I knew the concept was valid from Schempp-Hirth instructions on how to
heat up an early Cirrus wing and put in the twist that Cirrus's after s/n 175 had. I have a badly twisted gear door (corner stood proud a good 5mm), so I thought I'd give it a try on a much smaller scale. I held the gear door in front of an electric space heater for a good 8 minutes, until it was too hot to leave a finger on the surface. Then I put it in place on the wheel-well (fuselage inverted) and held the ends with two 25# shot bags. I slipped in a 5mm shim to achieve over- twist for the expected spring-back. Let it cool for an hour and it fits like new! Anybody else have experience heat-twisting epoxy/fiberglass parts? What's the yield temp? JJ |
On Oct 29, 3:28 pm, JJ Sinclair wrote:
I knew the concept was valid from Schempp-Hirth instructions on how to heat up an early Cirrus wing and put in the twist that Cirrus's after s/n 175 had. I have a badly twisted gear door (corner stood proud a good 5mm), so I thought I'd give it a try on a much smaller scale. I held the gear door in front of an electric space heater for a good 8 minutes, until it was too hot to leave a finger on the surface. Then I put it in place on the wheel-well (fuselage inverted) and held the ends with two 25# shot bags. I slipped in a 5mm shim to achieve over- twist for the expected spring-back. Let it cool for an hour and it fits like new! Anybody else have experience heat-twisting epoxy/fiberglass parts? What's the yield temp? JJ Lots of experience here ! Yield temp is just a bit lower than when it starts to turn brown ;-) Last time I did this I just used a hair dryer and gradually increased the heat until the part gave a little easier. There's got to be a better way to quickly judge it though ? Maybe Bumper can recommend one of those nifty strips that changes color at just the right temperature ? See ya, Dave "YO" |
I knew the concept was valid from Schempp-Hirth instructions on how to heat up an early Cirrus wing and put in the twist that Cirrus's after s/n 175 had. I have a badly twisted gear door (corner stood proud a good 5mm), so I thought I'd give it a try on a much smaller scale. I held the gear door in front of an electric space heater for a good 8 minutes, until it was too hot to leave a finger on the surface. Then I put it in place on the wheel-well (fuselage inverted) and held the ends with two 25# shot bags. I slipped in a 5mm shim to achieve over- twist for the expected spring-back. Let it cool for an hour and it fits like new! Anybody else have experience heat-twisting epoxy/fiberglass parts? What's the yield temp? JJ Doesn't seem to work as well on ships made with newer resins like current production ships that have been post cured to 50 C or so. T1(yield) temp is just above whatever it was post cured to from my experience. Seems to make sense. UH |
On Oct 29, 1:06 pm, wrote:
On Oct 29, 3:28 pm, JJ Sinclair wrote: I knew the concept was valid from Schempp-Hirth instructions on how to heat up an early Cirrus wing and put in the twist that Cirrus's after s/n 175 had. I have a badly twisted gear door (corner stood proud a good 5mm), so I thought I'd give it a try on a much smaller scale. I held the gear door in front of an electric space heater for a good 8 minutes, until it was too hot to leave a finger on the surface. Then I put it in place on the wheel-well (fuselage inverted) and held the ends with two 25# shot bags. I slipped in a 5mm shim to achieve over- twist for the expected spring-back. Let it cool for an hour and it fits like new! Anybody else have experience heat-twisting epoxy/fiberglass parts? What's the yield temp? JJ Doesn't seem to work as well on ships made with newer resins like current production ships that have been post cured to 50 C or so. T1(yield) temp is just above whatever it was post cured to from my experience. Seems to make sense. UH I've used hot tap water to "adjust" fiberglass parts. It conducts the heat to the part better than air, and I don't think you could over heat it that way. I maxed out the thermostat on my water heater to do it. I've been able to do significant "shaping" this way. I've also gotten scalded more than once. |
On Oct 29, 12:28 pm, JJ Sinclair wrote:
I knew the concept was valid from Schempp-Hirth instructions on how to heat up an early Cirrus wing and put in the twist that Cirrus's after s/n 175 had. I have a badly twisted gear door (corner stood proud a good 5mm), so I thought I'd give it a try on a much smaller scale. I held the gear door in front of an electric space heater for a good 8 minutes, until it was too hot to leave a finger on the surface. Then I put it in place on the wheel-well (fuselage inverted) and held the ends with two 25# shot bags. I slipped in a 5mm shim to achieve over- twist for the expected spring-back. Let it cool for an hour and it fits like new! Anybody else have experience heat-twisting epoxy/fiberglass parts? What's the yield temp? JJ Depends on the resin. When we reshaped the trailing edge of my ASW22 Rudder, Larry M. built a foam box and used hair dryers to maintain it at 175F The part was Kevlar lay up not plain glass. Your experience might vary Regards Al |
Looks like the Jonkers sustainer will have this capability
built in - a least for the fin and tailplane:-) http://www.jonkersailplanes.com/vide...nd_320x240.wmv John Galloway yahhoooooooo! Man do I want one of those! Or Two, hang the expense! Bagger |
At 13:48 05 November 2007, Bagmaker wrote:
-Looks like the Jonkers sustainer will have this capability built in - a least for the fin and tailplane:-) http://www.jonkersailplanes.com/vide...nd_320x240.wmv John Galloway - yahhoooooooo! Man do I want one of those! Or Two, hang the expense! Bagge -- bagmaker HpH has is also going to have the option on the new 304S's see:http://www.hph.cz/ (second item down on news page) As you can see, they are pretty far along, and it should be available soon. Paul Hanson "Do the usual, unusually well"--Len Niemi |
| Thread Tools | |
| Display Modes | |
| Fiberglass seperation | Lou | Home Built | 7 | September 25th 06 05:03 AM |
| Aluminized fiberglass | Dan, U.S. Air Force, retired | Home Built | 2 | May 3rd 05 09:35 AM |
| FS: Aircraft Instruments Parts Avionics Warbird Parts | Bill Berle | Home Built | 0 | January 10th 04 03:20 AM |
| FS: Aircraft Instruments Parts Avionics Warbird Parts | Bill Berle | Aviation Marketplace | 0 | January 10th 04 03:20 AM |
| 2004 California airshow season shaping up! | Wings Of Fury | Military Aviation | 0 | December 31st 03 06:34 AM |
