#11
"F. Baum" wrote in
: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie |
john smith wrote in
: Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie |
john smith wrote in : Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. -- Dudley Henriques |
Dudley Henriques wrote:
Bertie the Bunyip wrote: john smith wrote in : Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. Come to think of it, I do recall seeing something about Decathlons being available with fixed pitch props but never ran across one. Ours had the Hartzel. -- Dudley Henriques |
Dudley Henriques wrote in
: Dudley Henriques wrote: Bertie the Bunyip wrote: john smith wrote in : Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. Come to think of it, I do recall seeing something about Decathlons being available with fixed pitch props but never ran across one. Ours had the Hartzel. Yeah, Might have been an option that nearly everyone took up. I think you could get a Citabria with one IIRC. They're making them again now and they're slightly different spec to the old ones, I think Bertie |
On Dec 17, 3:42 pm, Bertie the Bunyip wrote:
Dudley Henriques wrote : Dudley Henriques wrote: Bertie the Bunyip wrote: john smith wrote in : Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. Come to think of it, I do recall seeing something about Decathlons being available with fixed pitch props but never ran across one. Ours had the Hartzel. Yeah, Might have been an option that nearly everyone took up. I think you could get a Citabria with one IIRC. They're making them again now and they're slightly different spec to the old ones, I think Bertie- Hide quoted text - - Show quoted text - IIRC in the early days there was a Decathlon with 150 HP fixed pitch and then the Super Decathlon with C/S prop. There is a late 90s Decathlon made by ACA that is for sale in my neiborhood for under 100. I have checked and it will fit in the hangar with my other plane............. Gonna make an offer after the holidays. |
Dudley Henriques wrote in : Dudley Henriques wrote: Bertie the Bunyip wrote: john smith wrote in : Bertie the Bunyip wrote: "F. Baum" wrote in news:02bef7c5-1ee1-437d-a908-b9b6dcfcfdd9 @b1g2000pra.googlegroups.com: On Dec 16, 8:18 pm, Bertie the Bunyip wrote: I see a lot of Acrosport IIs on Barnstormers for not a lot of money. A low performance bipe like that makes a good first aerobatic trainer because it will be easy enough to do the manuevers, yet difficult enough to do them well, and a well built one should be just about unbreakable. Bertie- Hide quoted text - How does it compare to the ACA Decathelon ? Never flown an Acrosport, but I did display in a Decathlon years ago. the Decathlon is a good airplane, but for a beginner in aerobatics it's probably not the best choice unless you're under a steady hand during the initial, scary bits. The Decathlon is relatively clean an the entry speeds for some manuevers are fairly close to the redline. Biplanes are inherently stronger ( unless the airplane is a piece of crap), but th eDecathlon will do in a pinch! It's nto a kitplane or anything like one, of course! Even a good second hand Decathlon wil set you back over fifty grand. The Citabria even more so, but having said that they are both fine airplanes, providing their spars haven't been damaged. Bertie, you forgot to mention if one's first Decathlon should be a fixed-pitch or constant speed prop. Don't really think it matters. It's not that big a deal to use one. Are there any fixed pitch prop Decathlons? I don't think I've ever seen one. Anyhow, with some decent instruction using a CS prop on an aerobatic airplane is definitely a plus for a lot of reasons. Better perfromance and better braking if you screw it up! Bertie I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. Come to think of it, I do recall seeing something about Decathlons being available with fixed pitch props but never ran across one. Ours had the Hartzel. Yeah, Might have been an option that nearly everyone took up. I think you could get a Citabria with one IIRC. They're making them again now and they're slightly different spec to the old ones, I think Bertie I know I've seen and flown several and never seemed to come across one with the fixed pitch prop but I'm sure there must have been a few out there. We leased one back from a guy on the field to use for basic acro introduction. If I remember right, there was a hefty AD issued on the wing that cost a damn fortune for the owners. I liked the airplane for what we did with it. -- Dudley Henriques |
On 2007-12-17, Dudley Henriques wrote:
I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. I had a '79 with 150HP and a fixed pitch prop. -- Doug Carter |
Doug Carter wrote:
On 2007-12-17, Dudley Henriques wrote: I don't remember ever seeing a Decathlon with anything but a constant speed Hartzel on it. I had a '79 with 150HP and a fixed pitch prop. -- Doug Carter Solves that question. Thanks! -- Dudley Henriques |
wrote in message ... What are the kit or plans built planes that people use for aerobatics? What kind of aerobatics do you want to do? Simple loop/roll kind of maneuvers? Harder stuff like gyroscopic maneuvers? Do you need cross country ability (say 150 mph cruise with at least one passenger and bags)? There is a full spectrum of options out there. For a good compromise aircraft that loops and rolls well and offers good cross country ability, the RV series is hard to beat. If your need is more biased towards hard acro, Pitts and One Designs are very capable. If you want to learn acro, there are several good choices listed elsewhere in the thread. |
| Thread Tools | |
| Display Modes | |
| My first aerobatic lesson | Marco Rispoli | Piloting | 6 | April 13th 05 03:21 PM |
| US Aerobatic Team | MuscleBiplane | Aerobatics | 0 | March 19th 05 11:28 PM |
| Aerobatic club | Klein | Aerobatics | 1 | February 9th 05 06:53 PM |
| Air-to-air aerobatic photos | Daniel Karlsson | Piloting | 0 | October 29th 04 12:51 PM |
| Air-to-air aerobatic photos | Daniel Karlsson | Aerobatics | 0 | October 29th 04 12:50 PM |
