Morgans wrote:
"Matt Whiting" wrote The issue with shock cooling isn't the rate of cooling per se, but rather stress induced by differential cooling. Most engines see far higher temperature differentials during start-up than they do during cooldown. Jay, have you timed your engine heat up rate? It would be interesting to watch how fast your engine heats up from say a 50 degree cold start and then compare that to the cool-down rate when you pull the throttle for engine out practice. I'm assuming this would be fairly trivial with your engine analyzer. I'm pretty sure that the rate of heating of the metal of the head is not the big issue, according to the shock cooling proponents. Instead, it is the heads (and cylinders) cooling more rapidly than the pistons, and the hot pistons (not able to be cooled as rapidly) against the cooler cylinders (the cylinders do not have heat instrumentation, so the closest thing they can do is to measure is the head temperatures) causing a reduction in the tolerances between the piston and the cylinder walls, thus causing possible scuffing and abnormal wear. At least that is my take on what they say. It seems to me that upon engine start the pistons would heat up much faster than the cylinders causing the same net affect as cooling down the cylinders faster once hot. Either way the pistons are hotter than the cylinders. Matt |
On Oct 13, 8:55 pm, Matt Whiting wrote:
It seems to me that upon engine start the pistons would heat up much faster than the cylinders causing the same net affect as cooling down the cylinders faster once hot. Either way the pistons are hotter than the cylinders. Matt At idle or low power settings there is little heat generated. So little, in fact, that it can take forever to get the CHT warm enough to carry out the runup when the temps here are -15 or 20°C. The cylinder has plenty of time to warm up. It's the sudden removal of the heat source when the atmosphere is really cold that problems might arise. In Canada we have to think about it a little more than the pilot in Arizona. Pistons are aluminum and expand at twice the rate of the steel cylinders, clearances get small during operational temps, and shrinking a cylinder quickly around a hot piston is asking for scuffing or seizure. We run six Lycs in flight training ops. They usually reach TBO in good condition. They get a lot of rapid throttle movement, even though I constantly make noises about not abusing the engines. In my opinion, opening the throttle too fast can do more damage than closing it too quickly. Cylinder pressures can get high enough with rapid throttle movement to cause detonation, however briefly, and cracking of various parts might occur. A pilot who bangs the throttle open is applying high manifold pressures to an engine at very low RPM, the definitive extreme oversquare situation. Closing it quickly in flight will cause afterfiring (lean mixtures that often don't fire in the cylinder, igniting instead in the hot muffler). Cracking of exhaust components is a risk there, and we find that often enough. Our students get plenty of forced-approach practice. The engine is throttled back in two or three or four seconds. Transport Canada tells us that some practice forced landings (PFLs) end in the real thing when the carb ices up during the glide. The syllabus calls for an application of power for a few seconds every 1000' of altitude loss to clear the engine, but since the exhaust system is cool in the glide, it can take much more than a few seconds to clear any ice accretion and the engine might not respond when necessary. For those lucky ones with injection, carb ice is not a problem, but most of us are stuck with carbs and need to be thinking, when we check the weather before the flight, about what the atmosphere is up to. We wouldn't dive into unknown waters without making sure there weren't hidden rocks or sharks around, and we shouldn't launch without knowing the temp and dewpoint spread, right? Dan |
Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
