before, these articles are often emailed to me with no attribution therefore I simply attribute them to the "FIGHTER PILOT" email list as instructed and will continue to do so. Besides, proper attribution cannot transform an infringing use into a fair one. Now, I don't know if the following applies to "copyright" material forwarded on the net, but FWIW here is what my somewhat dated '92 version of the Associated Press' Stylebook & Libel Manual sez: "While copyright generally prohibits the use of another's protected expression, the doctrine of 'fair use' permits, in certain circumstances, the use of copyright material without its author's permission. To determine whether a particular use is fair, courts are required to evaluate and balance such factors as: (1) the purpose of the use; (2) the nature of the copyright work which is used; (3) the amount of and substantiality of the portion used in relation to the copyright work as a whole; and (4) the effect of the use upon the potential value of the copyright work." *** In any event, $1 to Tsgt. Timothy P. Barela. Outstanding! |
Jack wrote:
Mike Marron at wrote: "PosterBoy" wrote: While I am always pleased to read military aviation articles that are not easily available on the 'net, I am getting increasingly annoyed with the reproduction of original work here upon which a copyright should be noted. The most current example, from Mike Marron, should have credited the author of this piece as: Tech. Sgt. Timothy P. Barela, USAF. Not only does the law insist upon it, but common courtesy should dictate it here. Speaking of "common courtesy," a simple "thank you" would've sufficed. With regards to the law, right or wrong anything in my inbox I pretty much consider as mine to do with as I damn well see fit. As I've explained before, these articles are often emailed to me with no attribution therefore I simply attribute them to the "FIGHTER PILOT" email list as instructed and will continue to do so. Besides, proper attribution cannot transform an infringing use into a fair one. As usual Mike, you're long on rebuttal and short on comprehension. Jack Er um, Have we met? |
| Thread Tools | |
| Display Modes | |
