Hi,
did a lot of research and thinking about my engine cooling/cowling lately. It's a conventional VW-Dub powered pusher. There's quite a lot of space below the engine an very few on top. I want to do a tightly cowled engine (only the heads and barrels enclosed, not the complete engine under pressure). Yes - I know the 'traditional' method is feeding the air under pressure on top and sucking out below. But in my case things would be much easier (and streamlined) if I would feed the pressureized air from below and let the hot stuff exit through the top cover of the cowling. It will be an aluminun cowling, so heat is not such an issue. Any don'ts except an oil-spilled windscreen in case of engine failure (even then all oil hoses, cooler, pushrod tubes will be -outside- of the pressurized chamber). Your suggestions/opinions are highly appreciated. Happy New Year to All |
sorry, of course no pusher, prop is at the front end ;-)
oilsardine a écrit :
But in my case things would be much easier (and streamlined) if I would feed the pressureized air from below and let the hot stuff exit through the top cover of the cowling. It will be an aluminun cowling, so heat is not such an issue. Assume you mean tractor engine. "Reverse" cooling has already been done. It can work, but the air is pre-warmed when passing the exhaust pipes before reaching the cylinders and heads. See for instance the Eze family. NACA and NASA studies (Miley) have shown that this method generates a little more drag than an equally engineered "normal" cooling. So, unless you look for ultimate performance, you can do as you want. BTW, where will the exhaust discharge ? Best regards, -- Gilles http://contrails.free.fr |
NACA and NASA studies (Miley) have shown that this method generates a little more drag than an equally engineered "normal" cooling. ---------------------------------------------------- Also, the draft of the VW's head castings show that the direction of the cooling-air flow was taken into account when creating the demountable, permanent molds. Just another of the 'unimportant' details that tend to get overlooked (or deliberately ignored) when converting the VW for flight. -R.S.Hoover |
"GTH" schrieb im Newsbeitrag ... .... So, unless you look for ultimate performance, you can do as you want. BTW, where will the exhaust discharge ? the exhaust will discharge down/aft. This may not pose an problem, because I will use 114mm diameter air duct routing the pressurized air from nose-bowl's inlet to the cylinder shroud. So hot and cold air will not be mixed. |
schrieb im Newsbeitrag ... NACA and NASA studies (Miley) have shown that this method generates a little more drag than an equally engineered "normal" cooling. ---------------------------------------------------- Also, the draft of the VW's head castings show that the direction of the cooling-air flow was taken into account when creating the demountable, permanent molds. Just another of the 'unimportant' details that tend to get overlooked (or deliberately ignored) when converting the VW for flight. -R.S.Hoover good point, Veeduber. Wonder how much this effect/penalty is. |
the exhaust will discharge down/aft. This may not pose an problem, because I will use 114mm diameter air duct routing the pressurized air from nose-bowl's inlet to the cylinder shroud. So hot and cold air will not be mixed. So you will discharge cooling air up, and exhaust/engine compartment air down ? Best regards, -- Gilles http://contrails.free.fr |
"oilsardine" wrote in message ... "GTH" schrieb im Newsbeitrag ... ... So, unless you look for ultimate performance, you can do as you want. BTW, where will the exhaust discharge ? the exhaust will discharge down/aft. This may not pose an problem, because I will use 114mm diameter air duct routing the pressurized air from nose-bowl's inlet to the cylinder shroud. So hot and cold air will not be mixed. I would not think that that is a large enough diameter tubes for engine cooling. Someone may have used that size and had it work OK, but I would be surprised. I would think that you would need double that, or one tube for each cylinder. If you had that size intake, and no tubes, but instead an open plenum pressurizing one side of the cylinders, you would have much less drag, and more airflow, than the air slowing down going through the tubes. Also, most "Updraft" cooling engines do not do well on single engine airplanes, because the windshield is relatively close behind the engine, and that makes the whole top of the engine cowl an area of positive pressure. With positive pressure on the outlet, the air will have a very hard time getting out, and you will have a hot engine. At the very minimum, the outlets would need to be on the side of the cowl, ala Thorpe T-18. I think even those have some of the air exiting the bottom, in the area of low pressure. I'm sure someone will correct that if it is wrong. -- Jim in NC |
"Morgans" schrieb im Newsbeitrag ... .... I would not think that that is a large enough diameter tubes for engine cooling. Someone may have used that size and had it work OK, but I would be surprised. I would think that you would need double that, or one tube for each cylinder. sorry, yes, one tube per side. This would be the same what Sonex recommends for the AeroVee If you had that size intake, and no tubes, but instead an open plenum pressurizing one side of the cylinders, you would have much less drag, and more airflow, than the air slowing down going through the tubes. yes, but on the other hand would then have much more air leaks. All those wires tubes going through the baffling... Also, most "Updraft" cooling engines do not do well on single engine airplanes, because the windshield is relatively close behind the engine, and that makes the whole top of the engine cowl an area of positive pressure. Outlet would be about one feet in front of the cowl/windshield intersection. The cowl blends almost straight into the windscreen. There should be negative or zero pressure on the exit side and poitive pressure on the scoop. You may have aloog on this sketch: http://www.ph21.de/guest/updraft-cooling.JPG However question is how close is this to the pressure situation of my bird. |
In Sports Car Club of America Formula Vee racing (my other expensive
hobby) a few guys have tried updraft cooling on the blueprinted 1200cc motors we use, which put out about 60 bhp, have no cooling fans and are run at full throttle (except for brief braking) at average speeds in the 80-90 mph range; we also run in drafting packs which put a lot of hot air into every motor except the one in front. Nobody has stuck with it; they say that the cooling drag is not reduced measurably (if at all) and the heads run about 20-30 deg F hotter than with downdraft cooling. Your figure shows a low-pressure area on top of the nose. This is substantiated by the placement of the cooling outlets on Peter Garrison's updraft-cooled Melmoth II; they're so far forward and so close to facing forward that everyone mistakes them for inlets. Also note the high-pressure area under the nose in the figure; the only reason this changes to low pressure behind the cowling is the "chin" at the cowl's bottom rear. This is not a natural feature; it has to be induced with aerodynamic trickery at some cost in drag. |
| Thread Tools | |
| Display Modes | |
| Fuel pump cooling shroud? | Jim Burns | Owning | 3 | September 5th 06 02:06 PM |
| Question: Piston Cooling and Altitude | [email protected] | General Aviation | 1 | August 5th 06 01:02 AM |
| Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 05:32 AM |
| Speaking of Cooling | Larry Smith | Home Built | 4 | September 23rd 03 08:59 PM |
| oil cooling | [email protected] | Home Built | 2 | July 11th 03 03:15 AM |
