this isn't much to go on I know, but maybe someone will remember this
I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. |
On Sep 21, 9:48?am, Scaler wrote:
this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page: http://www.spyflight.co.uk/Latest%20News.htm Rob |
On Sep 21, 12:29 pm, Rob Arndt wrote:
On Sep 21, 9:48?am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page:http://www.spyflight.co.uk/Latest%20News.htm Rob Thanks, this is extremely interesting. I read about the Super Valkyrie years ago, as well as again recently. I know it's also gone by the names (right or wrong) "Brilliant Buzzard" and SR-75 "Penetrator". As for the SR-3 Blackstar name, I don't remember that, or I've forgotten it. I also didn't know the combination of the two aircraft was codename Black Magic. I also realize that I (and others) could be confused. sometimes these are said to be the same aircraft but with different names / codenames. other articles state they were different programs / different aircraft. I am questioning my memory now, with these names. I wonder if what I read years ago was actually called BlackMagic or if it was Blackstar. I can't say if entire "Black Magic" project consisting of the SR-3 Blackstar / Super Valkyrie / Brillant Buzzard / SR-75 Penetrator and the small XOV "is it", if it's the aircraft (bomber?) that was described in that book - but, I will say this is the closest match yet. sometimes I wish my memory was really as sharp as people tell me it is (it's not). thanks again. |
On Sep 21, 12:08?pm, Scaler wrote:
On Sep 21, 12:29 pm, Rob Arndt wrote: On Sep 21, 9:48?am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page:http://www.spyflight.co.uk/Latest%20News.htm Rob Thanks, this is extremely interesting. I read about the Super Valkyrie years ago, as well as again recently. I know it's also gone by the names (right or wrong) "Brilliant Buzzard" and SR-75 "Penetrator". As for the SR-3 Blackstar name, I don't remember that, or I've forgotten it. I also didn't know the combination of the two aircraft was codename Black Magic. I also realize that I (and others) could be confused. sometimes these are said to be the same aircraft but with different names / codenames. other articles state they were different programs / different aircraft. I am questioning my memory now, with these names. I wonder if what I read years ago was actually called BlackMagic or if it was Blackstar. I can't say if entire "Black Magic" project consisting of the SR-3 Blackstar / Super Valkyrie / Brillant Buzzard / SR-75 Penetrator and the small XOV "is it", if it's the aircraft (bomber?) that was described in that book - but, I will say this is the closest match yet. sometimes I wish my memory was really as sharp as people tell me it is (it's not). thanks again.- Hide quoted text - - Show quoted text - No problem. I was certain your myster bomber was in the book "Beyond the Horizon" that was published in 1994, but I could find no refs to Blackmagic. BTW, the SR-75 is associated with the Aurora and not the Super Valkyrie and Blackstar is not a bomber, but a launcher for the XOV. Maybe if you described the fictional Blackmagic configuration (canards, blended body, delta, canted tails, tailless, etc...) it might help someone remember what you are talking about as far as the book goes. Also, are you sure it was not Black Magic? Any further details will help the search... Rob |
On Sep 21, 2:28 pm, Rob Arndt wrote:
On Sep 21, 12:08?pm, Scaler wrote: On Sep 21, 12:29 pm, Rob Arndt wrote: On Sep 21, 9:48?am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page:http://www.spyflight.co.uk/Latest%20News.htm Rob Thanks, this is extremely interesting. I read about the Super Valkyrie years ago, as well as again recently. I know it's also gone by the names (right or wrong) "Brilliant Buzzard" and SR-75 "Penetrator". As for the SR-3 Blackstar name, I don't remember that, or I've forgotten it. I also didn't know the combination of the two aircraft was codename Black Magic. I also realize that I (and others) could be confused. sometimes these are said to be the same aircraft but with different names / codenames. other articles state they were different programs / different aircraft. I am questioning my memory now, with these names. I wonder if what I read years ago was actually called BlackMagic or if it was Blackstar. I can't say if entire "Black Magic" project consisting of the SR-3 Blackstar / Super Valkyrie / Brillant Buzzard / SR-75 Penetrator and the small XOV "is it", if it's the aircraft (bomber?) that was described in that book - but, I will say this is the closest match yet. sometimes I wish my memory was really as sharp as people tell me it is (it's not). thanks again.- Hide quoted text - - Show quoted text - No problem. I was certain your myster bomber was in the book "Beyond the Horizon" that was published in 1994, but I could find no refs to Blackmagic. I'm trying to get one of several local libraries to get ahold of that book for me, thanks for mentioning it, regardless. BTW, the SR-75 is associated with the Aurora and not the Super Valkyrie and Blackstar is not a bomber, but a launcher for the XOV. sometimes I see SR-75 associated with Super Valkyrie, but more often, with the Aurora. I do understand that both / all of these platforms are non-bombers. even though it's been said that, theoretically, they may have had the potential to carry light payloads for strike missions. Maybe if you described the fictional Blackmagic configuration (canards, blended body, delta, canted tails, tailless, etc...) it might help someone remember what you are talking about as far as the book goes. unfortunately I don't remember much. canards, likely yes. blended body, not that I remember no. I believe it did have a tail and I'm pretty sure it had swing wings. the Super Valkyrie was thought to be a heavily modernized XB-70, the Blackmagic reminded me of a B-1B on steroids. Also, are you sure it was not Black Magic? I'm not certain. can't say it wasn't but also can't say it was. Any further details will help the search... Rob that's about the most I remember. It'll either be someone who remembers exactly the book and page of that book I'm recalling, or me having some luck finding it again myself. |
