Engine configuration
Old December 20th 07, 08:21 PM posted to rec.aviation.homebuilt
Ron Webb
Default Engine configuration
Yea -- my point was that this is ALMOST a good idea. But not quite.
Lotsa those!
Much better to just use a normal V6 or V8 and a PSRU. Many such that have
gone 2000+ hours.
As for weight and CG, I'd use the V6 STOL as an example. This is a set of
plans done in the '60's by a guy named Blanton. It has you buy a trashed
Piper tri-pacer and use the parts to build a new aircraft. More HP, longer
wings, and a lengthened fuselage made for a really good aircraft. There were
about 500 built, and there is only 1 on the NTSB crash database. He actually
had FAA approval at one time.
For the engine, he used a 3.8 Liter Ford V6. They are still selling
derivatives today.
After he hot-rodded it, he got 260 HP out of the engine, but derated it to
230 HP. According to the Blanton plans, it weighed 14 pounds more than a
comparably equipped IO360 Lyc (180 HP). Point is that the V6 engine with
belt PSRU meant he could use an engine big enough to do the job in style.
And since it is water cooled, you can run it at the stoicheometric (sp?)
point of 14.7:1 air fuel mixture, instead of the 10:1 or so necessary in an
air cooled engine to keep the valves from burning. That leaner mixture
translates to considerably better gas mileage (up to 30% better).
What that improvement translates to is that you need carry less fuel. So
even though the engine is 14 pounds heavier, 30% less fuel means overall you
are carrying less weight. And 50 more HP.
"cavelamb himself" wrote in message
Ron Webb wrote:
"Certain types of V engine have been built as inverted engines,
most commonly for aircraft. Advantages include better visibility
in a single-engined airplane, and lower centre of gravity."
An aluminum V8 was adapted in the 1960s to power ---I want to say the
Whittman Tailwind, but I could be wrong --- it was run direct drive and
inverted. Ran fine for many years. One problem was that the oiling system
had to be redesigned. It was originally designed to pump oil up into the
valve covers, then let it drain back down. Obviously that won't work if
the whole engine is upside down. Also the carb had to be replaced (float
bowls don't work upside down either.) Neither change is trivial, both are
do-able.
As I recall, Wittman said big problem was that the engine ate plugs in
the inverted position. Barely get 20 hours on a set...
You can see why it would result in a lower center of gravity - the crank
(directly connected to the prop) becomes the highest point on the engine
instead of the lowest. Same for visibility - the whole engine is lower
and out of the way.
But that all assumes you are going to use it direct drive - which almost
nobody does. If you use a gearbox, belt PSRU, or HiVo chain PSRU, they
will all give you an offset of several inches, making for the same center
of gravity without the other changes, and allowing for much greater
power, because engine RPM's can be run much higher for the same prop RPM.
And what does all that do to 1) weight and 2) CG ???
Old December 20th 07, 11:51 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Lotsa those!
gone 2000+ hours.
derivatives today.
Ron, how about share with us where you got you information?
Old December 21st 07, 01:43 AM posted to rec.aviation.homebuilt
Ron Webb
I got the information from the set of very old V6 STOL plans I bought a few
years ago off of EBay.
Paid $75. That's WAYYY out of character for me! It was worth it though.
Among other things, there is a blueprint that shows how to convert a PA-22
to a taildragger without the mods to the undercarriage. Just mod the gear to
sweep forward. My PA-20 was converted like that, so having the drawing is a
good thing.
There are perhaps 75 pages of drawings, and 75 pages of text. Covers
fuselage mods, wing mods, and converting the engine.
I'd share the info if I could get permission from his heirs...
Old December 21st 07, 01:51 AM posted to rec.aviation.homebuilt
good thing.
That's about what I expected.
Here, update thyself...
http://www.contactmagazine.com/
Old December 21st 07, 02:30 AM posted to rec.aviation.homebuilt
Ron Webb
Thanks for the link. It had been a while since I had looked at the Contact!
web site.
The Belted Air Power belt drive is very similar to the Blanton drive. I'm
sure I'd rather buy it than build it. I'd heard they weren't selling the BAP
unit anymore. Anybody know?
I like the info in the old plans because it is one of the few cases I've
seen where a certificated engine was removed from a certificated aircraft,
then a properly converted auto engine was installed in it's place - with
everything on both sides weighed, and pictures of the scale. I've not seen
much with better first hand knowledge of weights. And nothing much has
changed.
I have made a collection of similar info, from every source I can find,
including a few of my own weights and measures. I still have the file
somewhere...I think.
As for the fuel burn info - that is not even in doubt! You can't run an air
cooled engine at the Stoicheometric point. Anybody with a pilot's license
will tell you that you run rich of peak, or get used to paying for valve
jobs among other things. Not so with a water cooled engine. Keeping the
mixture EXACTLY at stoich is the whole purpose of an Electronic Fuel
Injection system. I DO know something about that.
An engine running at Stoich 14.7:1 fuel air mixture WILL get better mileage
than one getting the same power at 10:1 mixture. How could it be otherwise?
few years ago off of EBay.
