![]() "Maxwell" wrote: Is John with the CPA or Lycoming? Just wondering what Lycoming thinks of the recommendations. CPA The settings I mentioned, and some that are even more over-square, are listed as permissable in the POH. Here's what I found in a Lycoming flyer for a higher-power version of the TIO-540: "A power setting of 2200 RPM and 31" Hg manifold pressure is recommended for all cruise flight." -- Dan T-182T at BFM |
Dan Luke wrote:
The settings I mentioned, and some that are even more over-square, are listed as permissable in the POH. Here's what I found in a Lycoming flyer for a higher-power version of the TIO-540: "A power setting of 2200 RPM and 31" Hg manifold pressure is recommended for all cruise flight." Your quotation refers to a turbocharged engine which by definition would always be operated oversquare in cruise anyway. I doubt you will ever see 31" of manifold pressure in a normally aspirated engine. They just can't do it. That being said, I have been a long time fan of using the lowest RPM I can get away with for cruise flight mostly because of my experience with bigger twins. The slower they turn, the quieter they are, and the less tired everybody in earshot becomes. I look for whatever combination of low RPM and manifold pressure can give me 65-75% power. I still want the speed but don't need the extra noise trying to get an extra 7 knots out of the beast. All things in moderation... -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
![]() "Mortimer Schnerd, RN" wrote: "A power setting of 2200 RPM and 31" Hg manifold pressure is recommended for all cruise flight." Your quotation refers to a turbocharged engine which by definition would always be operated oversquare in cruise anyway. I doubt you will ever see 31" of manifold pressure in a normally aspirated engine. They just can't do it. My engine is a turbocharged engine. http://tinyurl.com/2jskz7 That being said, I have been a long time fan of using the lowest RPM I can get away with for cruise flight mostly because of my experience with bigger twins. The slower they turn, the quieter they are, and the less tired everybody in earshot becomes. Yep. -- Dan T-182T at BFM |
600 square miles? | Hilton | Piloting | 6 | September 8th 07 04:39 PM |
the square end of the Kiev | Dave Kearton | Aviation Photos | 0 | March 2nd 07 06:10 AM |
Back to square one on buying an Arrow | Jack Allison | Owning | 51 | March 26th 05 04:53 AM |
presidential TFR - 3,291 statute miles square! | Larry Dighera | Piloting | 47 | June 15th 04 06:08 PM |
square tube aluminum homebuilt | Joa | Home Built | 0 | October 21st 03 01:16 AM |