On Sep 21, 4:34?pm, Scaler wrote:
On Sep 21, 2:28 pm, Rob Arndt wrote: On Sep 21, 12:08?pm, Scaler wrote: On Sep 21, 12:29 pm, Rob Arndt wrote: On Sep 21, 9:48?am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page:http://www.spyflight.co.uk/Latest%20News.htm Rob Thanks, this is extremely interesting. I read about the Super Valkyrie years ago, as well as again recently. I know it's also gone by the names (right or wrong) "Brilliant Buzzard" and SR-75 "Penetrator". As for the SR-3 Blackstar name, I don't remember that, or I've forgotten it. I also didn't know the combination of the two aircraft was codename Black Magic. I also realize that I (and others) could be confused. sometimes these are said to be the same aircraft but with different names / codenames. other articles state they were different programs / different aircraft. I am questioning my memory now, with these names. I wonder if what I read years ago was actually called BlackMagic or if it was Blackstar. I can't say if entire "Black Magic" project consisting of the SR-3 Blackstar / Super Valkyrie / Brillant Buzzard / SR-75 Penetrator and the small XOV "is it", if it's the aircraft (bomber?) that was described in that book - but, I will say this is the closest match yet. sometimes I wish my memory was really as sharp as people tell me it is (it's not). thanks again.- Hide quoted text - - Show quoted text - No problem. I was certain your myster bomber was in the book "Beyond the Horizon" that was published in 1994, but I could find no refs to Blackmagic. I'm trying to get one of several local libraries to get ahold of that book for me, thanks for mentioning it, regardless. BTW, the SR-75 is associated with the Aurora and not the Super Valkyrie and Blackstar is not a bomber, but a launcher for the XOV. sometimes I see SR-75 associated with Super Valkyrie, but more often, with the Aurora. I do understand that both / all of these platforms are non-bombers. even though it's been said that, theoretically, they may have had the potential to carry light payloads for strike missions. Maybe if you described the fictional Blackmagic configuration (canards, blended body, delta, canted tails, tailless, etc...) it might help someone remember what you are talking about as far as the book goes. unfortunately I don't remember much. canards, likely yes. blended body, not that I remember no. I believe it did have a tail and I'm pretty sure it had swing wings. the Super Valkyrie was thought to be a heavily modernized XB-70, the Blackmagic reminded me of a B-1B on steroids. Also, are you sure it was not Black Magic? I'm not certain. can't say it wasn't but also can't say it was. Any further details will help the search... Rob that's about the most I remember. It'll either be someone who remembers exactly the book and page of that book I'm recalling, or me having some luck finding it again myself.- Hide quoted text - - Show quoted text - More info on Blackstar: http://www.astronautix.com/craft/blakstar.htm Rob |
How about "Black Rainbow"? On Sep 21, 11:48 am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. |
On Sep 22, 8:00 am, Rob Arndt wrote:
On Sep 21, 4:34?pm, Scaler wrote: On Sep 21, 2:28 pm, Rob Arndt wrote: On Sep 21, 12:08?pm, Scaler wrote: On Sep 21, 12:29 pm, Rob Arndt wrote: On Sep 21, 9:48?am, Scaler wrote: this isn't much to go on I know, but maybe someone will remember this I recall reading a book in the early to mid 1990s, it was about modern military aircraft. This book was probably published in the late 80s or the 90s, more likely the 90s. There was quite a bit about stealth technology. the F-117 Nighthawk and B-2 stealth bomber was described. maybe other stealth aircraft that were either rumored or canceled. The thing that really caught my eye was a description of a fictional , future bomber that (IIRC) they called "Blackmagic". it was a purly made-up name, *not* a codename for a secret stealth plane, IIRC. It was definitally *not* the Soviet / Russian Tu-160 Blackjack bomber, nor was it the well-known fictional Megafortress (a heavily modified B-52). It was also not any of the rumored classified stealth attack aircraft or hypersonic spyplanes that have been the subject of much discussion the past 15+ years. this fictional heavy bomber was very advanced, yet semi conventional. From what I remember, it looked like a stealthy version of the B-1B, but maybe larger, and the illustration might have shown it flying low through a canyon or between mountains or something like that. I might be wrong but I want to say that I think I remember it had saw-toothed edges near the engines. I strongly believe it was a variable geometry bomber, but again it was neither the B-1B Lancer (or a derivative of the B-1) or the Tu-160 Blackjack. I suppose if anything, it