Civil airports closed for ultralights
Old October 26th 07, 05:12 PM posted to rec.aviation.piloting
Stefan
Default Civil airports closed for ultralights
wp schrieb:
How many civil airports in Europe are closed for ultralight aircrafts?
If so, what's the common cause?
To be more precise: which international airports you are aware of are
closed for ultralights? I wonder if this is common practice or just an
exception?
Again: When it comes to ultralights, there is no such thing as "Europe".
In terms of ultralight in mean LSA/VLA of MTOW 495/600kg.
Even this definition is not unified in Europe.
Old October 26th 07, 05:34 PM posted to rec.aviation.piloting
Snowbird
One variation on the theme is those large airports that require a
transponder to enter the control zone. That tends to keep out most ULs, as
it's difficult to fit a transponder within the (in this case) 450 kg MTOM
limit.
Another variant is the significantly higher landing fees charged at the
large airports.
Neither one is of course directly shutting out ultralights, but the end
result is practically the same.
And as already mentioned, each country is different.
Old October 26th 07, 05:55 PM posted to rec.aviation.piloting
wp
limit.
Transponder weights only 1.5kg or even less so it's not a problem.
large airports.
The money is not a problem as well.
SPace-SHIP
Old October 26th 07, 07:55 PM posted to rec.aviation.piloting
Snowbird
Then buy a certified airplane, for example the inexpensive Aero AT-3, which
presumably can be operated at your airport ;-)
Old October 26th 07, 08:11 PM posted to rec.aviation.piloting
wp
It's not an option because it's way too slow!
SPace-SHIP
Ultralights in Space? DABEAR Home Built 9 February 12th 07 09:26 PM
Australian Ultralights Kevin Berlyn Home Built 0 March 15th 05 01:09 PM
Best engine for ultralights Josip General Aviation 5 August 27th 04 07:02 PM
one medical away from Ultralights Gilan Owning 7 May 22nd 04 01:54 AM
one medical away from Ultralights Gilan Piloting 7 May 22nd 04 01:54 AM
