396 w/PS Eng audio panel problem
I've got a friend that has been having problems with his 396 dropping all
satellites. He just emailed me the following: "First, I finally isolated the problem to my audio panel. I had all the radios off and still no GPS signal. Then just for fun I shut off the audio panel and instantly the 396 locked on. After verifying this several times I knew what was causing the problem but not how to fix it. I talked to Garmin and PS eng at OSH along with several avionics shops and none of them ever heard of my problem. They suggested that I relocate the GPS antenna and wiring but that didn't help. Last week I called tech support at PS Eng and they said they knew about the problem and were able to reproduce it on the bench. They also said just send it in for a no charge (same day) fix. And hopefully that's that!" Jim |
"Jim Burns" wrote in message ... Then just for fun I shut off the audio panel and instantly the 396 locked on. Jim, how did you shut off your audio panel? |
Sorry, not my airplane/audio panel. This was a friend's of mine. I'm
guessing either an avionics master switch or a circuit breaker for the audio panel was used. Jim "Mike Isaksen" wrote in message news:k%wOi.2636$h33.1129@trndny02... "Jim Burns" wrote in message ... Then just for fun I shut off the audio panel and instantly the 396 locked on. Jim, how did you shut off your audio panel? |
Mike Isaksen wrote: "Jim Burns" wrote in message ... Then just for fun I shut off the audio panel and instantly the 396 locked on. Jim, how did you shut off your audio panel? Must not be a Garmin. The Garmin has an on/off switch. |
Jim,
I have a PS Engineering 8000B audio panel and a Garmin 396 GPS. I've had the combo over a year and have never had a problem. The 396 is mounted on the yoke, I use the little stubby antenna only (the Cardinal has a large sloping windscreen with plenty of sky for the unit to see) and the XM antenna placed on the far left side of the glareshield. The audio panel is in the top position in the radio stack. I would be curious which GPS antenna your friend uses and which model PS Eng. audio panel he has. If you have a chance to ask him, I'd be interested to know. Kobra |
Kobra,
I'll be sure to do that, I'm interested as well. I know that he's had at least one antenna upgrade and that the 396 is in a AirGizmo panel mount. I'd be interested in hearing or reading PS Engineerings explanation and solution. I couldn't find anything in their FAQs or elsewhere on their website. Jim "Kobra" wrote in message . .. Jim, I have a PS Engineering 8000B audio panel and a Garmin 396 GPS. I've had the combo over a year and have never had a problem. The 396 is mounted on the yoke, I use the little stubby antenna only (the Cardinal has a large sloping windscreen with plenty of sky for the unit to see) and the XM antenna placed on the far left side of the glareshield. The audio panel is in the top position in the radio stack. I would be curious which GPS antenna your friend uses and which model PS Eng. audio panel he has. If you have a chance to ask him, I'd be interested to know. Kobra |
Similar Threads | ||||
New Garmin Audio Panel | Lakeview Bill | Products | 2 | October 27th 05 11:28 AM |
Updated RST Audio Panel? | N523RV | Home Built | 11 | April 21st 05 01:51 AM |
RST-565 Audio Panel | Jim Weir | Owning | 0 | October 29th 04 08:57 PM |
RST Audio Panel Kit Assembly | Tim Witt | Owning | 6 | March 29th 04 03:06 AM |
FS: KMA20 TSO Audio Panel | Maik | Aviation Marketplace | 0 | February 25th 04 07:52 PM |