might have been described one of the concepts for one of the B-3 bomber proposals. If this rings a bell, if anyone by some chance remembers the title of the book, I'd most appreciate knowing what it was. I've already done all the googling I can with every keywork I can think of. I guess my best bet is to try various libraries and used book stores to see if i run across it again. but I thought I'd first run this across this group, thanks in advance. You probably should know that there was a codename "Black Magic" to describe the rumored two-stage-to-orbit combo of the SR-3 Blackstar (once known as the Super Valkyrie) and the XOV (Experimental Orbiter Vehicle). You can find info on that here about 2/3rds of the way down the page:http://www.spyflight.co.uk/Latest%20News.htm Rob Thanks, this is extremely interesting. I read about the Super Valkyrie years ago, as well as again recently. I know it's also gone by the names (right or wrong) "Brilliant Buzzard" and SR-75 "Penetrator". As for the SR-3 Blackstar name, I don't remember that, or I've forgotten it. I also didn't know the combination of the two aircraft was codename Black Magic. I also realize that I (and others) could be confused. sometimes these are said to be the same aircraft but with different names / codenames. other articles state they were different programs / different aircraft. I am questioning my memory now, with these names. I wonder if what I read years ago was actually called BlackMagic or if it was Blackstar. I can't say if entire "Black Magic" project consisting of the SR-3 Blackstar / Super Valkyrie / Brillant Buzzard / SR-75 Penetrator and the small XOV "is it", if it's the aircraft (bomber?) that was described in that book - but, I will say this is the closest match yet. sometimes I wish my memory was really as sharp as people tell me it is (it's not). thanks again.- Hide quoted text - - Show quoted text - No problem. I was certain your myster bomber was in the book "Beyond the Horizon" that was published in 1994, but I could find no refs to Blackmagic. I'm trying to get one of several local libraries to get ahold of that book for me, thanks for mentioning it, regardless. BTW, the SR-75 is associated with the Aurora and not the Super Valkyrie and Blackstar is not a bomber, but a launcher for the XOV. sometimes I see SR-75 associated with Super Valkyrie, but more often, with the Aurora. I do understand that both / all of these platforms are non-bombers. even though it's been said that, theoretically, they may have had the potential to carry light payloads for strike missions. Maybe if you described the fictional Blackmagic configuration (canards, blended body, delta, canted tails, tailless, etc...) it might help someone remember what you are talking about as far as the book goes. unfortunately I don't remember much. canards, likely yes. blended body, not that I remember no. I believe it did have a tail and I'm pretty sure it had swing wings. the Super Valkyrie was thought to be a heavily modernized XB-70, the Blackmagic reminded me of a B-1B on steroids. Also, are you sure it was not Black Magic? I'm not certain. can't say it wasn't but also can't say it was. Any further details will help the search... Rob that's about the most I remember. It'll either be someone who remembers exactly the book and page of that book I'm recalling, or me having some luck finding it again myself.- Hide quoted text - - Show quoted text - More info on Blackstar:http://www.astronautix.com/craft/blakstar.htm Rob going by all the unofficial stuff on the web and elsewhere, it seems there were (at least described if not actually built) two or more combinations of SR-71 sized (or larger) "motherships" that could fly at mach 3-4 (or somewhat faster) at roughly 100,000 feet, paired with a smaller manned or unmaned craft attached to the top or underside of the larger 1st stage mothership, and these small 2nd stage craft could fly at suborbit/to the edge of space or low-earth orbit / space altitudes at hypersonic speeds. |
I was also going to add, could it be that the USAF, CIA, Gov, etc
had two programs in succession? one in the 1970s/1980s and one in the 1990s/2000s? just as the U2 covered the 1950s/1960s and the SR-71 covered the 1960s/1970s. it's not unreasonable to think there were overlapping and/or successive programs. |
On Sep 22, 12:09?pm, Scaler wrote:
I was also going to add, could it be that the USAF, CIA, Gov, etc had two programs in succession? one in the 1970s/1980s and one in the 1990s/2000s? just as the U2 covered the 1950s/1960s and the SR-71 covered the 1960s/1970s. it's not unreasonable to think there were overlapping and/or successive programs. It would seem like the SR replacement, whether SR-75 Penetrator or Aurora, was replaced by the Sentinel while the Super Valkyrie became the S-3 Blackstar and moved into the space category along with the TR-3B ASTRA. Also, the NRO has always been rumored to control new aircraft and NOT just satellites. Part of the reason for black project "blackout" since the B-2 was publically unveiled in the late 1980s. Rob |
| Thread Tools | |
| Display Modes | |
| The advance of perihelion of Mercury is entirely predicted- (so called "anomaly") | Michael Baldwin, Bruce | Products | 0 | May 27th 07 08:12 AM |
| Precession of Mercury's longitude of perihelion - (so called "anomaly") | Michael Baldwin, Bruce | Products | 0 | May 27th 07 08:00 AM |
| "Eight more F-22 stealth fighters arrive in Japan" | Mike[_1_] | Naval Aviation | 1 | February 19th 07 12:56 AM |
