Jay Honeck writes:
I have never, ever, EVER had work done under the panel that did not result in the need for further work.... Hence my dream to move as much as possible out of there. Icom/Kenwood/etc make 2mtr ARS/VHF commercial radios with a detachable ~0.5" thick panel, and simple connecting cable. I'd make it a fiber, and move the bigger boxes to under the rear seat where cooling and access are both easy. Little box with mike/earphone jacks going back there. Then some instruments as well; LCD/glasspanel. That leaves lots of room for the backup, deep ASI/AH/whatever. Then I wake up and realize: these are the folks with external regulators on their generators....and magneto ignitions. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Icom/Kenwood/etc make 2mtr ARS/VHF commercial radios with a detachable ~0.5" thick panel, and simple connecting cable. I'd make it a fiber, and move the bigger boxes to under the rear seat where cooling and access are both easy. Little box with mike/earphone jacks going back there. Not exactly a new idea. Most WWII aircraft radios had a control box and a remotely-mounted main chassis. My first airplane had a Narco Omnigator "coffee grinder" with that arrangement. The remote part too up a fair percentage of the baggage compartment. It sort of worked, but you had to speed up the engine (and stand on the brakes) on the ground so the generator would kick in and bring the voltage up to where the transmitter would work. I don't miss it. BTW: it had vacuum tubes and a vibrator power supply. Anyone remember those? David Johnson |
Dave writes:
I'd make it a fiber, and move the bigger boxes to under the rear seat where cooling and access are both easy. Little box with mike/earphone jacks going back there. Not exactly a new idea. Yep. Back Then, you needed a place for the dynamotor. But while we don't need one any longer, and adding the fiber connection; I think the cooling and accessability would offer real advantages. I'd likely throw in a small Gel-Cell for backup power as well. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
What is a 'PK" screw? | mhorowit | Home Built | 9 | January 2nd 07 05:44 PM |
Screw It's Aircraft Tie Down System | User | Home Built | 20 | November 28th 06 05:31 PM |
Query: Canadian Owner maintenance | Stealth Pilot | Home Built | 11 | May 4th 06 10:03 PM |
Owner Maintenance and Inspection | Jay Honeck | Owning | 1 | January 31st 06 07:34 PM |
Pilot/Owner Signoff for spark plug maintenance? | John Clonts | Owning | 3 | September 14th 04 11:08 AM |