PA-22 to a taildragger without the mods to the undercarriage. Just mod
the gear to sweep forward. My PA-20 was converted like that, so having
the drawing is a good thing.
Old December 21st 07, 03:08 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Thu, 20 Dec 2007 17:30:03 -0900, "Ron Webb"
web site.
changed.
Never heard of "agressive leaning" of air cooled aircraft engines?
Below peak power it is very viable
Posted via a free Usenet account from http://www.teranews.com
Old December 21st 07, 04:19 AM posted to rec.aviation.homebuilt
On Thu, 20 Dec 2007 11:21:23 -0900, "Ron Webb" wrote:
As for weight and CG, I'd use the V6 STOL as an example....There were
500 built? I'm skeptical. I did a search of the FAA database using "V-6,"
"STOL,", "Defunky", "Javelin" and "Blanton" as terms (with the typical
variations of "V-6". When you eliminate all the Zenairs and "R V-6"es, I maybe
35 hits. Five hundred flying aircraft is about the same as Fly Babies, and I
don't think the Blantons are as common.
Blanton was a controversial figure, back then, and there were those who were
skeptical of his veracity, and, at times, his sanity. Scroll about halfway down
here...
http://www.seqair.com/Other/Sawdust/Sawdust1992.html
Look for the section starting, "With a tongue like this, who needs a propeller?"
Or try...
http://bd-4.org/newsletter17.html
....and scroll down to the "Horsepower" section.
Old December 21st 07, 04:20 PM posted to rec.aviation.homebuilt
Like most homebuilt projects, there are likely a lot of
Blanton conversions sitting in garages and basements all over the
world, waiting for the owner to get motivated enough to finish the
project.
Dan
Old December 22nd 07, 02:45 AM posted to rec.aviation.homebuilt
Ron Webb
"V-6,"
maybe
and I
I'll admit that I don't have any source but Blantons writings for that one.
Could be wrong. This far in the future, and 35 IDENTIFIABLE still flying
isn't doing that bad. I know of several here in Alaska that have never been
registered.
were
halfway down
here...
Yea, his name here on RAH was nearly as bad as Zooom's after one fellow (who
was that?) got done with him.
Blanton's claim that you could get 230 reliable HP out of it was vigorously
debated.
With open intake, open exhaust, ported heads, big cam and carb, and forged
rods and pistons for reliability my desktop Dynamometer program shows over
330 HP at 6500 RPM, and 278 HP at a more sedate 5000 RPM possible, without
forced induction. Dyno2000 is usually very close to right. Blanton claimed
260 HP, derated to 230 HP.
The commercial version of the Ford 3.8 L with the Northwest Aero belt PSRU
attached that shipped with the Adventurer amphib put out around 200, but it
was not modified as described above. The ported heads alone would be worth
the extra 30 HP.
Old December 23rd 07, 04:04 PM posted to rec.aviation.homebuilt
GeorgeB
On Fri, 21 Dec 2007 17:45:28 -0900, "Ron Webb"
debated.
I doubt that anyone will argue with that statement. The problem isn't
in getting that power out, it is with getting the heat out, even with
water cooled engines. An engine, to give 2000 hours MTBF (well, with
a 2000 hour TBO, you would want the MTBF significnatly longer) needs
more than great tuning.
You did say reliable; remember that an airplane engine typically will
be expected to operate at 75% to 85% power for hours at a time; an
automobile engine in a 2500 lb car (think Cessna 182 or Cirrus)
running at 60 MPH probably averages 20 HP. I cannot prove my
automobile numbers, and they may be all wet.
Look at highly tuned auto engiens ... NASCAR probably gets 800 HP from
350 cu-in ... and they last 4 or 5 hours. Drag racers likely get over
double that, but their engines last minutes.
Contrary to what many think, most accept that the "obsolete"
Lyconental engines are pretty good products, making below 0.4 lb/hp-hr
SFC ... better than many cars. That's EFFICIENT!
I'd bet that if an auto engine would out perform Lycontental, we'd see
them certified and in use; the only water cooled engine I know of in
certified applications is the water cooled HEAD engine by Rotax. They
get 80 HP @ 5500 rpm from 74 cu-in ... and a 1500 hr TBO. They are
not cheap to build, either; even the uncertified ones are in the
$15,000 range.
Business wants to make money; if you can build a 230 HP engine that
will reliably give 2000 hours in an airplane and sell it for $10,000,
I'd bet that getting it certified and insured will be a piece of cake
.... certified, it is probalby over a $30,000 sale.
But my own opinion ... if it were that easy, it would have been done.
Engine configuration Michael Henry Home Built 42 December 20th 07 10:30 PM
Engine configuration cavedweller Home Built 7 December 16th 07 01:23 AM
V-22 Prop Configuration, 3-vs-4 blades Don McIntyre Naval Aviation 23 April 10th 06 03:23 AM
T-2C Buckeye nav light configuration. Mike W. Naval Aviation 14 March 17th 05 07:05 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 05:57 PM
