Gamijectors - problem probably solved
Old December 10th 07, 03:49 PM posted to rec.aviation.owning
nrp
Default Gamijectors - problem probably solved
On Dec 10, 7:09 am, Denny wrote:
The problem the lubed cam solves is the delay in splash lubrication
right after starting when the engine has set for long enough for the
cam to drain dry...
A better way out of this is to religiously preheat in cold weather.
The cam won't ever drain completely dry. Rather the problem is that
it takes quite a while for the replacement lubrication fog to develop
in a cold engine/crankcase.
Think of it this way - many of the the most critical parts of an
engine are lubricated only by the fog. The design of the oil pump and
relief valve system is such that the sump oil has little access to the
heat of an engine if the oil is thick. As a result, the fog can be
very slow to develop. Any high power without having the fog, & the
cam can spall in a few seconds. It will never recover its surfaces
from this.
Pre oilers might help, but there is thermally a long way between a few
oil splatters and a true oil fog. The problem really isn't the
immediacy of oil pressure, it is the needed thinning so that oil is
generously spraying around the crankcase vs being congealed.
Test flight with new GAMIjectors [email protected] Piloting 0 October 27th 07 07:23 PM
GAMIjectors Dan Luke[_2_] Owning 25 September 9th 07 02:37 PM
OT - Garmin database updates PROBLEM SOLVED Michael Ware Piloting 9 December 2nd 06 08:25 PM
Jay Honeck-- Your "Airplane On A Pole" problem is solved RST Engineering Owning 15 May 30th 05 03:56 PM
"Not Responding" Problem Solved!! Amir Facade Simulators 1 August 21st 03 06:36 AM
